Webmail afstellen
Hallo
Ik ben al de hele dag bezig om mijn mailserver aan de gang te krijgen, na uren te googlen en documentatie op de ubuntu sites bekeken te hebben geef ik het op en vraag ik jullie om hulp.
Ik heb een server gebasseerd op ubuntu, postfix en dovecat.
Het probleem is dat mails niet naar buiten willen ik krijg namelijk deze error in het systeem:
-Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient-------
382217010B8 2142 Sun Sep 1 19:57:17 mailman-bounces@localhost.localdomain
(connect to mail.localhost.nl[2a02:58:3:79:25::2]:25: Network is unreachable)
stephan@localhost.nl
598E87010AA 1022 Sun Sep 1 20:39:02 root@ubuntu
(connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
root@ubuntu
8050D70124D 762 Sun Sep 1 20:26:12 stephan@racingweirdo.stx.nl
s.lucassen@icloud.com
68F56701260 724 Sun Sep 1 20:43:19 stephan@racingweirdo.stx.nl
40E09701222 611 Sun Sep 1 20:17:03 root@ubuntu
-- 7 Kbytes in 5 Requests.
en deze in de systeemlog:
Sep 1 20:29:01 ubuntu CRON[13834]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:29:06 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] New connection from 84.25.183.120
Sep 1 20:29:06 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] PAM_RHOST enabled. Getting the peer address
Sep 1 20:29:14 ubuntu pure-ftpd: (?@84.25.183.120) [WARNING] Authentication failed for user [anonymous]
Sep 1 20:29:14 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] New connection from 84.25.183.120
Sep 1 20:29:28 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] defaultracingweirdo is now logged in
Sep 1 20:30:01 ubuntu CRON[13849]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:30:01 ubuntu CRON[13850]: (getmail) CMD (/usr/local/bin/run-getmail.sh > /dev/null 2>> /dev/null)
Sep 1 20:30:01 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Sep 1 20:30:01 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Sep 1 20:30:01 ubuntu dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Sep 1 20:30:01 ubuntu postfix/smtpd[13878]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 1 20:30:01 ubuntu dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Sep 1 20:30:01 ubuntu postfix/smtpd[13878]: connect from localhost[127.0.0.1]
Sep 1 20:30:01 ubuntu postfix/smtpd[13878]: lost connection after CONNECT from localhost[127.0.0.1]
Sep 1 20:30:01 ubuntu postfix/smtpd[13878]: disconnect from localhost[127.0.0.1]
Sep 1 20:31:01 ubuntu CRON[13904]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:32:01 ubuntu CRON[13912]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:32:33 ubuntu postfix/qmgr[12459]: 8050D70124D: from=<stephan@racingweirdo.stx.nl>, size=762, nrcpt=1 (queue active)
Sep 1 20:32:33 ubuntu postfix/qmgr[12459]: 40E09701222: from=<root@ubuntu>, size=611, nrcpt=1 (queue active)
Sep 1 20:32:33 ubuntu postfix/smtp[13920]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Sep 1 20:32:33 ubuntu postfix/smtp[13921]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Sep 1 20:32:33 ubuntu postfix/smtp[13920]: 8050D70124D: to=<s.lucassen@icloud.com>, relay=none, delay=381, delays=381/0.05/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 1 20:32:33 ubuntu postfix/smtp[13921]: 40E09701222: to=<stephan@racingweirdo.stx.nl>, relay=none, delay=930, delays=930/0.07/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 1 20:33:01 ubuntu CRON[13927]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:34:01 ubuntu CRON[13947]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:35:01 ubuntu CRON[13978]: (getmail) CMD (/usr/local/bin/run-getmail.sh > /dev/null 2>> /dev/null)
Sep 1 20:35:01 ubuntu CRON[13979]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:35:01 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Sep 1 20:35:01 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Sep 1 20:35:01 ubuntu postfix/smtpd[14007]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 1 20:35:01 ubuntu postfix/smtpd[14007]: connect from localhost[127.0.0.1]
Sep 1 20:35:01 ubuntu dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Sep 1 20:35:02 ubuntu dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Sep 1 20:35:02 ubuntu postfix/smtpd[14007]: lost connection after CONNECT from localhost[127.0.0.1]
Sep 1 20:35:02 ubuntu postfix/smtpd[14007]: disconnect from localhost[127.0.0.1]
Sep 1 20:36:01 ubuntu CRON[14040]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:37:01 ubuntu CRON[14048]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:38:01 ubuntu CRON[14057]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:38:41 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] Timeout - try typing a little faster next time
Sep 1 20:38:54 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] Timeout - try typing a little faster next time
Sep 1 20:39:01 ubuntu CRON[14066]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:39:01 ubuntu CRON[14067]: (root) CMD ( [ -x /usr/lib/php5/maxlifetime ] && [ -d /var/lib/php5 ] && find /var/lib/php5/ -depth -mindepth 1 -maxdepth 1 -type f -cmin +$(/usr/lib/php5/maxlifetime) ! -execdir fuser -s {} 2>/dev/null \; -delete)
Sep 1 20:39:02 ubuntu postfix/cleanup[14088]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 1 20:39:02 ubuntu postfix/pickup[12458]: 598E87010AA: uid=0 from=<root>
Sep 1 20:39:02 ubuntu postfix/cleanup[14088]: 598E87010AA: message-id=<20130901183902.598E87010AA@ubuntu>
Sep 1 20:39:02 ubuntu postfix/qmgr[12459]: 598E87010AA: from=<root@ubuntu>, size=1022, nrcpt=1 (queue active)
Sep 1 20:39:02 ubuntu postfix/smtp[14092]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Sep 1 20:39:02 ubuntu postfix/smtp[14092]: 598E87010AA: to=<root@ubuntu>, orig_to=<root>, relay=none, delay=0.23, delays=0.22/0.01/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 1 20:40:01 ubuntu CRON[14097]: (getmail) CMD (/usr/local/bin/run-getmail.sh > /dev/null 2>> /dev/null)
Sep 1 20:40:01 ubuntu CRON[14098]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:40:01 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Sep 1 20:40:01 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Sep 1 20:40:01 ubuntu postfix/smtpd[14126]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 1 20:40:01 ubuntu postfix/smtpd[14126]: connect from localhost[127.0.0.1]
Sep 1 20:40:01 ubuntu dovecot: imap-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Sep 1 20:40:02 ubuntu postfix/smtpd[14126]: lost connection after CONNECT from localhost[127.0.0.1]
Sep 1 20:40:02 ubuntu postfix/smtpd[14126]: disconnect from localhost[127.0.0.1]
Sep 1 20:40:02 ubuntu dovecot: pop3-login: Disconnected (no auth attempts): rip=127.0.0.1, lip=127.0.0.1, secured
Sep 1 20:40:47 ubuntu postfix/master[12420]: terminating on signal 15
Sep 1 20:41:01 ubuntu CRON[14223]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:42:02 ubuntu CRON[14246]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:42:15 ubuntu postfix/master[14487]: daemon started -- version 2.9.6, configuration /etc/postfix
Sep 1 20:42:15 ubuntu postfix/qmgr[14492]: 382217010B8: from=<mailman-bounces@localhost.localdomain>, size=2142, nrcpt=1 (queue active)
Sep 1 20:42:15 ubuntu postfix/qmgr[14492]: 8050D70124D: from=<stephan@racingweirdo.stx.nl>, size=762, nrcpt=1 (queue active)
Sep 1 20:42:15 ubuntu postfix/smtp[14498]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Sep 1 20:42:15 ubuntu postfix/smtp[14498]: 8050D70124D: to=<s.lucassen@icloud.com>, relay=none, delay=963, delays=963/0.11/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 1 20:42:45 ubuntu postfix/smtp[14497]: connect to mail.localhost.nl[82.197.223.85]:25: Connection timed out
Sep 1 20:42:45 ubuntu postfix/smtp[14497]: connect to mail.localhost.nl[2a02:58:3:79:25::2]:25: Network is unreachable
Sep 1 20:42:45 ubuntu postfix/smtp[14497]: 382217010B8: to=<stephan@localhost.nl>, relay=none, delay=2728, delays=2698/0.27/30/0, dsn=4.4.1, status=deferred (connect to mail.localhost.nl[2a02:58:3:79:25::2]:25: Network is unreachable)
Sep 1 20:43:01 ubuntu CRON[14504]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:43:07 ubuntu dovecot: auth-worker: mysql(localhost): Connected to database dbispconfig
Sep 1 20:43:07 ubuntu dovecot: imap-login: Login: user=<stephan@racingweirdo.stx.nl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=14516, secured
Sep 1 20:43:07 ubuntu dovecot: imap(stephan@racingweirdo.stx.nl): Disconnected: Logged out bytes=44/709
Sep 1 20:43:08 ubuntu dovecot: imap-login: Login: user=<stephan@racingweirdo.stx.nl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=14518, secured
Sep 1 20:43:08 ubuntu dovecot: imap(stephan@racingweirdo.stx.nl): Disconnected: Logged out bytes=244/1826
Sep 1 20:43:08 ubuntu dovecot: imap-login: Login: user=<stephan@racingweirdo.stx.nl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=14520, secured
Sep 1 20:43:08 ubuntu dovecot: imap(stephan@racingweirdo.stx.nl): Disconnected: Logged out bytes=272/1298
Sep 1 20:43:19 ubuntu postfix/smtpd[14521]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 1 20:43:19 ubuntu postfix/smtpd[14521]: connect from localhost[127.0.0.1]
Sep 1 20:43:19 ubuntu postfix/cleanup[14525]: warning: database /var/lib/mailman/data/virtual-mailman.db is older than source file /var/lib/mailman/data/virtual-mailman
Sep 1 20:43:19 ubuntu postfix/smtpd[14521]: 68F56701260: client=localhost[127.0.0.1]
Sep 1 20:43:19 ubuntu postfix/cleanup[14525]: 68F56701260: message-id=<1ec8fafbe509c661106d7b0e4921e7f7.squirrel@192.168.178.13>
Sep 1 20:43:19 ubuntu postfix/qmgr[14492]: 68F56701260: from=<stephan@racingweirdo.stx.nl>, size=724, nrcpt=1 (queue active)
Sep 1 20:43:19 ubuntu postfix/smtp[14498]: connect to 127.0.0.1[127.0.0.1]:10024: Connection refused
Sep 1 20:43:19 ubuntu postfix/smtpd[14521]: disconnect from localhost[127.0.0.1]
Sep 1 20:43:19 ubuntu postfix/smtp[14498]: 68F56701260: to=<s.lucassen@icloud.com>, relay=none, delay=0.18, delays=0.17/0/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Sep 1 20:43:19 ubuntu dovecot: imap-login: Login: user=<stephan@racingweirdo.stx.nl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=14527, secured
Sep 1 20:43:19 ubuntu dovecot: imap(stephan@racingweirdo.stx.nl): Disconnected: Logged out bytes=615/459
Sep 1 20:43:19 ubuntu dovecot: imap-login: Login: user=<stephan@racingweirdo.stx.nl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=14530, secured
Sep 1 20:43:19 ubuntu dovecot: imap(stephan@racingweirdo.stx.nl): Disconnected: Logged out bytes=117/1401
Sep 1 20:43:23 ubuntu dovecot: imap-login: Login: user=<stephan@racingweirdo.stx.nl>, method=PLAIN, rip=127.0.0.1, lip=127.0.0.1, mpid=14532, secured
Sep 1 20:43:23 ubuntu dovecot: imap(stephan@racingweirdo.stx.nl): Disconnected: Logged out bytes=117/1401
Sep 1 20:44:02 ubuntu CRON[14539]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:44:14 ubuntu pure-ftpd: (?@84.25.183.120) [INFO] Timeout - try typing a little faster next time
Sep 1 20:44:28 ubuntu pure-ftpd: (defaultracingweirdo@84.25.183.120) [INFO] Timeout
Sep 1 20:45:01 ubuntu CRON[14548]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 > /dev/null | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Sep 1 20:45:01 ubuntu CRON[14549]: (getmail) CMD (/usr/local/bin/run-getmail.sh > /dev/null 2>> /dev/null)
Sep 1 20:45:03 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] New connection from 127.0.0.1
Sep 1 20:45:03 ubuntu pure-ftpd: (?@127.0.0.1) [INFO] Logout.
Ik heb bij postfix aangegeven dat http://84.25.183.120/ het juiste domein is maar op een of andere manier blijft hij mail.localhost.nl aanroepen, weet iemand waarom dit is?
  • begintmeta
begintmeta
Waarom wil postfix met localhost port 10024 verbinden? Spamassassin oid? Ik denk dat het handig zou zijn als je de relevante configuratiebestanden en logs zou posten (en irrelevante zaken even uit de logs filteren)
  • vanaalten
  • Laatst online: 21:19
Ik heb er niet al teveel verstand van (maar: *wel* een werkende mailserver draaiend onder Debian) maar ik denk dat het helpt als je:
1) je Postfix configuratie hier plaatst (/etc/postfix/main.cf, denk ik)
2) je laat weten wat je aan het doen bent: vanaf waar probeer je je mail te versturen... vanaf de server zelf, of vanaf een andere machine? Als root, of als gewone gebruiker?
3) gaat mail ontvangen van buiten wel goed?
4) hoe probeer je Postfix te configureren: gewoon door de config te editten met een texteditor, of via zo'n virtualmin manage geval?
Verder denk ik dat je misschien 'localhost' moet toevoegen in Postfix aan de lijst van 'mydestination' en je je lokale netwerk (192.168.178.0/24 en 127.0.0.0/8) toevoegen aan 'mynetworks'.
Ik heb deze gevolgd: http://www.howtoforge.com...nd-dovecot-ispconfig-3-p3
Zowel naar mail verzenden als ontvangen gaat niet, ik edit de file gewoon ouderwets et nano.
Ik heb even tijdelijk het gratis domein racingweirdo.stx.nl tot mijn beschikking die doormiddel van dns is gekoppeld aan mijn server, zowel web als mail.
Ik probeer vanaf een ander machine een mail te verzenden via mijn server.
# See /usr/share/postfix/main.cf.dist for a commented, more complete version
# Debian specific: Specifying a file name will cause the first
# line of that file to be used as the name. The Debian default
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
# appending .domain is the MUA's job.
append_dot_mydomain = no
# Uncomment the next line to generate "delayed mail" warnings
#delay_warning_time = 4h
readme_directory = /usr/share/doc/postfix
# is /etc/mailname.
biff = no
# TLS parameters
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
smtpd_tls_session_cache_database = btree:${data_directory}/smtpd_scache
smtp_tls_session_cache_database = btree:${data_directory}/smtp_scache
# See /usr/share/doc/postfix/TLS_README.gz in the postfix-doc package for
# information on enabling SSL in the smtp client.
myhostname = ubuntu
alias_maps = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
myhostname = ubuntu
alias_database = hash:/etc/aliases, hash:/var/lib/mailman/data/aliases
mydestination = ubuntu, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8 [::1]/128
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
html_directory = /usr/share/doc/postfix/html
virtual_alias_domains =
$f, pro$mydestination = ubuntu, localhost, localhost.localdomain
relayhost =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, pro$
relayhost = relayhost =
relayhost =
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /var/vmail
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
inet_protocols = all
smtpd_sasl_auth_enable = yes
broken_sasl_auth_clients = yes
smtpd_sasl_authenticated_header = yes
smtpd_recipient_restrictions = permit_mynetworks, permit_sasl_authenticated, ch$
smtpd_tls_security_level = may
transport_maps = hash:/var/lib/mailman/data/transport-mailman, proxy:mysql:/etc$
relay_domains = mysql:/etc/postfix/mysql-virtual_relaydomains.cf
relay_recipient_maps = mysql:/etc/postfix/mysql-virtual_relayrecipientmaps.cf
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $vir$
smtpd_sender_restrictions = check_sender_access mysql:/etc/postfix/mysql-virtua$
smtpd_client_restrictions = check_client_access mysql:/etc/postfix/mysql-virtua$
smtpd_client_message_rate_limit = 100
maildrop_destination_concurrency_limit = 1
maildrop_destination_recipient_limit = 1
virtual_transport = dovecot
header_checks = regexp:/etc/postfix/header_checks
mime_header_checks = regexp:/etc/postfix/mime_header_checks
nested_header_checks = regexp:/etc/postfix/nested_header_checks
Wat ben ik toch een ongelovelijke ezel, zie net dat myhostname en mynetworks verkeerd staan, ik deze ga deze aanpassen aan mijn ip adres(84.) dan moet het werken.
[ Voor 15% gewijzigd door Verwijderd op 01-09-2013 21:43 ]
  • vanaalten
Afgezien daarvan is het verstandig even een cleanup te doen van je postfix config. Het aantal dubbele regels dat ik zie gaat het ooit eens heel verwarrend maken.
Ik heb ook even snel die tutorial bekeken die je gebruikt. Als ik het goed zie ga je daarbij Postfix juist niet met de hand configureren, maar gebruik je zo'n admin pakket (ISPConfig-3 of zo in stap #22). Geen idee hoe dat werkt, ik ben meer van dat soort dingen zelf doen en met de hand configureren.
Je ziet in die tutorial ook nergens dat Postfix geconfigureerd wordt (op een kleinigheidje na voor iets dat binnen ISPConfig-3 niet kan). Ik gok dat je die myhostname en mynetworks dus ook niet zelf hoeft te configureren, maar dat dat ook door ISPConfig-3 geregeld wordt.
Het nadeel van deze tutorial is dan ook dat er zo enorm veel geinstalleerd wordt, je veel stappen moet doen voor je het eindresultaat bereikt en je veelal niet weet hoe dingen echt werken en samenhangen. 1 klein foutje ergens, en het werkt niet - en zie dan maar eens te achterhalen wat de oorzaak is.
[ Voor 38% gewijzigd door vanaalten op 02-09-2013 08:05 ]
vanaalten schreef op maandag 02 september 2013 @ 08:00:
Postfix kun je juist niet met ispconfig bewerken of aanpassen, alles moet met de hand en nano, ik ben inmiddels opnieuw begonnen vanavond verder.
  • begintmeta
begintmeta
Kan je ook je master .cf eens doorkijken(&posten), ik heb het dee dat je sowieso de mail nog door een filter probeert te routen, gezien die poort 10024. Maar ik moet zeggen dat het alweer een hele tijd geleden is dat ik een mailserver heb opgezet. Zeker met virtual users kan dat best wel voeten in de aarde hebben (ik worstelde altijd vooral met ldap als ik me goed herinner).
[ Voor 3% gewijzigd door begintmeta op 02-09-2013 09:35 ]
begintmeta schreef op maandag 02 september 2013 @ 09:35:
Hij is al weg, 1024 is de vervangende poort van de 25.
  • deadinspace
  • Laatst online: 23:29
deadinspace
The what goes where now?
Verwijderd schreef op zondag 01 september 2013 @ 20:49:
84.25.183.120 is natuurlijk geen domein (en http://84.25.183.120/ al helemaal niet). Ik weet niet of postfix dat pikt, maar eigenlijk hoort dat natuurlijk een domeinnaam te zijn. (Sowieso, wie wil er nou mailen naar racingweirdo@84.25.183.120...)
Dat IP-adres is trouwens een Ziggo consumentenadres. Veel consumentenproviders blokkeren poort 25 (zowel in- als uitgaand), wat het draaien van een eigen mailserver onmogelijk maakt. Weet je zeker dat je daar geen last van hebt? Zie ook de "network is unreachable" melding:
(En hoezo localhost.nl?)
deadinspace schreef op maandag 02 september 2013 @ 09:46:
Nee daar heb ik geen last van, heb hem via de howto ingesteld op 1025 wat wel werkt.
Beide dingen vielen mij ook al op, beide heb ik niet ingesteld,ik heb hem echt op. Mijn domein racingweirdo.stx.nl afgesteld, maar goed ik ga vanavond verder met een schone installatie.
  • wian_gn
  • Laatst online: 21:26
Als je binnenkomende mail wilt kunnen ontvangen, zul je moeten zorgen dat poort 25 van je MX-record(s) bereikbaar is (zijn), dan kun je controleren door te telnetten naar poort 25 van het IP-adres van de MX. Verder raad ik je aan om uitgaande mail af te leveren op een SMTP-server van je provider.
Eventueel kun je voor beide gebruik maken van een externe dienst, die zorgt er dan voor dat je binnenkomende mail wordt afgeleverd op een niet-standaard poort en eventueel zorgt die ook voor outbound mail. Tevens vangt zo'n dienst over het algemeen je mail op als je eigen server niet on-line is. Kost natuurlijk een paar knaken, maar het maakt je het leven wel veel aangenamer.
  • deadinspace
deadinspace
Verwijderd schreef op maandag 02 september 2013 @ 10:47:
Nouja, je logs beweren anders (zie het gequote stuk uit mijn vorige post).
Bovendien: ingesteld op poort 1025 voor wat? Alle andere mailservers in de wereld luisteren op poort 25, niet 1025, dus als je daar mail wil afleveren zal poort 25 uitgaand open moeten staan. En alle andere mailservers proberen bij jouw mailserver af te leveren op poort 25, dus als je mail wilt ontvangen daarvan zal poort 25 inkomend ook open moeten staan.
Je mailserver op een andere poort laten luisteren of versturen helpt alleen voor andere mailservers en -clients onder jouw beheer die je in kunt stellen voor die alternatieve poort.
Dan zou ik eens je systeemconfiguratie nalopen (zoals /etc/hosts en /etc/hostname). Wellicht is localhost.nl een default iets uit ispconfig? (ik gebruik dat soort pakketten nooit)
  • vanaalten
Ziggo klanten: inkomende mail kan gewoon door je prive-mailserver ontvangen worden; uitgaand moet echter via de relay van Ziggo. Kwestie van de relayhost opgeven in Postfix en het werkt.
