• TVDG
  • Laatst online: 09-10 21:09
Ik kwam op de site van AMD het volgende tegen [en dit is volgens mij niet de M laptop variant]
Wat zijn jullie bedenkingen hierover.
Ik kan nog geen release date vinden.
Afbeeldingslocatie: http://www.amd.com/PublishingImages/Public/Photograph_ProductShots/WebBannerJPEG/AMD-Radeon-HD-8900-Series-Hero-574W.jpg
http://www.amd.com/us/pro...s/8000/Pages/8970.aspx#/3
◾1GHz Engine Clock (up to 1.05GHz with boost)
◾3GB GDDR5 Memory
◾1500MHz Memory Clock (6.0 Gbps GDDR5)
◾288GB/s memory bandwidth
◾4.3 TFLOPS Single Precision compute power
◾1.01 TFLOPS Double Precision compute power
◾GCN Architecture ◦32 Compute Units (2048 Stream Processors)
◦128 Texture Units
◦128 Z/Stencil ROP Units
◦32 Color ROP Units
◦Dual geometry units
◾Dual Asynchronous Compute Engines (ACE)
◾PCI Express 3.0 x16 bus interface
◾DirectX® 11.1-capable graphics ◦9th generation programmable hardware tessellation units
◦Shader Model 5.0
◦DirectCompute 11
◦Accelerated multi-threading
◦HDR texture compression
◦Order-independent transparency
◾OpenGL 4.2 support ◦Partially Resident Textures (PRT) •Ultra-high resolution texture streaming technology
◾Image quality enhancement technology ◦Up to 24x multi-sample and super-sample anti-aliasing modes
◦Adaptive anti-aliasing
◦Morphological Anti-Aliasing (MLAA) 2.0
◦DirectX® 9/10/11 Super Sample Anti-Aliasing (SSAA) •Automatic LOD adjustment (Requires AMD Catalyst™ 12.4 or higher)
◦16x angle independent anisotropic texture filtering
◦128-bit floating point HDR rendering
◾AMD Eyefinity multi-display technology4 ◦Up to 6 displays supported with DisplayPort 1.2 Multi-Stream Transport
◦Independent resolutions, refresh rates, color controls, and video overlays
◦Display grouping •Combine multiple displays to behave like a single large display
◾AMD App Acceleration3 ◦OpenCL 1.2 Support
◦Microsoft C++ AMP
◦DirectCompute 11
◦Double Precision Floating Point
◦AMD HD Media Accelerator •Unified Video Decoder (UVD) •H.264
•VC-1
•MPEG-2 (SD & HD)
•MVC (Blu-ray 3D)
•MPEG-4 Part 2 (DivX/Xvid)
•Adobe Flash
•DXVA 1.0 & 2.0 support
•Video Codec Engine (VCE) •Multi-stream hardware H.264 encoder
•Full-fixed mode: 1080p @ 60 FPS encoding
•Hybrid mode: Stream Processor-assisted encoding
•Enhanced Video Quality features •Advanced post-processing and scaling •Deblocking
•Denoising
•Automatic deinterlacing
•Mosquito noise reduction
•Edge enhancement
•3:2 pulldown detection
•Advanced video color correction •Brighter whites processing (Blue Stretch)
•Independent video gamma control
•Flesh tone correction
•Color vibrance control
•Dynamic contrast
•Dynamic video range control
◾AMD HD3D technology5 ◦Stereoscopic 3D display/glasses support
◦Blu-ray 3D support
◦Stereoscopic 3D gaming
◦3rd party Stereoscopic 3D middleware software support
◾AMD CrossFire™ multi-GPU technology6 ◦Dual, triple or quad-GPU scaling
◾Cutting-edge integrated display support ◦DisplayPort 1.2 •Max resolution: 4096x2160 @ 60 Hz per display
•Multi-Stream
•21.6 Gbps bandwidth (HBR2)
•High bit-rate audio
•Quad HD/4K/UHDTV display support
•1080p60 Stereoscopic 3D (Frame Sequential Format)
◦HDMI® (With 4K, 3D, x.v.Color™ and Deep Color) •Max resolution: 4096x2160 @ 30 Hz
•1080p30 Stereoscopic 3D (Packed Frame Format)
•Quad HD/4K/UHDTV video display support
◦Dual-link DVI with HDCP •Max resolution: 2560x1600
◦VGA •Max resolution: 2048x1536
◾Integrated HD audio controller ◦Output protected high bit rate 7.1 channel surround sound over HDMI with no additional cables required
◦Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
◾AMD PowerPlay™ power management technology7 ◦Automatic power management with low power idle states
◾AMD PowerTune technology7 ◦Intelligent TDP management technology
◦Dynamic clockspeed/performance enhancement for games
◾AMD ZeroCore Power technology7 ◦Ultra-low idle power when the system’s display is off
◦Efficient low power mode for desktop work
◦Secondary GPUs in an AMD CrossFire™ technology configuration power down when unneeded
◾AMD Catalyst™ graphics and HD video configuration software ◦Software support for Windows® 7, Windows Vista® and Windows® XP.
◦AMD Catalyst™ Control Center - AMD Catalyst™ software application and user interface for setup, configuration, and accessing features of AMD Radeon products.
◦Unified Graphics display driver - AMD Catalyst™ software enabling other PC programs and devices to use advanced graphics, video, and features of AMD Radeon™ products.
  • Teun.
8000 series zijn rebrands, dit is denk ik simpelweg de 7970 ghz edition.
  • Gadgeteer
8000 serie is OEM versie van de 7000 serie.
De 8970 is dan ook (volgens mij) vergelijkbaar aan de 7970
  • Fordox
  • Laatst online: 08-10 14:41
Fordox
00101010
8000 is een getweakte oem versie van de 7000 serie. deze wordt voor de consument over geslagen, en springt gelijk door naar de 9000 serie ;)
Edit: Ik gebruik de edit-knop vaak.
  • Gadgeteer
@Fordox: getweakt betekent wat precies?
Ik heb nog niet gelezen dat de 8000 serie sneller is dan de 7000 serie (dus dat een 8970 sneller zou zijn dan een7970). Wellicht dat een OEM partner zelf nog e.e.a kan tweaken net als dat A-merken dat vaak ook doen met bijvoorbeeld een OC uitvoering.
