fdisk run-time error R6003 - integer divide by 0
  • 790 views sinds 30-01-2008
  • gluiperd
  • Laatst online: 25-05-2025
Deze foutmelding kreeg ik na een dag tweaken met mn HD's plotseling. Deze krijg ik als ik op een helemaal lege schijf (die primary slave staat) een primary dos partition wil maken....ik kan dr nix meer mee dus (hij heeft geen logical drive nix...)
iemand die dit kent???
Uit Microsoft Technet:
This information applies to both Microsoft DoubleSpace and Microsoft DriveSpace.
For MS-DOS 6.22, use DRVSPACE in place of DBLSPACE for commands and filenames.
You may receive the following error message if you are using MS-DOS DoubleSpace:
Error: R6003 - Integer Divide by Zero
CAUSE
This error message can be caused by corrupted DoubleSpace files or incompatible
terminate-and-stay-resident (TSR) programs.
WORKAROUND
To work around this problem, do the following:
1. Copy the DBLSPACE.BIN file from Disk 1 of the original MS-DOS Upgrade disk
set to the root directory for your host drive. For example, if your
compressed drive is C, and your host drive is H, type the following at the
MS-DOS command prompt and then press ENTER:
" copy a:\dblspace.bin h:\ " (without the quotation marks)
To determine your host drive for drive C, type "dblspace /list" (without the
quotation marks) at the MS-DOS command prompt and then press ENTER.
Note: If there is an existing DBLSPACE.BIN file on the host drive but it is
corrupted, remove the attributes from the file before copying a new one to
the drive. For example, type "attrib h:\dblspace.bin -r -s -h" (without the
2. Expand the DBLSPACE.EXE files from the original MS-DOS disks. For example,
type the following at the MS-DOS command prompt and then press ENTER:
" expand a:\dblspace.ex_ c:\dblspace.exe" (without the quotation marks)
DBLSPACE.EX_ is located on Disk 3 of the 1.44-megabyte (MB) 3.5-inch disk set
and on Disk 4 of the 1.2-MB 5.25-inch disk set.
3. Restart your computer by pressing the reset button or by turning the machine
off and then on again.
4. If you have not eliminated the problem, restart your computer again. To
isolate the problem, press the Clean Start function key (F5) or the
Interactive Startup function key (F8) when the text "Starting MS-DOS..."
appears to eliminate unnecessary device drives and TSRs.
Succes d'rmee!
