Mybook world + port forwarding leidt niet tot remote toegang
  • 187 views
  • traveller22
  • Laatst online: 05-08-2013
<Ik heb deze post op het forum van mybookworld.wikidot geplaatst en deze nu even gekopiëerd. Vandaar de engelse taal>
Hello,
After hours and hours of reading and tinkering with settings I come here to ask help....
The situation is as follows:
I am in Spain and have Orange ADSL with an Orange Livebox modem/router. My Book World Edition (MBWE) attached to router on LAN-port.
Access from within the network is not a problem.
Installed most of the Feature Packs (openvpn, no-ip, transmission, mediatomb) have not had the time to play around with these.
In my former home in The Netherlands I was able to connect to the MBWE remotely. With my set up now I am not.
My MBWE still has the same static IP of 192.168.1.116 and my router's gateway is 192.168.1.1.
I set port 21 on the router to forward to 21 on 192.168.1.168 and it didn't work.
Then after much trying I just started to open a bunch of ports to see if that was going to help anything.
All of the following ports were open to LAN address 192.168.1.116 (static IP MBWE) with TCP and enabled in the router:
LAN Port > Public Port:
21>21
22>22
80>80
119>119
443>443
1394>1394
5000-5049 >5000-5049
8080>8080
9091>9091
My MBWE info I found:
Mybook Infos
Process Disk Network Performance Leds
Network Interfaces
eth0 Link encap:Ethernet HWaddr 00:90:A9:6D:3A:DE
inet addr:192.168.1.116 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:56678 errors:0 dropped:0 overruns:0 frame:0
TX packets:10633 errors:1 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:15366559 (14.6 MiB) TX bytes:2695956 (2.5 MiB)
Interrupt:8
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:8943 errors:0 dropped:0 overruns:0 frame:0
TX packets:8943 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:453962 (443.3 KiB) TX bytes:453962 (443.3 KiB)
Routing Table
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
224.0.0.0 0.0.0.0 240.0.0.0 U 0 0 0 eth0
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 eth0
Ports in use
tcp 0 0 0.0.0.0:49152 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:7777 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:2049 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:548 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:932 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:38663 0.0.0.0:* LISTEN
tcp 0 0 192.168.1.116:9000 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:3689 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:1641 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:57587 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:21 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:1910 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN
tcp 0 0 127.0.0.1:5335 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN
unix 2 [ ACC ] STREAM LISTENING 6561 /tmp/lighttpd/public-php-fcgi.sock-0
unix 2 [ ACC ] STREAM LISTENING 6570 /tmp/lighttpd/php-fcgi.sock-0
When I tried Port Forward's port checker application I found that of all my manually opened ports ONLY port 8080 seemed to be open. When I put in my remote browser's address bar http://myip:8080 is comes back with "hello world".
But with http://myip:<any port> it fails.
Also with ftp://myip, ftp://admin@myip, ftp://admin@myip:21.
Can anybody tell me if I am missing something here. Or maybe someone can advise me which step to take from here. Or what I should check next?
Your help would be greatly appreciated!!!!
Kind regards,
Traveller22
  • job
  • Laatst online: 19:55
job
De meeste adsl modems doen niet aan nat loopback (Wikipedia: Network address translation: Nat Loopback) Dat kan een reden zijn voor het niet kunnen bereiken van de servers.
Testen of de poort daadwerkelijk open staat doe je overigens het beste via een andermans internetverbinding, of kijk of de poort te bereiken is via shields up (grc.com) of een vergelijkbare test site.
[ Voor 14% gewijzigd door job op 05-08-2013 02:19 ]
  • traveller22
Spelen met ShieldsUp heeft geholpen. Problem solved!
[ Voor 79% gewijzigd door traveller22 op 05-08-2013 00:36 ]
  • Equator
  • Laatst online: 07-10 09:40
Equator
Crew Council
🦺#Rodekruis #whisky #barista
Fijn, en toch gaat er een slot op. We zijn een nederlands forum, dus verwachten we posts in het nederlands.
Volgende keer gewoon even vertalen.
