[Win2k] Branden in Nero en geen admin user zijn...
  • 109 views sinds 30-01-2008
  • Helsie
Hoe kun je iemand met Nero laten branden zonder hem admin rechten te geven?
  • Arno
  • Laatst online: 11:51
Arno
PF5A
--> Software Algemeen <--
"Supercars are made to mess around with G-forces, hypercars are made to mess around with G-strings"
Jeremy Clarkson
  • Helsie
Dit is toch een typische win2k vraag???
  • Metzie
  • Laatst online: 09:23
Metzie
Nyaano !
Nero installeren en de user laten branden.
Zover ik weet kan je als default user gewoon programma's starten, dus ook nero.
http://www.totalprogress.nl Computer reparatie en webdesign
I just hate it when the computer does what I tell it to do and not what I mean for it to do.
  • Helsie
Dat geldt dus niet voor Win2k & Nero.
Er zit wel iets in de Nero help:
Now, let's assume the situation of a Windows NT4 or Windows 2000 PC in a network environment and with many different users. Security considerations make it absolutely impossible to grant administrator rights to all. So firstly, there must be a way to allow CD recording for non-administrators and being able to decide which users may record CDs and which users may not.
The way Nero solves this problem is to allow system administrators to assign during installation a group of users the rights to record CDs on the system. If an administrator wants to allow or disallow CD recording for certain users, it is enough to make the user member of this group or to remove the group membership of that user. If everybody should get the right to record CDs, the recording rights should be assigned to the group "Users".
In some situations, it might be convenient for the administrator to change the group assigned CD recording permissions. Nero has a new property page with title "Security". This page can be opened by using the menu command "File"->"Preferences". Administrators may edit and normal users may only view the group name of the users, that have the permission to burn CDs. Any changes of these settings become effictive after the next system restart. Uninstalling Nero will cause the recording CD rights to be removed again.
Maar ik heb bij File-preferences dat Tabje niet. In de Usermanager zie ik ook niets terug van Nero...
  • StratoFarmer
  • Laatst online: 04-09 21:10
StratoFarmer
Anke :*
.....echter, branden is een soort formatteren (wat een user niet mag!)
Power User mag wel branden dacht ik.
en waarschijnlijk kun je de rechten voor die functie wel apart aanpassen.
en dan maar hopen dat het niet samen gaat met de rechten voor formatteren van c:\ >:)
Mijn plekkie + Sympathisant van 'GoT voor Behoud der Nederlandsche Taal' [GvBdNT]
  • Helsie
Volgens de help van Nero moet het wel kunnen.
  • Helsie
Echt dank aan het modje dat vindt dat dit een algemene vraag is.
Laat ik het anders stellen: Hoe kun je in Win2k branden en toch geen admin rechten hebben?
Is het dan nu wel een win2k vraag?
Op dinsdag 05 juni 2001 12:53 schreef Helsie het volgende:
En dat probleem heb ik dus ook.
  • Booooe
  • Laatst online: 27-11-2021
Booooe
Fetch!
Gister Nero 5.5 onder w2k weer eens geinstalleerd (niet dat ie t doet, maarja...).
tijdens de installatie kreeg ik de vraag welke soort users mochten branden. Kreeg een pulldown menu'tje met de lijst van Admin tot en met User...
  • rstegers
  • Laatst online: 14-09 08:48
Dit kreeg ik van Nero terug:
Sorry, we had to disable the "Security Feature" as when this option was enabled, we found many programs that did not properly support this Microsoft feature would no longer function. To avoid Tech support calls, we disabled this feature.
We hope to have this resolved soon!
UNOFFICALLY:
You can.....
In users and passwords in control panel, i setup the user so that they were seen as an Admin locally (i.e. the same user logon and specified my domain but member of local Admin group). Used policies and permissions on the 2000 Server Directory to restrict their access.And thank
you for using Nero
Die unofficial oplossing is toch niets voor grote netwerken. Gebruikers kunnen op dat moment lokaal alles doen.
Blah.
Heeft iemand een goede oplossing voor het branden onder windows 2000 professional met een default user???
  • InSPiRE
  • Laatst online: 21-03 20:19
In deze thread staat een goede opmerking van F_J_K. Kijk daar maar eens.
