• GoT
GoT
/ / ( . Y . ) \ \
Hoi,
Ik heb Google maps geupdate naar nieuwe versie.
Er was in Google maps een optie: History daarmee kon je op de map per dag zien waar je bent geweest.
Maar na de update is dit weg ?
o << Your asshole before prison.
O << Your asshole after prison.
  • xp7amrkr
  • Laatst online: 28-09 20:15
xp7amrkr
De enige echte!
Vroeger was dat "Latitude", een dienst waar Google mee stopt. Zie de onderstaande email die ik eerder deze week ontving:
Hello,
Earlier today, we announced that Google Latitude is no longer part of the Google Maps app, and we're retiring Latitude on August 9, 2013.
This means that after August 9, your Latitude friends list will be deleted and you'll lose the ability to share your location with them. There will also be some changes to Location Reporting and Location History, including changes to third-party applications that use Google Latitude. Please see our FAQs for more information.
We understand some of you still want to see your friends and family on a map, which is why we've added location sharing to Google+ for Android (coming soon to iOS).
Thank you for using Google Latitude.
Sincerely,
The Google Latitude Team
True science is not measured by its successes, but by its ability to learn gracefully from its failures.
  • Tk55
  • GoT
GoT
/ / ( . Y . ) \ \
Heet dat Latitude ?
Voor de duidelijkheid:
Sharing stond uit, ik deel mijn locatie niet met anderen.
Ik kon alleen op mijn eigen smartphone zien (mbv de map) waar ik ben geweest en welke route ik heb genomen.
Het heeft al die tijd gewerkt, totdat ik donderdag of vrijdag maar eens een update heb gedaan van Google maps.
  • Balance
  • Laatst online: 20:16
A new Google Maps app for smartphones and tablets
One important change you should know about is that Latitude and check-ins will be retired. These features will no longer be a part of the new Google Maps app, and will stop functioning in older versions by August 9. We understand some of you still want to see your friends and family on a map, which is why we've added location sharing and check-ins to Google+ for Android (coming soon to iOS). More details about Latitude and check-in changes can be found in our help center.
Astu ;)
EDIT: August 9, 2013
  • GoT
GoT
/ / ( . Y . ) \ \
I don't get it:
Het is op 09 augustus al gestopt.
Maar het heeft al die tijd bij mij gewerkt, tot de update van vorige week donderdag/vrijdag.
Hebben we het wel over zelfde ?
[ Voor 10% gewijzigd door GoT op 14-07-2013 15:15 ]
  • Strunkie
  • Laatst online: 21:38
Strunkie
> Post is rechts!
Kom je grot eens uit en check de datum van vandaag -.-
^ Post is hierboven!
  • reyals
  • Laatst online: 18-07 00:04
En als je kunt lezen staat er dat latitude in de nieuwe versie is verwijderd, en vanaf 9 augustus ook niet meer werkt in de oude versies waar het nog wel in zit
Samsung Note 4 (Omegarom V4, android 6.0.1) Samsung Galaxy Note 3, Android 5.0 lollipop alexndr devbase (custom rom)/Asus transformer tab TF300T, Katkiss Nougatella 7.1.2
  • GoT
GoT
/ / ( . Y . ) \ \
Dan moet je eerst weten hoe dat heet.
In Google Maps was het gewoon een knopje: "History".
De referentie naar "Latitude" is niet snel gemaakt.
