[SBS2011] Windows SBS Console crasht bij opstarten
  • evan_nl
  • Laatst online: 16-11-2025
Goedemiddag,
Na eigenlijke en beetje ten einde raad te zijn post ik hier mijn probleem met de Console op SBS 2011. Zodra de Window SBS Console wordt geopend stopt deze met de melding:
Event log:
Faulting application name: console.exe, version: 6.1.7900.1, time stamp: 0x4ce6d9cf
Faulting module name: KERNELBASE.dll, version: 6.1.7600.17206, time stamp: 0x50e669a2
Exception code: 0xe0434352
Fault offset: 0x000000000000ac3d
Faulting process id: 0x33a4
Faulting application start time: 0x01ce6818ae60bf85
Faulting application path: C:\Program Files\Windows Small Business Server\Bin\console.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: f3ce42d4-d40b-11e2-87c9-bc305be5dba4
- System
- Provider
[ Name] Application Error
- EventID 1000
[ Qualifiers] 0
Level 2
Task 100
Keywords 0x80000000000000
- TimeCreated
[ SystemTime] 2013-06-13T09:30:58.000000000Z
EventRecordID 30078
Channel Application
Computer SERVERXXX.DOMEINXXX.local
Security
- EventData
console.exe
6.1.7900.1
4ce6d9cf
KERNELBASE.dll
6.1.7600.17206
50e669a2
e0434352
000000000000ac3d
33a4
01ce6818ae60bf85
Console.log:
[7312] 130613.110609.8411: General: Initializing...C:\Program Files\Windows Small Business Server\Bin\console.exe
[7312] 130613.110612.6404: General: Console shown...
[7312] 130613.110623.8855: Admin: !!!!FATAL: Console shutting down due to unhandled exception: Initialization failed.
[7312] 130613.110623.9005: Exception:
An exception of type 'Type: System.IO.IsolatedStorage.IsolatedStorageException, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' has occurred.
Timestamp: 06/13/2013 11:06:23
Message: Initialization failed.
Stack: at System.IO.IsolatedStorage.IsolatedStorageFile.Init(IsolatedStorageScope scope)
at Microsoft.WindowsServerSolutions.Console.Common.Persistance.IsolatedMementoStorage.Contains(String id)
at Microsoft.WindowsServerSolutions.Console.Pages.Page.LoadMementoCache(Guid guid, MementoStorage storage)
at Microsoft.WindowsServerSolutions.Console.Pages.Page.LoadCache()
at Microsoft.WindowsServerSolutions.Console.Pages.Home.Home.Initialize()
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Application.ThreadContext.System.Windows.Forms.UnsafeNativeMethods.IMsoComponent.FDoIdle(Int32 grfidlef)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at Microsoft.WindowsServerSolutions.Console.Program.Main(String[] args)
Ik heb al een flink aantal dingen geprobeerd, zoals:
-Een "repair" van de console uitvoeren, daarnaast ook console is safemode opstarten en elke page stuk voor stuk gedisabled om te testen maar console blijft crashen. zie: http://technet.microsoft.com/en-us/library/gg680337.aspx
-Opnieuw SBS monitoring database aangemaakt. http://blogs.technet.com/...smonitoring-database.aspx
-Gecheckt op oude computers in AD, WSUS herinstall. http://kb.itimpulse.in/?p=2413
-Verder nog wat dingen geprobeerd zoals redirect folders uit voor admin account, registeren cleaner, alles geupdate, updates teruggedraaid.
Wie kan mij verder op weg helpen dit probleem te tackelen? Alvast bedankt!
  • marc181982
  • Laatst online: 26-01 12:56
-Maak eens een 2e admin account en probeer het daar mee. Het admin account even in een ander OU zetten en de policies 'blocken'
-dotnet fix al geinstalleerd?
edit : vermoeden is dat de appdata locatie in het register verkeerd staat
Check
Registry Settings for Folder Redirection in Windows
Registry Settings for Folder Redirection in Windows - (HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell) - - Corrected Name: AppData - Type: REG_EXPAND_SZ - Data: This should not be on shared location should be something like %USERPROFILE%\Application Data
[ Voor 61% gewijzigd door marc181982 op 18-06-2013 12:18 ]
  • The-Eagle_2007
  • Laatst online: 09:35
Wellicht is tijdens een eerdere update de Windows Management Foundation 3.0 geïnstalleerd
KB 2506143
Deze zorgt er ook voor dat de SBS Console crashed
Via Add/Remove Programs kan je deze update deinstalleren.
Deze update word ondertussen niet meer aangeboden via de windows update
Bla Bla Bla
  • Orthodroom
Ik zit met hetzelfde probleem? :(
Heb je dit ooit nog weten op te lossen?
  • Vorkie
Ik ken dit van een te nieuwe internet explorer...
Toevallig geupdate van de week?
  • Orthodroom
Nee, het is opgetreden na een installatie van de virusscanner die ik heb moeten afbreken omdat het vastliep.
Maar ik heb het toevallig net wezen op te lossen.
Er stonden een paar register instellingen niet goed in:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
De padnamen waren niet correct.
Hierdoor waren er o.a. ook problemen met Powershell.
In een klap van 3 lastige problemen af :D
