  • Parzival
  • Laatst online: 07-05 14:37
Hoi,
Is er iemand die heeft geprobeerd om Windows Server 2012 te installeren op een IBM x366?
de processoren zouden goed moeten zijn..
maar ik dacht laat ik even vragen voor ik eraan begin..
_R
Intel(R) Xeon(TM) MP CPU 3.66GHz
Intel64 Family 15 Model 4 Stepping 1, GenuineIntel
HTT * Hyperthreading enabled
HYPERVISOR - Hypervisor is present
VMX - Supports Intel hardware-assisted virtualization
SVM - Supports AMD hardware-assisted virtualization
EM64T * Supports 64-bit mode
SMX - Supports Intel trusted execution
SKINIT - Supports AMD SKINIT
NX * Supports no-execute page protection
SMEP - Supports Supervisor Mode Execution Prevention
SMAP - Supports Supervisor Mode Access Prevention
PAGE1GB - Supports 1 GB large pages
PAE * Supports > 32-bit physical addresses
PAT * Supports Page Attribute Table
PSE * Supports 4 MB pages
PSE36 * Supports > 32-bit address 4 MB pages
PGE * Supports global bit in page tables
SS * Supports bus snooping for cache operations
VME * Supports Virtual-8086 mode
RDWRFSGSBASE - Supports direct GS/FS base access
FPU * Implements i387 floating point instructions
MMX * Supports MMX instruction set
MMXEXT - Implements AMD MMX extensions
3DNOW - Supports 3DNow! instructions
3DNOWEXT - Supports 3DNow! extension instructions
SSE * Supports Streaming SIMD Extensions
SSE2 * Supports Streaming SIMD Extensions 2
SSE3 * Supports Streaming SIMD Extensions 3
SSSE3 - Supports Supplemental SIMD Extensions 3
SSE4.1 - Supports Streaming SIMD Extensions 4.1
SSE4.2 - Supports Streaming SIMD Extensions 4.2
AES - Supports AES extensions
AVX - Supports AVX intruction extensions
FMA - Supports FMA extensions using YMM state
MSR * Implements RDMSR/WRMSR instructions
MTRR * Supports Memory Type Range Registers
XSAVE - Supports XSAVE/XRSTOR instructions
OSXSAVE - Supports XSETBV/XGETBV instructions
RDRAND - Supports RDRAND instruction
RDSEED - Supports RDSEED instruction
CMOV * Supports CMOVcc instruction
CLFSH * Supports CLFLUSH instruction
CX8 * Supports compare and exchange 8-byte instructions
CX16 * Supports CMPXCHG16B instruction
BMI1 - Supports bit manipulation extensions 1
BMI2 - Supports bit maniuplation extensions 2
ADX - Supports ADCX/ADOX instructions
DCA - Supports prefetch from memory-mapped device
F16C - Supports half-precision instruction
FXSR * Supports FXSAVE/FXSTOR instructions
FFXSR - Supports optimized FXSAVE/FSRSTOR instruction
MONITOR * Supports MONITOR and MWAIT instructions
MOVBE - Supports MOVBE instruction
ERMSB - Supports Enhanced REP MOVSB/STOSB
PCLULDQ - Supports PCLMULDQ instruction
POPCNT - Supports POPCNT instruction
SEP * Supports fast system call instructions
LAHF-SAHF - Supports LAHF/SAHF instructions in 64-bit mode
HLE - Supports Hardware Lock Elision instructions
RTM - Supports Restricted Transactional Memory instructions
DE * Supports I/O breakpoints including CR4.DE
DTES64 * Can write history of 64-bit branch addresses
DS * Implements memory-resident debug buffer
DS-CPL * Supports Debug Store feature with CPL
PCID - Supports PCIDs and settable CR4.PCIDE
INVPCID - Supports INVPCID instruction
PDCM - Supports Performance Capabilities MSR
RDTSCP - Supports RDTSCP instruction
TSC * Supports RDTSC instruction
TSC-DEADLINE - Local APIC supports one-shot deadline timer
TSC-INVARIANT - TSC runs at constant rate
xTPR * Supports disabling task priority messages
EIST * Supports Enhanced Intel Speedstep
ACPI * Implements MSR for power management
TM * Implements thermal monitor circuitry
TM2 * Implements Thermal Monitor 2 control
APIC * Implements software-accessible local APIC
x2APIC - Supports x2APIC
CNXT-ID * L1 data cache mode adaptive or BIOS
MCE * Supports Machine Check, INT18 and CR4.MCE
MCA * Implements Machine Check Architecture
PBE * Supports use of FERR#/PBE# pin
PSN - Implements 96-bit processor serial number
PREFETCHW - Supports PREFETCHW instruction
Logical to Physical Processor Map:
**------ Physical Processor 0 (Hyperthreaded)
--**---- Physical Processor 1 (Hyperthreaded)
----**-- Physical Processor 2 (Hyperthreaded)
------** Physical Processor 3 (Hyperthreaded)
Logical Processor to Socket Map:
**------ Socket 0
--**---- Socket 1
----**-- Socket 2
------** Socket 3
Logical Processor to NUMA Node Map:
******** NUMA Node 0
Logical Processor to Cache Map:
**------ Data Cache 0, Level 1, 16 KB, Assoc 8, LineSize 64
**------ Unified Cache 0, Level 2, 1 MB, Assoc 8, LineSize 128
--**---- Data Cache 1, Level 1, 16 KB, Assoc 8, LineSize 64
--**---- Unified Cache 1, Level 2, 1 MB, Assoc 8, LineSize 128
----**-- Data Cache 2, Level 1, 16 KB, Assoc 8, LineSize 64
----**-- Unified Cache 2, Level 2, 1 MB, Assoc 8, LineSize 128
------** Data Cache 3, Level 1, 16 KB, Assoc 8, LineSize 64
------** Unified Cache 3, Level 2, 1 MB, Assoc 8, LineSize 128
Logical Processor to Group Map:
******** Group 0
Geef me ff wat spatie...: MCM: Directory Services Windows 2008
