Helium is the missing app sync and backup solution for Android. Helium does NOT require root. All Android users can use Helium to backup and sync Android applications. Helium lets you backup your apps and data to your SD card or cloud storage. With Helium, you can sync app data from your other Android devices-- even if they are not on the same network. Set up backup schedules with Helium, and never lose data again. Helium Setup 1. Install Helium on Android a) Root user? You're done! 2. Install and run Helium Desktop (link below) 3. Connect Android to computer. a) You may need to set your USB Connection Mode to "PTP". (Nexus 7, Nexus 10, etc) 4. Helium on Android should now be enabled . Helium (Free) features: Backup and restore to SD card Backup and restore from PC Helium (Premium) features: No ads Automatic Backup schedules Android to Android sync Cloud backup and restore * Dropbox * Box * Google Drive Note: Helium is NOT available to Motorola devices. Note: Some Sony devices have issues with Helium. This includes the Xperia S and Xperia Z. Waar te downloaden: Op de website: http://download.clockworkmod.com/apks/Backup.apk Via Google Play: Google Play: Helium - App Sync and Backup Helium Desktop Installer: http://www.clockworkmod.com/carbon Zijn er al Tweakers met ervaringen met deze backup-applicatie van de makers van ClockWorkMod? Ik heb net de free-versie geïnstalleerd en ben nu wat backups aan het maken. Straks even m'n telefoon resetten en kijken hoe snel en hoe goed het werkt! En even door de settings heen struinen, ziet er ansich allemaal wel goed uit! Topicreeks: Android Software & Discussie |
