• SvenG
  • Laatst online: 27-01 10:56
HI,
sinds medio DEC 2012 heb ik deze BR player in huis. Aangezien ik al jaren geen dvd speler meer had gebruikt omdat ik via mn PC films keek, was ik helemaal de ellende met Regio's vergeten
Nu heb ik BluRay discs in huis die niet Regio 2 zijn en die kan ik nu niet bekijken vanwege dat irritante Cinavia (audio muted)
Weet iemand hoe ik dit ding regio vrij kan maken ?
Ik heb deze methode geprobeerd , echter zonder succes
[i][i][i][i]
Region code hack posted by BradO74, May 12 2012:
**NOTE** this was done with the following:
Firmware : 2012/02/02_001005
Remote : AK59-00148A
1. Ensure that there is no disk in the tray.
2. Switch the player off and then back on. This is necessary to clean-boot the
firmware.
3. Wait until the main menu page appears and the player stops doing
anything.
4. Press the eject button on your remote to open the tray.
5. Press the eject button on your remote to close the tray.
6. As soon as the "No Disk" message appears at the top left corner do the following.
8. Press the STOP button (the square symbol)
9. Enter 76884 on the number pad.
10. The region code "4" should appear at the top left corner of the screen.(this just flashed on then off, so keep an eye on the screen)
11. Enter a "9" to make the player region free.
12. Power down and power up again.
13. Play a foreign DVD to verify the change.
Firstly, you must start entering the code just after the "No Disk" message is shown and before the message disappears.
Secondly, the STOP key is part of the code. All six keys must be entered smoothly as "STOP 76884". The entry gets timed out so you can't stop in the middle and restart.
If you don't see the "4" the first time, don't worry. Just start from step 4 again (took me 2 goes to get it, it is all about the timing)
For people from other parts of the world, all region codes are as follows
1 – 2 9 3 3 4
2 – 5 7 5 3 8
3 – 5 6 7 3 2
4 – 7 6 8 8 4
5 – 5 3 8 1 4
met een gepatchte Firware zou ik ook geholpen zijn ;-)
BVD Sven
  • mr.paaJ
  • Laatst online: 02-10 19:32
mr.paaJ
generatie cmd+z
Die methode is voor DVD, BR is een stuk lastiger en zal hardwarematig gemod moeten worden. Speler importeren uit de VS is waarschijnlijk goedkoper, of als het slechts een paar films zijn: opnieuw kopen
liever de tong gebrand dan lauwe soep
  • SvenG
mr.paaJ schreef op vrijdag 17 mei 2013 @ 11:09:
OK thanks, ik zag dat er philips BR palyers v rond de 100E zijn, die maar ns proberen
  • SvenG
*SLOTJE*
