Installeren van Exchange 2013 lukt niet
  • Isane
  • Laatst online: 01:32
Ik probeer Exchange 2013 te installeren op Windows Server 2012. Ik heb Prerequisites uitgevoerd
Setup /IAcceptExchangeServerLicenseTerms  /PrepareSchema
Setup /IAcceptExchangeServerLicenseTerms  /PrepareAD /OrganizationName:Domeinnaam
Setup /IAcceptExchangeServerLicenseTerms  /PrepareAllDomains
Als ik vervolgens Exchange ga installeren komt tijdens de installatie de volgende melding naar voren:
Error:
The following error was generated when "$error.Clear();
if ($exsSid -eq $null -or $exsSid -eq "")
$exsSid = get-ExchangeServerGroupSID -DomainController $RoleDomainController
start-setupservice -ServiceName MSExchangeADTopology -ServiceParameters $exsSid,$RoleDomainController
" was run: "Service '' isn't installed on this server.".
Weet iemand hoe dit probleem op te lossen is?
Stukje uit een log file:
[05/12/2013 14:46:20.0905] [2] [ERROR] Service '' isn't installed on this server.
[05/12/2013 14:46:21.0130] [2] Ending processing start-setupservice
[05/12/2013 14:46:21.0189] [1] The following 1 error(s) occurred during task execution:
[05/12/2013 14:46:21.0238] [1] 0. ErrorRecord: Service '' isn't installed on this server.
[05/12/2013 14:46:21.0238] [1] 0. ErrorRecord: Microsoft.Exchange.Configuration.Tasks.ServiceNotInstalledException: Service '' isn't installed on this server.
at Microsoft.Exchange.Configuration.Tasks.Task.WriteError(Exception exception, ErrorCategory category, Object target, Boolean reThrow, String helpUrl)
at Microsoft.Exchange.Configuration.Tasks.Task.WriteError(Exception exception, ErrorCategory category, Object target)
at Microsoft.Exchange.Management.Tasks.ManageSetupService.StartService(ServiceController serviceController, Boolean ignoreServiceStartTimeout, Boolean failIfServiceNotInstalled, Unlimited`1 maximumWaitTime, String[] serviceParameters)
at Microsoft.Exchange.Management.Tasks.ManageSetupService.StartService(String serviceName, Boolean ignoreServiceStartTimeout, Boolean failIfServiceNotInstalled, Unlimited`1 maximumWaitTime, String[] serviceParameters)
at Microsoft.Exchange.Management.Tasks.StartSetupService.InternalProcessRecord()
at Microsoft.Exchange.Configuration.Tasks.Task.ProcessRecord()
[05/12/2013 14:46:21.0264] [1] [ERROR] The following error was generated when "$error.Clear();
[05/12/2013 14:46:21.0264] [1] [ERROR] Service '' isn't installed on this server.
[05/12/2013 14:46:21.0265] [1] [ERROR-REFERENCE] Id=AllADRolesCommonServiceControl___e95681b135f04f6ca85c706536bfbeed Component=EXCHANGE14:\Current\Release\Shared\Datacenter\Setup
Ik heb zelf het internet al geraadpleegd maar ik kom helaas niet verder.
Wel heb ik zelf IPv6 al een keer opnieuw aangevinkt (met herstarts)
Ik kan zelf niks uit de logfiles halen.
Alvast bedankt!
[ Voor 99% gewijzigd door Verwijderd op 12-05-2013 18:16 . Reden: nee, toch niet. ]
  • FreestyleFrl
  • Laatst online: 13-10 22:08
Ik neem aan dat je de server waarop je dit probeert de functie domeincontroller hebt gegeven? je melding geeft volgens mij aan dat dit niet het geval is.
  • Turdie
  • Laatst online: 20-04 14:54
Is je account waarmee je installeert lid van de Domain Admins,Enterprise Admins en de Schema Admins groep?
[ Voor 14% gewijzigd door Turdie op 12-05-2013 18:23 ]
  • Isane
FreestyleFrl schreef op zondag 12 mei 2013 @ 18:21:
Jep, op deze server draait een DC + DNS + DHCP
shadowman12 schreef op zondag 12 mei 2013 @ 18:22:
Ik heb het nagekeken, ja de gebruiker (Administrator) is lid van de groepen.
Ik heb ook nog even naar DNS gekeken, nslookup werkt zowel forward als reverse
[ Voor 6% gewijzigd door Isane op 12-05-2013 18:42 ]
  • Turdie
  • Isane
Hmm, ja dan houdt het verhaal hierbij op denk ik. In ieder geval bedankt voor alle reacties :)
  • Jazzy
  • Laatst online: 20:44
Jazzy
Moderator SSC/PB/AI
Moooooh!
Hohoho, niet zo snel. :) Het installeren van Exchange op een Domain Controller is al jaren niet aanbevolen maar wordt wel ondersteund. Als je de beperkingen of nadelen begrijpt en die voor jou opwegen tegen de alternatieven dan moet dit gewoon werken. Dus als je dit wilt dan kunnen we het gewoon troubleshooten.
Wil je de volledige output van ipconfig /all eens posten? En als je bij de services kijkt, staat Microsoft Exchange Active Directory Topology er dan tussen?
  • Killah_Priest
  • Laatst online: 10-10 22:29
Ik kreeg exchange 2013 zonder problemen werkend op een 2012 dc.
[ Voor 2% gewijzigd door Killah_Priest op 13-05-2013 20:46 . Reden: typo aangepast ]
  • Isane
Ik krijg momenteel wat meer problemen met de installatie, eerst die problemen oplossen. Moment!
  • Razwer
  • Laatst online: 17-09 21:20
powershell execution policy op unrestricted staan?
setup wel gestart als admin? UAC uitzetten op 2012 werkt niet altijd even goed (moet je vaak nog registry aanpassing voor doen).
Error:
lijkt op UAC issue.
Newton's 3rd law of motion. Amateur moraalridder.
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
Waarom denk je dat? Zou je dan niet een Access denied verwachten?
  • Isane
Error:
if ($RoleStartTransportService)
start-SetupService -ServiceName FMS
" was run: "Service 'FMS' failed to reach status 'Running' on this server.".
Als ik google kom ik deze solution tegen: http://www.howexchangewor...port-failed-to-reach.html
Uitvoeren? of hebben jullie een andere optie?
EDIT: Het lijkt erop dat ik de volgende commando's vergeten ben: Import-Module ServerManager
Add-WindowsFeature RSAT-ADDS
Nu ben ik bezig om de installatie opnieuw te laten lopen
[ Voor 20% gewijzigd door Isane op 15-05-2013 12:28 ]
  • Razwer
Jazzy schreef op dinsdag 14 mei 2013 @ 21:17:
omdat ik in Server 2012 nog wel gekkere dingen ben tegen gekomen maar idd access denied zou het meest voor de hand liggend zijn.
  • Jazzy
Jazzy
Moderator SSC/PB/AI
Moooooh!
MarkoAlmelo schreef op dinsdag 14 mei 2013 @ 23:43:
Die link beschrijft een ander issue.
RSAT-ADDS staat als het goed is al op je server omdat het een domain controller is. Deze wordt trouwens alleen gebruikt om je domein te preparen als dit de eerste Exchange 2013 server is, niet voor de daadwerkelijke installatie van Exchange.
  • Isane
Jazzy schreef op woensdag 15 mei 2013 @ 20:18:
Ik snap er vrij weinig meer van waarom ik niet door de installatie kom :(
Ik installeer een DC, DHCP en DNS. Alles werkt naar behoren maar Exchange installeren..hoo maar.
aangezien het toch maar een test machine is, laat ik het ff voor wat het is.
Ik pak het later weer op :Y
  • Newjersey
  • Laatst online: 03-10 15:18
Heb je de RTM versie of CU1? Ik had ook problemen met het installeren van de RTM versie, de CU1 versie deed het wel gewoon goed :)
