Intel garantie op tray processors
  • Monochrome
  • Laatst online: 22-10 15:40
Ik heb een i7 3770 tweedehands gekocht. Hij is voor zover ik kan zien nog nooit gebruikt, en ik wil nagaan of ik garantie heb. Na lang zoeken een ´warranty checker´ gevonden, maar de FPO en ATPO codes worden niet gevonden.. Daarna gaan chatten met een medewerker, die zegt dat ze geen garantie leveren op tray units.
Weet iemand of en hoe ik garantie kan krijgen op deze processor? Kan ik de CPU ergens registeren oid?
tldr, chatlog met die dude van Intel.. Hij leek zo aardig ;)
Intel: Please wait for a site operator to respond. You are now chatting with 'Deepak'
Deepak Hello. Thank you for using the Intel Customer Chat Support service. We are glad to be of service. How may I help you?
Wouter Bokslag Hello, I have a processor with FPO 32****51 and ATPO 2**2. It is a i7-3770, and your product warranty checker fails to find it.
Wouter Bokslag I just wanted to make sure it is covered by intel warranty
Deepak I understand that you need to check the warranty status of your Intel processor.
Wouter Bokslag indeed, just want to make sure
Deepak I will be happy to assist you with the query.
Wouter Bokslag thank you
Deepak You are most welcome.
Deepak Before proceeding further, may I know if this is the first time you are contacting Intel® Technical Support?
Wouter Bokslag yes, this is the first time. However I have another CPU for which I´d also like to verify, but it is currently in my PC so i´ll have to do that another time i guess yes, this is the first time. However I have another CPU for which I´d also like to verify, but it is currently in my PC so i´ll have to do that another time i guess
Deepak I see.
Wouter Bokslag this chat is glitchy.. apologies for weird replies ahem
Deepak Since you are interacting with Intel® for the first time, we need to create your profile with our database for an easier and smoother communication.
Wouter Bokslag ok
Deepak Please stay online for 2 minutes, while I create a profile and check the warranty details for you.
Wouter Bokslag ok thank you
Wouter Bokslag is there any way to find FPO and ATPO without taking out the CPU
Deepak Yes, the FPO number and ATPO number will on the CPU box.
Deepak Please stay online for 2 minutes, while I check the warranty details for you.
Wouter Bokslag ok
Deepak Thank you for staying online, I appreciate your patience.
Wouter Bokslag no problem I didn´t expect an answer so soon anyway
Deepak Wouter, may I have the complete ATPO number? Are you able to see 12,13 or 14 characters towards the edge of your processor?
Wouter Bokslag on the pcb I suppose, let me look.
Deepak Ok.
Wouter Bokslag I´m sorry there is nothing else
Wouter Bokslag just a 2d barcode
Deepak It is fine. Could you please check whether FPO number: 32****1 is correct?
Wouter Bokslag it is correct. It is the last line on the heat spreader, below ´costa rica´, and behind it there is a circle with ´e4´ inside.. but I doubt this has anything to do with the FPO number
Deepak Thank you for confirming.
Deepak I am sorry to inform you that I could not validate the details provided by you. Since you have contacted Intel technical support team, we will not be able to create an order or check the warranty status right now. However I can escalate this case to the concerned team and your local Intel support team will contact you within 24-48 working hours.
Wouter Bokslag Is it possible you can´t find the details because it *might* be an OEM processor or is that not a possible scenario
Deepak May I know the manufacturer of your computer?
Wouter Bokslag It is custom built
Deepak Wouter, may I know whether you have purchased i7-3770 as a separate boxed unit?
Wouter Bokslag it was not boxed, it was a tray processor
Wouter Bokslag but new and unused, for as far as I could judge
Deepak Wouter, I am sorry to inform you that we are from Intel desktop support for boxed units and we will not support tray units.
Wouter Bokslag ok. Is there anywhere else where I can find out the warranty status about this processor
Deepak OEM's configure Intel products and they have different hardware and firmware environment. Intel sells processors, motherboards, and other products via Retail and Wholesale channels. Retail products are sold in clearly marked individual boxes and carry a warranty directly from Intel. Wholesale products are not sold in retail boxes and are typically pre-installed by a system manufacturer (ex. HP*, Dell*, Gateway*) or reseller. Intel does not provide direct warranty support for wholesale products.
Deepak In order to get the exact information regarding warranty for this product, you need to contact your computer manufacturer.
Wouter Bokslag I am sorry, but one can purchase tray processors from regular webshops. Who should I contact, my pc is built by myself..
Deepak I have not escalated this case since you are using a Tray unit. I would request you to check with your reseller to find warranty details of your processor.
Deepak Please contact the person or the place from where you have purchased this unit.
Wouter Bokslag All right, I´ll try that
Wouter Bokslag thank you for your time
Deepak Is there anything else I can assist you with?
Deepak Thank you for using chat. We value your suggestions and would appreciate it if you would take a moment to complete our survey. The survey will appear when you click "Close'' to close the chat window. If you are satisfied with our support, please score items where applicable with a 4 or 5 in the online survey. We will value your feedback and we will use it to make our services better.
Deepak Thank you for using Intel® Products and Services. Have a nice day.
Intel: Chat session has been terminated by the site operator.
Intel: Sorry, agents are not available right now.
  • Ultraman
  • Laatst online: 29-10 22:33
Ultraman
Boefje
Volgens mij is dit topic meer voor het idee van "stel dat ik het nodig heb"?
Want je hebt een werkende processor op het moment?
Daarnaast heb ik nog nooit een CPU stuk gehad, en nooit iets van garantie hoeven claimen. Zolang je die dingen met respect behandeld gaat het eigenlijk altijd goed. Dus een echt antwoord heb ik ook niet.
[ Voor 11% gewijzigd door Ultraman op 08-05-2013 12:43 ]
  • LiquidT_NL
  • Laatst online: 17-06 08:19
Van wat ik er van weet, is het inderdaad zo geregeld vanuit de fabrikanten. OEM processoren zijn voor OEM's. Intel kan dan ook die garantie plicht afwimpelen. Op de een of andere manier worden die dingen alsnog hier verkocht, maar je garantie loopt dan ook via de winkel: dan zul je weinig merken van wat Intel er mee doet.
Maar je vraag is dus of je nu wel of geen garantie hebt, en hoe je er aan komt. Wat heb je zelf al gevonden? Dit staat gewoon op de site van Intel namelijk, waar zou jij je product willen registreren?
De enige die je kan helpen is degene van wie je hem hebt gekocht, die winkelfactuur kun je meenemen. Algemeen consumentenrecht is ook hier van toepassing (wat je ook terug kan vinden op verschillende sites).
Explorers in the further regions of experience...demons to some, angels to others.
  • Monochrome
Ok, bedankt voor de info. Ik heb gezocht op de site, waar je kan registreren, maar dat lukt niet voor tray. Dit was al min of meer wat ik verwachtte, weet ik in elk geval waar ik aan toe ben!
Groet,
Wouter
  • dion_b
  • Laatst online: 22:28
dion_b
say Baah
Dit heeft niets met techniek te maken.
Move PMG -> Shopping Forum
Verder zit je op de verkeerde plek te kijken voor garantie. Volgens NL recht is je leverancier verantwoordelijk voor je garantie en verder niemand. Wat de leverancier allemaal achter de schermen regelt met fabrikant, importeur, distributeur of Sinterklaas is jouw probleem niet. Leverancier moet een deugdelijk product leveren die een redelijke tijd meegaat.
Oslik, blyat! Oslik!
