Nieuwe Sony Fit serie - hopelijk naar NL?
  • floepie05
  • Laatst online: 29-03 20:39
Wat specs voor z'n prijs!
14" or 15" screen
svelte uiterlijk - zwart, rose, wit
aluminium
FHD 1920x1080 aanraakscherm
Hybrid Drive
Verlichting toetsenbord
Verkrijgbaar met dedicated gfx card.
Onder de $700!
Dit is voor de "Fit" model en niet de "Fit E".
http://www.theverge.com/2...ineup-entry-level-laptops
http://reviews.cnet.com/s.../4505-5_7-35757138-2.html
[ Voor 24% gewijzigd door floepie05 op 07-05-2013 11:25 ]
  • Gandalf
  • Laatst online: 22:27
Eerste test van de 14": http://www.laptopmag.com/...oks/sony-vaio-fit-14.aspx
Pros: Elegant and attractive chassis; Sharp 1600 x 900 touch screen; Solid performance and graphics; Robust software bundle
Cons: Shallow keyboard feedback; Below-average battery life; Narrow viewing angles
The Verdict: The Sony VAIO Fit 14 offers an attractive design, sharp screen and solid performance, but it suffers from subpar battery life.
En van de 15": http://www.notebookreview..._VAIO_Fit_Review+notebook
Pros:
Stylized design
Vibrant touch-enabled display
Comfortable keyboard
Cons:
No SSD
Poor battery life
[ Voor 21% gewijzigd door Gandalf op 07-05-2013 12:13 ]
  • JustwilliamNL
  • Laatst online: 17-10 05:09
Spring is here, which means it's high time that Sony refreshed its laptop line for the cool kids in Japan. The company is talking up a quartet of new VAIOs including the previously-reviewed Duo 11 as well as the unfamiliar trio of the VAIO Fit 15E, Fit 14 and Fit 15. Delving deep into that last model, the 22.5mm-thick unit comes with a 1,920 x 1,080 touchscreen display and runs the 64-bit version of Windows 8 on a 2GHz Intel Core i7-3537U CPU. Look deeper and you'll find 8GB RAM, Intel HD Graphics 4000, 1TB of hybrid storage as well as 802.11 b/g/n WiFi, NFC and an Exmor R webcam. The various models will filter into Japanese stores between May 18th and June 1st, with the stock Fit 15 setting you back 180,000 yen ($1,818).
Bron: http://www.engadget.com/2...sic&utm_campaign=Engadget
Waarschijnlijk zal in het 15' model de 2GHz Intel Core i7-3537U geplaatst zijn en het beeldscherm wordt aangestuurd door de IGP (HD4000). Ik denk dat het 14' model een iets minder krachtige processor krijgt in de U reeks, wellicht een i5-3337U of een I5-3317U ipv van een i7. Bij de 14' wordt het beeldscherm net zo goed aangestuurd door de IGP.
