<CPU ID: 000106A5 patch ID: 00000011> boot failure
  • Rolfski
  • Laatst online: 04-11-2025
Ik loop ineens tegen een opstartfout aan die of moederbord of SSD gerelateerd is en waar ik nog weinig info over heb kunnen vinden. Het hele rijtje in de Tweakers FAQ ben ik al afgelopen zonder resultaat. Ik kan niet opstarten "Boot failure..." en ik krijg een error in mijn bios menu: "<CPU ID: 000106A5 patch ID: 00000011>"
Onderstaand de beschrijving van mijn probleem zoals ik hem op buitenlandse forums heb gepost:
My system suddenly,out of nowhere, won't start anymore. It recognizes my Crucial M4 256 GB SSD but it won't boot. After "verifying DMI Pool Data" , I either get the "Boot failure, please insert system disk" message (when only M4 SSD connected) or some line with all kinds of random ASCI signs (when other hard drives are connected as well).
Immediately after start-up, right after CPU check, I also get the message "<CPU ID: 000106A5 patch ID: 00000011>"
Things I've done so far to solve the issue:
  • Changed Bios battery. It wasdefinitely empty but replacement didn' thelp.
  • Disconnected all devices except M4 SSD. See above, disconnecting other drives did change the error message after "verifying DMI Pool Data" but didn't help.
  • Disconnected all devices including M4 SSD. Still got the "<cpuid: 000106A5 patch ID: 00000011>" message
  • Checked all internal cable connections. No luck.
  • Checked/ changed all bios settings and loaded a back-up bios. No luck
  • Booted from Win7 64i nstallation disc, using "repair my computer". Start-up check couldn't find any Win7 installation or partition table.
  • Unplugged power, removed battery and did a CMOS reset, still the <cpuid: 000106A5 patch ID: 00000011> message
With above results taken into account, I have a suspicion that the CPU id patch id error might not be related to the boot failure of the M4. I still have no idea on how to proceed now though so some help will be appreciated.
Thks a lot in advance.
Btw, these are my system specs: http://nl.hardware.info/u...roductie-dj-ing-en-gaming
Weet iemand raad?
  • Nielson
  • Laatst online: 16:05
Al zo kaal mogelijk opgestart, dus alle overbodige pci/pci-e kaarten verwijderd en met een enkele geheugen module?
  • hcQd
  • Laatst online: 19:11
Die melding is informatief, geeft slechts aan dat de BIOS een microcodepatch heeft geïnstalleerd op je Core i7 CPU. Die stond er eerder ook al, maar is je nooit opgevallen.
  • Permutor
  • Laatst online: 02-03-2022
CMOS resetten. Standaard waarden kiezen.
  • Rolfski
Nielson schreef op zondag 28 april 2013 @ 10:09:
Ogestart met alleen videokaart en geheugenmodules (geheugen functioneert goed overigens).
hcQd schreef op zondag 28 april 2013 @ 10:12:
De melding is nieuw, geloof me maar of het met opstartproblemen te maken heeft ben ik niet zeker van.
Permutor schreef op zondag 28 april 2013 @ 10:13:
Heb ik gedaan met zowel optimized defaults als fail safe defaults.
  • Speedy-J
  • Laatst online: 02-11 13:56
Speedy-J
AMD Enthusiast
Misschien is het wel handig om je BIOS een update of downgrade te geven.
Ryzen 9 5950@4.7GHz|Asus prime X570 pro|32GB Corsair pro rgb ,2x XFX rx470rs black wolf ,Custom WC van EK|chietech dragon|Corsair 1000w rm x
  • DeTeraarist
  • Laatst online: 10:01
DeTeraarist
#Boots2Asses
Volgens mij is dit je probleem en heeft het niets met hardware te maken. Kijk eens met een partitiemanager of de juiste partities nog wel actief staan. Dat kan met linux live cds meestal wel, ook zijn er een aantal partitie managers die een cd aanbieden.
Soms, als ik heel stil ben, kan ik de zon horen schijnen
