================BASIC GESTURES =================
Swipe up when screen dark = unlock
Swipe up when on to peek at notifications and back to apps grid/home
Swipe up and to the right in a J = Hub notices
Swipe two fingers from bottom = keyboard
Swipe from top = settings
Swipe left to right (or right to left) = scroll through the available apps/screens
=========== NOTABLE FEATURES ===================
* Flow - everything is at your fingertips, all the ways you can communicate flow together
* Peek - simple swipe to see new communications & notices without leaving your current app
* Hub - centralized messaging center
* Learning Keyboard - the keyboard learns the patterns of how you write and helps you type faster (think Swiftkey)
* Sideloading Android apps - at launch BB has 100K+ apps thanks to it having the ability to run Android apps
* Time Shift Camera - instead of taking a single shot the camera takes a series and lets you pan to find the best shot
* Smart Calendar - suggests who to invite based on previous appointments
* Documents-To-Go and Print-to-Go Apps for creating, reading and prints docs like PowerPoint PPT, Excel XLS, Word DOC
* Micro HDMI Port - display PowerPoint presentations and videos on any HDMI device with a little adapter [[ASIN:B004286VMW Mediabridge Micro-HDMI to HDMI Cable with Ethernet - (6 Feet) - FLEX Series High Speed]]
* DLNA Support for streaming content to any compatible device
* MicroSD slot for expanded storage
=========== SETTING UP OUTLOOK INTEGRATION ===================
Sync
blogs.blackberry.com/2013/02/set-up-outlook-sync-with-blackberry-z10/
Import Only
helpblog.blackberry.com/2013/03/blackberry-link-import-outlook/
ActiveSync Setup
helpblog.blackberry.com/2013/03/connect-blackberry-10-to-mail-server/
Managing Contacts
helpblog.blackberry.com/2013/03/five-tip-friday-contacts/
=========== OTHER TIPS ===================
Change search engine: On the home screen, swipe down from the top of the screen. Tap Settings > Search.
Change browser search engine: Open up your web browser and start typing a search in the search. Up top in the right hand corner, you'll see the search logo. Tap it.
Take picture from lock screen: Tap and hold the camera icon on the bottom right
Take a Screenshot: Press both the Volume Up and Volume Down keys. Pics are saved to the camera folder.
Picture Blurry? Try stabilization mode. Select camera app, tap the [...] at the bottom, change the mode to "stabilization"
Want to try Time Shift Camera (great for group photos)? Select the camera app, tap the camera icon in the top corner, select the icon that looks like a face in a circle. Take a picture. If someone blinked, tap their face move the circular slider to a time when they weren't blinking then tap the check icon.
Batterij besparen :
- email ; gebruik geen pop maar imap
gmail op push zetten en je interval op 24 uur want deze is alleen nodig om berichten die
je bijvoorbeeld delete op je toestel ook wordt doorgezet. Kijk je toch nog regelmatig via de
computer en alleen 's avond dan kun je interval wel op 6 uur zetten.
- connection - NFC en Bluetooth uitzetten is goed maar NFC gebruikt niet veel.Het is meer bluetooth.
- Wifi zet iedereen uit maar zit je bij KPN/T-mobile en je hebt gratis hotspot dan zeg ik zet wifi
aan en zet 3G na 2G only gals je thuis ook gewoon Wifi hebt. 10-20% besparing op 24 uur.
- scherm : - zet scherm licht/brightness gewoon op 30% of 50% maar met dit jaargetijde en bewolking is 20%
wel voldoende.
- time out scherm op 10 of 20 seconden
- Apps : - locatie bepaling uitzetting
- facebook zet friends search uit
- whatsapp zet veel uit zoals inkijken en gebruik maken van sms,email etc.
- Kijk zo in de apps beheer wat er aan staat en wat uit kan
- Twitter is een batterij vreter en vraag je af of je dit nog wel gebruikt anders delete.
- Aktieve frames : uitzetten van frames vooral als die aktief zijn zoals het weer of nieuws welke elke
5 minuten worden ververst. Dit scheet ook weer batterij vermogen.
- Nacht modus : Heb je je toestel overdag niet nodig in een meeting doe dan een swipe naar beneden en
daarna weer een swipe naar beneden en kies nachtmodus. Via configuratie na de tweede
swipe kun je nog telefoontjes/sms aanzetten oproepen nachtkastje (erg zacht)
[ Voor 74% gewijzigd door Verwijderd op 13-04-2013 11:15 ]
  • Gtoniser
  • Laatst online: 22:27
Ik snap niet helemaal hoe die laatste werkt met de nacht modus? Swipe naar beneden waar? Op home screen? Dan krijg ik opties menu.
In lockscreen swipe naar beneden krijg je inderdaad die nacht modus met klok
Gtoniser schreef op zaterdag 13 april 2013 @ 11:57:
ja die met die klok :) thanks - tussen stap de klok en dan weer naar beneden swipen.
MUSIC PLAYER
Als je MP3 muziek op je Z10 zet en er verschijnt geen album cover dan kun je zelf een foto slepen naar de folder van je muziek. Hernoem de jpeg met de naam " Folder".
Als je nu weer terug gaat zie je dat je een album cover hebt.'
WIFI - ipv kabel op je pc/laptop.
Wist je dat je ook draadloos via een wifi netwerk je foto er af kan halen of via je laptop er muziek op kan zetten. Het is handig voor kleine bestanden. _/-\o_
[ Voor 90% gewijzigd door Verwijderd op 16-04-2013 23:06 ]
Keyboard :
Als je aan het typen bent en je hebt opeens abracadarba staan dan kun je met je vinger swipen van recht naar links op het toestenbord en je laatste woord gaat weg. Wil je twee woorden weg kun je ook twee vingers swipen.
Je kan ook een letter even ingedrukt houden voor Hoofdletter of een accent op de é bijvoorbeeld.
Bijlage
bij apps zoals facebook, whatsapp en zelfs email kun je een bijlgage toevoegen maar vaak zit je toetsenbord ervoor. Hou even net boven het toetsenbord waar je normaal je verhaal tikt even lang ingedrukt en je toetsenbord verdwijnt en ja daar staat het paperclip logo voor je bijlage's
TIP : Camera
Als je een foto maakt dan gaat deze foto naar de linker hoek en dan kun je daar op klikken en bekijken en ook naar je andere foto's kijken.
Maar je kan ook met je duim /vinger op dat kleine venster doen en dan sleep je met vinger naar de rechterhoek, zo zie de de laatste foto in het groot. je kan ook daarmee de foto kleiner en groter zien door te schuiven. laat je je vinger weer los van het scherm springt deze weer terug in zijn kadertje
Hierdoor hoef je de camera zelf niet te verlaten. Cool
  • Hjtel
  • Laatst online: 24-02-2024
Goed initiatief nlb, dit topic. Heb al diverse nuttige tips toegepast!! Ga door svp. Ik denk mee. :)
Waarvoor staat het blackberry logo'tje rechts in de bovenbalk eigenlijk?
Dat betekent dat de Blackberry is aangemeld op het BlackBerry netwerk, en dus bv. BBM werkt. Ik gebruik dit meer om te zien of de telefoon "internet" te pakken heeft. Want als je dat logotje ziet, weet je zeker dat internet werkt.
