kan xbmc niet opstarten (xbmcbuntu)
  • klen_ghost
  • Laatst online: 13-07 08:11
Mede-auteur:
  • earithramir84
  • Laatst online: 27-08-2025
earithramir84
als ik in ubuntu xbmc wil opstarten lukt het niet, start niet door.
volgende staat in de log :
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Fri Mar 29 22:01:22 CET 2013
XBMC Options:
Arch: i686
Kernel: Linux 3.7.0-7-generic #15-Ubuntu SMP Sat Dec 15 16:34:21 UTC 2012
Release:
Distributor ID: Ubuntu
Description: Ubuntu 12.10 - XBMCbuntu
Release: 12.10
Codename: quantal
############## END SYSTEM INFO ##############
############### STACK TRACE #################
gdb not installed, can't get stack trace.
############# END STACK TRACE ###############
################# LOG FILE ##################
22:01:19 T:3038394112 NOTICE: -----------------------------------------------------------------------
22:01:19 T:3038394112 NOTICE: Starting XBMC (12.1 Git:0d373cc), Platform: Linux (Ubuntu 12.10 - XBMCbuntu, 3.7.0-7-generic i686). Built on Mar 17 2013
22:01:19 T:3038394112 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
22:01:19 T:3038394112 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
22:01:19 T:3038394112 NOTICE: special://masterprofile/ is mapped to: /home/frank/.xbmc/userdata
22:01:19 T:3038394112 NOTICE: special://home/ is mapped to: /home/frank/.xbmc
22:01:19 T:3038394112 NOTICE: special://temp/ is mapped to: /home/frank/.xbmc/temp
22:01:19 T:3038394112 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
22:01:19 T:3038394112 NOTICE: Local hostname: mediacenterfrank
22:01:19 T:3038394112 NOTICE: Log File is located: /home/frank/.xbmc/temp/xbmc.log
22:01:19 T:3038394112 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
22:01:19 T:3038394112 NOTICE: Found 1 Lists of Devices
22:01:19 T:3038394112 NOTICE: Enumerated ALSA devices:
22:01:19 T:3038394112 NOTICE: Device 1
22:01:19 T:3038394112 NOTICE: m_deviceName : hdmi:CARD=HDMI,DEV=0
22:01:19 T:3038394112 NOTICE: m_displayName : HDA ATI
22:01:19 T:3038394112 NOTICE: m_displayNameExtra: HDMI
22:01:19 T:3038394112 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
22:01:19 T:3038394112 NOTICE: m_channels : FL,FR
22:01:19 T:3038394112 NOTICE: m_sampleRates : 48000
22:01:19 T:3038394112 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE
22:01:19 T:3038394112 NOTICE: load settings...
22:01:19 T:3038394112 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
22:01:19 T:3038394112 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:01:19 T:3038394112 NOTICE: loading special://masterprofile/guisettings.xml
22:01:19 T:3038394112 NOTICE: Getting hardware information now...
22:01:20 T:3038394112 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:01:20 T:3038394112 NOTICE: Loaded playercorefactory configuration
22:01:20 T:3038394112 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:01:20 T:3038394112 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:01:20 T:3038394112 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
22:01:20 T:3038394112 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
22:01:20 T:3038394112 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<useddsfanart>true</useddsfanart>
<cputempcommand>cputemp</cputempcommand>
<gputempcommand>gputemp</gputempcommand>
<samba>
<clienttimeout>30</clienttimeout>
</samba>
<network>
<disableipv6>true</disableipv6>
</network>
</advancedsettings>
22:01:20 T:3038394112 NOTICE: Getting hardware information now...
22:01:20 T:3038394112 NOTICE: Default DVD Player: dvdplayer
22:01:20 T:3038394112 NOTICE: Default Video Player: dvdplayer
22:01:20 T:3038394112 NOTICE: Default Audio Player: paplayer
22:01:20 T:3038394112 NOTICE: Disabled debug logging due to GUI setting. Level 0.
22:01:20 T:3038394112 NOTICE: Log level changed to 0
22:01:20 T:3038394112 NOTICE: Loading media sources from special://masterprofile/sources.xml
22:01:20 T:2970999616 NOTICE: Thread CSoftAE start, auto delete: false
22:01:20 T:3038394112 NOTICE: Running database version Addons15
22:01:20 T:3035220800 NOTICE: Thread XBMC Peripherals start, auto delete: false
22:01:20 T:3038394112 NOTICE: Previous line repeats 1 times.
22:01:20 T:3038394112 NOTICE: Setup SDL
22:01:21 T:3038394112 NOTICE: Checking resolution 16
22:01:21 T:3038394112 NOTICE: Using visual 0x14a
22:01:21 T:3038394112 NOTICE: GL_VENDOR = VMware, Inc.
22:01:21 T:3038394112 NOTICE: GL_RENDERER = Gallium 0.4 on llvmpipe (LLVM 3.2, 128 bits)
22:01:21 T:3038394112 NOTICE: GL_VERSION = 2.1 Mesa 9.2-devel
22:01:21 T:3038394112 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
22:01:21 T:3038394112 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_NV_primitive_restart GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_shader_texture_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_transform_feedback GL_ARB_invalidate_subdata
22:01:21 T:3038394112 ERROR: GLX: Same window as before, refreshing context
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
