Problemen Steam in Ubunte 12.04
  • Beerkiller
  • Laatst online: 20-09 10:01
Ik probeer Steam aan de praat te krijgen op mijn Ubuntu laptop
Alleen als ik hem via het commando: steam in de terminal probeer op te starten krijg ik het volgende:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
teus@teus-MS-1688:~$ steam
Running Steam on ubuntu 12.04 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1361807486_client)
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadRequest (invalid request code or no such operation)
Major opcode of failed request:  154 (GLX)
Minor opcode of failed request:  19 (X_GLXQueryServerString)
Serial number of failed request:  12
xerror_handler: X failed, continuing
Serial number of failed request:  41
Minor opcode of failed request:  14 (X_GLXGetVisualConfigs)
Serial number of failed request:  70
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2013-02-26 00:00:20] Checking for update on startup
[2013-02-26 00:00:20] Checking for available updates...
[2013-02-26 00:00:30] Download failed: http error 0
[2013-02-26 00:00:30] Error: Download failed: http error 0
[2013-02-26 00:00:30] Download complete.
[2013-02-26 00:00:30] Verifying installation...
unlinked 0 orphaned pipes
removing stale semaphore last operated on by process 3703 with name 0eBlobRegistryMutex_5A5B11089D196564C3E6AFF176DC2970
removing stale semaphore last operated on by process 3703 with name 0eBlobRegistrySignal_5A5B11089D196564C3E6AFF176DC2970
removing stale semaphore last operated on by process 3703 with name 0emSteamEngineInstance
removing stale semaphore last operated on by process 3703 with name 0eSteamEngineLock
[0226/000031:WARNING:proxy_service.cc(646)] PAC support disabled because there is no system implementation
Steam: An X Error occurred
Serial number of failed request:  34
Serial number of failed request:  63
Serial number of failed request:  92
Heeft iemand dit ook of heeft iemand een oplossing. Ik heb al meerdere dingen geprobeerd maar zonder suc6
  • Gropah
Gropah
Oompa-Loompa 💩
allereerst, voor dit soort dingen kun je het beste codeblocks gebruiken:
BBCode:
[code]
[/code]
Daarnaast zie ik veel X errors, dus hoe zit het met je videodrivers?
Also: wat heb je zelf al gedaan om het probleem op te lossen?
  • Beerkiller
Gropah schreef op dinsdag 26 februari 2013 @ 00:12:
BBCode:
[code]
[/code]
Heb geprobeerd om me grafische kaart opnieuw te installeren maar dat heeft niet geholpen en ik heb i386 libaries gedownload via apt-get. Ik moet zeggen dat ik best nieuw ben met ubuntu en linux opzich zelf dus weet ook eigenlijk niet wat ik precies heb gedaan.
  • lordgandalf
  • Laatst online: 13-10 16:23
heb geprobeerd dit uit te voeren via de run command applet want wat het waarschijnlijk is is dat je screen niet geset is en deze daardoor niet gevonden kan worden
Steam: Profile / Socialclub: Profile / Uplay: minedwarf / Origin: lordgandalf3
  • Beerkiller
Oke en hoe kan ik dat doen?
  • letatcest
letatcest
Freelanceredacteur
Kidult
Wat voor graka heb je? En kijk even bij de standaardinstellingen voor hardware drivers, zit rechtsboven in het menuutje onder het uit-teken. Kijk even of de grafische drivers zijn ingeschakeld.
die run-command applet krijg je door ALT-F2 te doen
[ Voor 12% gewijzigd door letatcest op 27-02-2013 22:45 ]
Schreef Cryptovaluta voor dummies, 3de druk in print | eBook-versie
  • Beerkiller
ik heb een ati/amd radeon m kaart uit de 5000 serie er inzitten
  • Hero of Time
  • Laatst online: 20-10 22:19
Hero of Time
Moderator LNX
There is only one Legend
En wat krijg je als je het volgende in een terminal typt (Menu > Accesoires > Terminal):
dpkg -l fglrx*
Commandline FTW
  • letatcest
letatcest
Freelanceredacteur
Kidult
die zou gewoon moeten werken met de automatische driverinstallatiemanier. Heb je al gekeken hoe het daarmee zit? Anders komen we natuurlijk nergens ;)
En natuurlijk even doen wat Hero of Time zegt.
[ Voor 14% gewijzigd door letatcest op 28-02-2013 14:15 ]
  • Beerkiller
Ik ben er nog niet aan toe gekomen omdat allemaal te proberen maar ga het van het weekend ff proberen. Alvast bedankt en ik laat wel ff weten of het werkt
  • FireWood
  • Laatst online: 20-10 22:33
Tip zet er 13.04 op. Werkt een stuk beter :)
Noobs don't use "F1", Pro's do, but they can't find the information they needed
