• Quad
Afbeeldingslocatie: http://i46.tinypic.com/35250di.jpg
Wat is WindowsAndroid?
WindowsAndroid is in feite niets meer dan Android 4.0.3 dat draait op een Windows Kernel.
Volgens de maker Socketeq draait het dus niet als een simulator maar for real en maakt het gebruik van de hardware waar het op draait.
Het doel van dit project is om Android zo goed mogelijk geschikt maken voor gebruik op jouw Windows PC!
Informatie van Socketeq
WindowsAndroid is a full porting of Android to MS Windows, with the goal to
extend Android’s application scope. Here is a snapshot of Android’s home
screen, when running as a Windows’ native application. It is cool, isn’t it?
Goals
  • Full porting
  • Keep Android’s all originalities, from UI to Dalvik virtual machine
  • High performance
  • Make use of Windows OS and hardware performance leverage, such as
    graphics hardware acceleration and high performance media codec.
Key technical points
  • OS adaption layer (OSAL) between Android and Windows
  • Android Framework/External projects porting
  • Hardware acceleration for Graphics subsystem
  • Dalvik VM porting and optimization
  • IPC (binder) porting and optimization
Features
  • current ported Android version is 4.0.3r1, new version is being developed
  • can run on Windows Vista, Windows 7 and Windows 8
  • has exactly the same user experience with the original Android
  • Integrated with Windows’ applications, such as Flash、Windows Media
    Player, etc.
  • supports any UI resolution, such as 1920x1080
  • supports windowing mode or full-screen mode, window scaling in
    windowing mode, and switching between windowing mode and full screen
    mode
  • supports IO devices such as mouse, keyboard, remote control
  • supports Ethernet, pppoe
Target application cases
  • High performance Android development tool
  • STB
  • Tablet
Screenshots
Afbeeldingslocatie: http://cdn.slashgear.com/wp-content/uploads/2013/01/apps.jpg
Afbeeldingslocatie: http://cdn.slashgear.com/wp-content/uploads/2013/01/game1.jpg
Afbeeldingslocatie: http://cdn.slashgear.com/wp-content/uploads/2013/01/wallpaper.jpg
Downloaden
Door datalimiet overschrijding van de website van Socketeq moet je gebruikmaken van beschikbare mirrors
Androidfilehost
Mega
Overigens is WindowsAndroid ook te vinden op Usenet.
Geïnstalleerd en dan?
Als je WindowsAndroid hebt geïnstalleerd dan kan je GAPPS erop zetten.
Van XDA overgenomen:
Install Gapps:
  1. Download gapps for ICS HERE.
  2. Unzip the gapps.
  3. Find the system folder that was unzipped, then go into the apps folder. Copy all of the apks
  4. Go to C:\SocketeQ\windowsandroid_root\system\apps
  5. Paste all of the apks in that directory.
  6. Restart Windowsandroid
  7. Enjoy gapps.
Note: You will now be able to add a Google account and get into Google Play but there is not really anything in the Play Store at this time.
Verder is het installeren van APPS niet mogelijk nog, het zou moeten kunnen eventueel dmv sideloaden, maar ook dit werkt (bij mij in elk geval) niet.
Het open zetten van 'unknown apps' is niet mogelijk daar de 'security' (settings -> security) pagina crasht.
Overig
WindowsAndroid is een leuk knutselwerkje waar zeker potentie in kan zitten (mits bepaalde dingen werken), echter zijn er te veel bugs die het eventueel het knutselen hiermee je kan laten staken.
Echter zijn er inmiddels aardig wat mensen die hieraan werken dmv hacks (build.prop editing) etc om in elk geval de PlayStore te laten werken.
topic in overleg met RoD hier laten plaatsen, mocht het niet wenselijk zijn mij daar even over informeren en verplaatsen naar juiste subforum :Y
Alles went behalve een Twent.
nggyu nglyd
