ASP.NET & MSExchange Error
Ik heb al geruime tijd enkele problemen in de EventLog staan, waar ik niet uit komt. Het gaat om een 2 tal errors en 1 warning.
Ik heb een Windows SBS 2011 Standaard domein opstaan, (inclusief Exchange 2010 SP2, en Sharepoin 2010 Foundation dus). Server is voorzien van alle meest recente updates.
Telkens verschijnen deze 3 meldingen onder elkaar. Deze komen elk uur terug.
WARNING:
Log Name: Application
Source: ASP.NET 2.0.50727.0
Date: 16-01-2013 17:01:26
Event ID: 1309
Task Category: Web Event
Level: Warning
Keywords: Classic
User: N/A
Computer: SRV-SBS-2011.company.local
Description:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 1/16/2013 5:01:26 PM
Event time (UTC): 1/16/2013 4:01:26 PM
Event ID: 4b8b9fb9f1154a14912aa661e4284595
Event sequence: 1276
Event occurrence: 15
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/1/ROOT/ecp-1-130027612831324562
Trust level: Full
Application Virtual Path: /ecp
Application Path: C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\ecp\
Machine name: SRV-SBS-2011
Process information:
Process ID: 17396
Process name: w3wp.exe
Account name: NT AUTHORITY\SYSTEM
Exception information:
Exception type: ArgumentException
Exception message: An item with the same key has already been added.
Request information:
Request URL: https://remote.company.local:443/ecp/default.aspx
Request path: /ecp/default.aspx
User host address: 192.168.0.1
User: extest_632089c04e654
Is authenticated: True
Authentication Type:
Thread account name: NT AUTHORITY\SYSTEM
Thread information:
Thread ID: 6
Is impersonating: False
Stack trace: at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at System.Collections.Generic.Dictionary`2.Add(TKey key, TValue value)
at Microsoft.Exchange.Data.PropertyBag.GetCalculatedPropertyValue(ProviderPropertyDefinition propertyDefinition)
at Microsoft.Exchange.Data.PropertyBag.get_Item(PropertyDefinition key)
at Microsoft.Exchange.Data.Directory.ADPropertyBag.get_Item(PropertyDefinition key)
at Microsoft.Exchange.Data.ConfigurableObject.get_Item(PropertyDefinition propertyDefinition)
at Microsoft.Exchange.Data.Directory.ADObject.get_Item(PropertyDefinition propertyDefinition)
at Microsoft.Exchange.Data.Directory.OwaSegmentationSettings.get_Item(ADPropertyDefinition owaFeature)
at Microsoft.Exchange.PowerShell.RbacHostingTools.RbacQuery.OwaSegmentationQueryProcessor.TryIsInRole(ExchangeRunspaceConfiguration rbacConfiguration)
at Microsoft.Exchange.PowerShell.RbacHostingTools.RbacQuery.RbacQueryProcessor.IsInRole(ExchangeRunspaceConfiguration rbacConfiguration)
at Microsoft.Exchange.PowerShell.RbacHostingTools.RbacPrincipal.IsInRole(String rbacQuery, Boolean& canCache)
at Microsoft.Exchange.PowerShell.RbacHostingTools.RbacPrincipal.IsInRole(String role)
at System.Web.Configuration.AuthorizationRule.IsTheUserInAnyRole(StringCollection roles, IPrincipal principal)
at System.Web.Configuration.AuthorizationRule.IsUserAllowed(IPrincipal user, String verb)
at System.Web.Configuration.AuthorizationRuleCollection.IsUserAllowed(IPrincipal user, String verb)
at System.Web.Security.UrlAuthorizationModule.IsUserAllowedToPath(HttpContext context, VirtualPath virtualPath)
at System.Web.SiteMapProvider.IsAccessibleToUser(HttpContext context, SiteMapNode node)
at System.Web.StaticSiteMapProvider.GetChildNodes(SiteMapNode node)
at Microsoft.Exchange.Management.ControlPanel._Default.CreateDataContract(SiteMapNode sNode)
at Microsoft.Exchange.Management.ControlPanel._Default.CreateNavTree()
at Microsoft.Exchange.Management.ControlPanel._Default.OnLoad(EventArgs e)
at System.Web.UI.Control.LoadRecursive()
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Custom event details:
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="ASP.NET 2.0.50727.0" />
<EventID Qualifiers="32768">1309</EventID>
<Level>3</Level>
<Task>3</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2013-01-16T16:01:26.000000000Z" />
<EventRecordID>442566</EventRecordID>
<Channel>Application</Channel>
<Computer>SRV-SBS-2011.company.local</Computer>
<Security />
</System>
<EventData>
<Data>3005</Data>
<Data>An unhandled exception has occurred.</Data>
<Data>1/16/2013 5:01:26 PM</Data>
<Data>1/16/2013 4:01:26 PM</Data>
<Data>4b8b9fb9f1154a14912aa661e4284595</Data>
<Data>1276</Data>
<Data>15</Data>
<Data>0</Data>
<Data>/LM/W3SVC/1/ROOT/ecp-1-130027612831324562</Data>
<Data>Full</Data>
<Data>/ecp</Data>
<Data>C:\Program Files\Microsoft\Exchange Server\V14\ClientAccess\ecp\</Data>
<Data>SRV-SBS-2011</Data>
<Data>
</Data>
<Data>17396</Data>
<Data>w3wp.exe</Data>
<Data>NT AUTHORITY\SYSTEM</Data>
<Data>ArgumentException</Data>
<Data>An item with the same key has already been added.</Data>
<Data>https://remote.company.local:443/ecp/default.aspx</Data>
<Data>/ecp/default.aspx</Data>
<Data>192.168.0.1</Data>
<Data>extest_632089c04e654</Data>
<Data>True</Data>
<Data>
</Data>
<Data>6</Data>
<Data>False</Data>
<Data> at System.ThrowHelper.ThrowArgumentException(ExceptionResource resource)
</Data>
</EventData>
</Event>
Gevolgd met de volgende 2 errors
Watson report about to be sent for process id: 17396, with parameters: E12, c-RTL-AMD64, 14.02.0328.009, ECP, M.Exchange.Data, M.E.D.PropertyBag.GetCalculatedPropertyValue, System.ArgumentException, b88e, 14.02.0328.009.
ErrorReportingEnabled: False
Current user: 'company.local/Users/extest_632089c04e654'
Request for URL 'https://remote.company.local/ecp/default.aspx' failed with the following error:
System.Web.HttpUnhandledException: Exception of type 'System.Web.HttpUnhandledException' was thrown. ---> System.ArgumentException: An item with the same key has already been added.
--- End of inner exception stack trace ---
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequest(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at ASP.default_aspx.ProcessRequest(HttpContext context)
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Ik hoop dat jullie mij hierbij kunnen helpen, Ik kan op google namelijk niet precies hetzelfde hierover vinden.
Bij voorbaat dank
