Andere manier voor Golden Orb op BP6!!!
  • 109 views sinds 30-01-2008
  • ChUcKiE
  • Registratie: September 1999
  • Laatst online: 09:53
ChUcKiE
Dus........
Iemand deze manier eens uitgeprobeerd, la salternatief voor het wegvijlen van bepaalde delen??
Here is the alternative way to mod an orb...
The orb is made up of two spereate parts: the cylinder shaped heart and a border. By default, the border creates problems on a BP6 as you all know. But no worries, there is a better solution. Just dettach the clip & fan so that on both sides of the orb the iron heart is visible. Put the orb in normal position in a wooden frame with a hole so that the bottom of the orb (were the chip makes contact) is free. Now hit the topside of the heart (were the fan used to be) with a wooden hammer softly untill the
space bweteen the border and heart increased with app. 4 mm. Decrease the pressure that the clip exerts on the cpu when locking the orb by pushing down the locking part, which is attached on the clip.
http://eu.battle.net/d3/en/profile/ChUcKiE-1330/hero/807720
