[Vista] Probleem opstarten (wdf01000.sys)
Dag allemaal,
Mijn medion laptop met windows vista wil niet meer opstarten. De tekst die ik krijg luidt als volgt:
Windows failed to start. A recent hardware or software change might be the cause.
To fix the problem:
1. Insert your Windows installation disc and restart the computer.
2. Choose your language settings and click next.
3. Click "repair your computer"
File:\Windows\system32\drivers\wdf01000.sys
Status: 0xc00000e9
Info: windows failed to load because a critical system driver is missing or corrupt
Ik heb de recovery disk van Vista gedraaid en daar kreeg ik de volgende meldingen:
Problem details:
Problem Event name: StartupRepairV2
Problem Signature 01: ExternalMedia
Problem Signature 02: 6.0.6000.16386.6.0.6001.18000
Problem Signature 03: 0
Problem Signature 04: 65537
Problem Signature 05: unknown
Problem Signature 06: NoOsinstalled
Problem Signature 07: 0
Problem Signature 08: 1
Problem Signature 09: FixPartitionTable
Problem Signature 10: 1168
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
en:
Diagnosis and repair details:
Startup Repair diagnosis and repair log
Number of repair attempts: 1
Session details
System Disk = \Device\Harddisk0
Windows directory = C:\Windows
AutoChk Run = 0
Number of root causes = 1
Test performed
Name: Check for updates
Result: Completed succesfully. Error code = 0x0
Time Taken = 16ms
Test performed
Name: System disk test
Time taken = 0 ms
Test performed
Name: Disk failure diagnosis
Time taken = 530 ms
Test performed
Name: Disk metadata test
Time taken = 16 ms
Test performed
Name: Target OS test
Time taken = 156 ms
Test performed
Name: Volume content check
Time taken = 28688 ms
Root cause found
No OS files found on disk
Repair action: Partition table repair
Result: Failed. Error code = 0x490
Time taken = 29079 ms
Op andere sites zag ik de tip om via de opdrachtprompt het corrupte bestand te vervangen voor het goede bestand. Alleen als ik naar de juiste locatie wil gaan, krijg ik het volgende te zien:
X:\Sources>C:\Windows\system32\drivers
'c:\windows\system32\drivers' is not recognized as an internal or external command, operable program or patch file.
Ook als ik gewoon c:\ tik krijg ik deze melding.
Ik heb eigenlijk maar twee vragen:
1) Wat is hier aan de hand, en nog belangrijker:
2) hoe krijg ik dit gerepareerd?
Alle hulp is meer dan welkom! Alvast dank!
Groeten,
Ben
Dit komt omdat deze prompt niet is uitgerust met alle DOS commando’s hiervoor moet je een opstart disk gebruiken geloof ik. De optie waar jij denk ik naar opzoek bent heet FIXMBR en kan wel is helpen maar kan je ook dagen zoekwerk kosten en vandaar dar een herinstallatie vaak de snelste oplossing is!
Werkt veilige modus nog wel?
Wat is er veranderd voordat het gebeurt is?
Heb je al getest of het systeem in orde is met een Ubuntu Cd’tje?
Hoi, dank voor je reactie. FIXMBR heb ik geprobeerd, maar hielp niet (instructies van deze link gevolgd: http://answers.microsoft....8e-4adc-a25b-2c0d0c234e0d).
Veilige modus werkt ook niet. De avond voordat hij het niet meer deed, heb ik een dvd'tje gekeken op laptop; daarna de dvd verwijderd en laptop afgesloten. Bij mijn weten dus geen bijzondere dingen gedaan met de laptop. Ubuntu heb ik niet mee getest, ben ik ook niet mee bekend. Kun je dat downloaden van internet?
Lullige is vooral dat ik net bestanden van mijn laptop wou overzetten naar mijn nieuwe desktop pc, oftewel ik heb geen backup. Bij een herinstallatie ben ik mijn bestanden waarschijnlijk kwijt, of niet?
