probleem met videokaart driver
  • Kudgamer
  • Laatst online: 21-09 20:20
ik heb een probleem met minecraft als ik het opstart krijg ik dit:
(ik heb trouwens windows 8 )
Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 26-12-12 15:36
-- System Details --
Details:
Minecraft Version: 1.4.6
Operating System: Windows 8 (x86) version 6.2
Java Version: 1.7.0_10, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 425448256 bytes (405 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
JVM Flags: 2 total; -Xms512m -Xmx1024m
AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
Suspicious classes: No suspicious classes found.
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
LWJGL: 2.4.2
OpenGL: ~~ERROR~~ NullPointerException: null
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Texture Pack: Default
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
at org.lwjgl.opengl.Display.createWindow(Display.java:311)
at org.lwjgl.opengl.Display.create(Display.java:856)
at org.lwjgl.opengl.Display.create(Display.java:784)
at org.lwjgl.opengl.Display.create(Display.java:765)
at net.minecraft.client.Minecraft.a(SourceFile:232)
at asq.a(SourceFile:56)
at net.minecraft.client.Minecraft.run(SourceFile:515)
at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT 99011e12 ----------
ik heb op deze site: http://www.minecraftforum...inecraft-windows-8-crash/ al een oplossing gevonden.
maar.....
dan moet je een oude driver downloaden maakt dan iets uit voor andere games of maakt dat geen verschil?
met vriendelijke groet,
The kudgamer
Hoe nieuwer de driver hoe beter het is voor de laatste spelen. Maar als de driver werkelijk niet geïnstalleerd is kan nu geen één 3D applicatie deze driver gebruiken omdat hij niet aanwezig lijkt. Heb je al een driver upgrade van je videokaart gedaan? Wat zijn je specs? De tekst meld ook iets over Java wat zover ik weet niet direct driver related is maar mogelijk moet je voor dit spel een up-to-date Java versie hebben, deze kan je downloaden vanaf Sun Java.
  • Kudgamer
mijn ndriver is helemaal up to date en java ook...
dit is mijn pc:
#ProductPrijsSubtotaal
1Intel Core i5 3570K Boxed€ 203,-€ 203,-
1ASRock Z77 Pro4-M€ 80,45€ 80,45
1MSI R7950 Twin Frozr 3GD5 V2/OC€ 274,-€ 274,-
1Seagate Barracuda 7200.14 ST2000DM001, 2TB€ 82,50€ 82,50
1NZXT Crafted Series Phantom 410€ 102,50€ 102,50
1TP-Link TL-WDN4800€ 33,03€ 33,03
1Dell Ultrasharp U2312HM Zilver, Zwart€ 188,-€ 188,-
1Microsoft Windows 8 (OEM) 64bit€ 78,37€ 78,37
1Scythe Mugen 3 PC Games Hardware Edition€ 34,99€ 34,99
1Microsoft Wired Keyboard 600€ 12,40€ 12,40
1Logitech G400 Gaming Mouse€ 26,-€ 26,-
1Steelseries QcK Guild Wars 2 Logo Edition€ 13,90€ 13,90
1Corsair Vengeance CML8GX3M2A1600C9 Low Profile€ 37,95€ 37,95
1Steelseries Siberia V2 Wit€ 69,90€ 69,90
1LG GH24NS90 Zwart€ 16,99€ 16,99
1XFX Pro 550W€ 54,50€ 54,50
1Samsung 830 series SSD 128GB€ 99,-€ 99,-
Bekijk collectie
Importeer producten
Totaal€ 1.407,48
