Club3D HD7950 lage 3Dmark 11 score: 5604
  • wout123
  • Laatst online: 12-10 14:08
Mijn gloednieuwe Club3D HD7950 royalKing (880mHz) heeft een erg lage score bij 3D Mark
gekocht bij afuture.nl (https://afuture.nl/productview.php?productID=483850)
Link: http://www.3dmark.com/3dm11/5074369]
Kaart is gister geïnstalleerd.
Mijn mobo is ASRock HM-67M-GE (PCIe 2 16x)
CPU: i5-2300 @2.8ghz
meeste kan je lezen in de link hierboven
Graphics Test 1 24.62 FPS
Graphics Test 2 27.27 FPS
Graphics Test 3 36.98 FPS
Graphics Test 4 16.72 FPS
Physics Test 17.99 FPS
Combined Test 25.93 FPS
deze link: reviews: Round-up: snelle HD 7800- en 7900-kaarten
staat Club3D 7950 staat score 6910 is 1300 punten verschil
Unigine Heaven:
3x
-op Tessellation: disabled (eerste)
-op Tessellation: Extreme (tweede)
-op Tessellation: Normal (derde)
Powered by Unigine Engine
Heaven Benchmark v3.0 Basic
FPS: 79.4
Scores: 2000
Min FPS: 14.8
Max FPS: 156.4
Hardware
Binary:
Windows 32bit Visual C++ 1600 Release Mar 7 2012
Operating system: Windows 7 (build 7601, Service Pack 1) 64bit
CPU model: Intel(R) Core(TM) i5-2300 CPU @ 2.80GHz
CPU flags: 2793MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT
GPU model: AMD Radeon HD 7900 Series 9.2.0.0 3072Mb
Settings
Render: direct3d11
Mode: 1776x1000 fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 16x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Unigine Corp. © 2005-2012
FPS: 44.4
Scores: 1119
Min FPS: 8.2
Max FPS: 121.9
Hardware
Binary: Windows 32bit Visual C++ 1600 Release Mar 7 2012
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: disabled
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Tessellation: extreme
FPS: 62.4
Scores: 1571
Min FPS: 20.9
Max FPS: 143.7
Hardware
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Tessellation: normal
Ben geen specialist, dus houd de antwoorden te begrijpen :P
[ Voor 67% gewijzigd door wout123 op 29-11-2012 18:21 ]
  • BlaBla1973
  • Laatst online: 06-10 10:03
clean install van windows gedaan?
Of oude drivers gewist...
En welke amd driver heb je gebruikt?
[ Voor 64% gewijzigd door BlaBla1973 op 30-11-2012 13:01 ]
Computer nr 486 denk ik..
  • wout123
Nee geen clean install, is laatst nog gebeurd
Oude drivers zijn gewist
Catalyst 12.10
Als ik de settings van Heaven goed had staan bij test 3 kom ik op de goede score uit.
[ Voor 32% gewijzigd door wout123 op 30-11-2012 15:41 ]
  • Gamer
  • Laatst online: 21:16
Gamer
Electrified
Gebruik de beta 12.11 eens, je score zal wel stijgen.
Homey Pro | 4600Wp Z - 4800Wp W- 4800Wp O | SH4.0RS | SH5.0RS | SBR192 accu| Zendure 2400AC + 5 AB3000X| Easee Charge Lite | Corsa-e 50kWh | Mercedes EQA 250+ 70kWh
  • wout123
Ik zal het proberen maar 3D mark start niet meer..
Het proces start op maar geen venster
Zoiets als
Klik klik bij mn pijltje heel even kort zon laad dingetje en weg. Niks gebeurt
  • prutser001
  • Laatst online: 09-10 03:39
prutser001
Vaak zit het tegen en soms zi
Kijk eens bij eventvwr misschien dat daar een foutmelding staat ofzo?
Asus Z390 Maximus IX Hero, Intel 9900K, RTX3080, 64GB DDR4 3000, 2TB NVME, Samsung 850Evo 1TB, 4 x 14TB Toshiba, Be Quiet SB 801, Samsung 34"
  • wout123
oud topic omhoog,
Ja staat een storing
"Beschrijving: het proces is beëindigd als gevolg van een onverwerkte uitzondering.
Uitzonderingsinformatie: System.Reflection.TargetInvocationException"
maar toch als ik even op YT keek zag ik toch iemand met een score van 10K?
Ernstig? Maar nog steeds help?
  • Moi_in_actie
  • Laatst online: 20:18
Ik denk niet dat die persoon op Youtube een stock 7950 draait met een instap Sandy Bridge Core i5 :) Ik doe een wilde gok dat het de review van TTL is en die haalde een 10K+ score met een max overclocked HD7950 en een overgeclockte i7 3960X.
Volgens deze Tweakers review haalt mijn Zotac GTX670 maximaal 9800 punten, mijn record is 11.4k. Kortom, vergelijken met de topscores moet je niet doen.
Terugkomend op het probleem, staat er nergens (in het bios of Windows) iets op een power saver modus? Kijk ook eens naar de core speed (bv. met EVGA Precision X) wanneer je 3D Mark 11 draait, of een game en kijk of de snelheden wel kloppen.
Download anders ook eens GPU-Z en kijk wat daar staat bij "Bus Interface", oftewel krijgt ie wel de volledige PCIe 2.0 x16 bandbreedte.
Tenslotte, welke voeding gebruik je? Wellicht dat de voeding niet genoeg power kan leveren, waardoor de GPU wel eens kan inhouden.
Wat betreft 3D Mark die niet meer wil starten, waarschijnlijk helpt het reinstallen ervan.
Ryzen 9 9950X3D ~~ 32GB GSkill TridentZ 6000Mhz ~~ ASRock B850M Steel Legend ~~ Powercolor Hellhound RX9070XT
  • faust2016
  • Laatst online: 21:00
faust2016
You yes have my shirt
Ik weet het niet zeker hoor, maar ik dacht dat als een voeding niet genoeg vermogen kan leveren het scherm op zwart springt en de pc zichzelf uitschakelt. Wat ik uit jouw reactie opmaak is dat de GPU zichzelf dan terug zou klokken..?
  • A87
A87
BlaBla1973 schreef op vrijdag 30 november 2012 @ 12:59:
Ik zie dit soort opmerkingen wel vaker, klein probleempje wat ik in 1 minuut oplos.... zeggen andere ''clean install etc.''
Maar als iemand een probleem heeft aan zijn auto zeg je toch ook niet meteen demonteer je hele auto even en zet alles weer in elkaar en achteraf was het daadwerkelijke probleem 10 seconden werk.
[ Voor 58% gewijzigd door A87 op 02-01-2013 11:10 ]
  • Moi_in_actie
faust2016 schreef op woensdag 02 januari 2013 @ 03:03:
In principe klopt het wat je zegt, het zou alleen kunnen (lees: het zou mij niet verbazen wanneer het gebeurt) dat hij terugclockt. Een soortgelijk iets lees je soms wel eens bij ultrabooks, waar de CPU gaat throttlen omdat het ding te warm wordt.
Het ging mij meer om het feit dat het kan zijn dat de GPU niet op de correcte snelheid loopt. Dit kan ook vanwege drivers, fout in de firmware/bios van de kaart, hardwarematig probleem van de kaart etc. Wanneer ik mijn GPU flink overclock en het te ver push crashen de drivers wel eens en blijft de kaart hangen in de 2D modus, met veel lagere clockspeeds. Stel wout123 heeft een kaart met een brak bios, waardoor dit al bij stock settings gebeurt...
Even kijken hoe de voltages zijn is een kleine moeite met iets als HardwareMonitor of OCCT, waarschijnlijk is dat het probleem niet maar je kunt het zo wel makkelijk uitsluiten.
  • mitsumark
A87 schreef op woensdag 02 januari 2013 @ 10:58:
Welke problemen heb jij binnen 1 minuut opgelost waarbij anderen zeiden dat er een clean install 'moest' komen?
Dit soort problemen worden nou eenmaal in 99% van de gevallen veroorzaakt door de software.
Je kunt inderdaad proberen eerst alleen alle gpu software/drivers te verwijderen en opnieuw te installeren, maar vaak helpt dat niet.
Bij een clean install weet je in ieder geval zeker (mits juiste drivers etc) dat daar het probleem niet zit.
Een clean install kost misschien 2 uur werk, maar verder kost het niks in euro's en heb je er sowieso profijt van (de vergelijking met de auto is irrelevant, we vragen toch niet of hij de pc opnieuw in elkaar zet?).
  • LiquidT_NL
  • Laatst online: 17-06 08:19
Nee zo werkt het niet. Inderdaad, clean install is niet het beste advies in veel gevallen, maar soms toch de enige oplossing, of in ieder geval tijdsefficiente oplossing. Er is een punt waarop zoeken naar een oplossing langer duurt. Daarnaast is het feit dat 3D mark niet draait ook een rode vlag voor een rotte Windows. Het punt is dat 10 uur zoeken naar een oplossing van een minuut minder loont dan het toepassen van een reinstall, dat een uurtje duurt.
Daarnaast, je topic heeft in het begin 4 dagen beslagen, en nu begin je weer. Ik heb ook niet echt het gevoel dat jij aangedragen punten/oplossingen hebt gedaan/geprobeerd. Zo ja, geef dat dan aan.
Explorers in the further regions of experience...demons to some, angels to others.
  • wout123
Was toch benieuwd en heb GPU-Z op Far Cry 3 uitgeprobeerd mijn GPU is wel de bottleneck.
Ben verder niet bezig geweest met mijn PC.
Die log van GPU-Z hoe kan ik die het beste posten? of moet ik wat opzoeken?
dit is de hele log het is redelijk duidelijk wanneer ik begin te spelen.
http://www.mijnbestand.nl/Bestand-J6RNVRUH8P8L.txt
Voeding: 650W (van XFX)
Ik heb een probleempje met CCC, deze geeft een foutmelding bij het verwijderen maar is dan toch verwijderd.
En ik ben niet echt verschrikkelijk handig met software/hardware
De kaart is Dual Bios dus ik zou hem nog op de andere bios kunnen zetten. (De overclocked, maar dat vind ik niet nodig als het geen problemen oplost)
  • comitatus
  • Laatst online: 27-08 11:52
Het verschil zit hem niet in de kaart maar in alles wat je anders doet, je overclockt niet, je hebt veel mindere cpu, hij wordt niet zwaar gekoeld. Je kunt zo niet een op een vergelijken. Het is daarom dat ze bookmarks in testen op 1 vaste pc uitvoeren.
  • LiquidT_NL
wout123 schreef op vrijdag 04 januari 2013 @ 00:08:
Zoals al vaker gezegd, die scores zeggen sowieso niets. En gezien je zoveel software problemen hebt, zou je niet even Windows opnieuw er op zetten?
  • wout123
Dit zijn echt de enige twee hoor ;)
verder eigenlijk niks, maar heb nu geen tijd voor clean install.
Dus het zegt gewoon niets?
dus eigenlijk is het gewoon goed zo? of wat is het?
Mijn CPU loopt echt niet op 100% (ver daarvan, rond 40%) met FC3
De error bij CCC is dat het bestand op een netwerkbron staat (?)
[ Voor 11% gewijzigd door wout123 op 04-01-2013 13:20 ]
