• RhedX
  • Laatst online: 28-04 23:42
beste lezer,
ik heb een probleem met mijn lg p350, hij wil niet meer opstarten.
Dit gebeurde nadat ik het frimware probeerde terug te draaien, dit heb ik gedaan met: Software Update KDZ.
Ik heb geen idee wat er fout is gegaan. Want nadat ik de p350 had geflasht sloot hij af, opstarten deedt ie dus niet meer.
Hier is de log die er gemaakt is:
[11:25:48:387] : =============================================
[11:25:48:387] : Log is started on 17.11.2012, at 11:25:48:387,
executable: C:\Users\Administrator\Desktop\KDZ_FW_UPD.exe (ProcID: 0x00000910),
compile time : Dec 8 2010 09:19:37
[11:25:48:614] : Version :
[11:25:49:305] : Get Usb Port
[11:25:50:403] : rsi.strFriendlyName=LGE Bluetooth TransPort (COM7)
[11:25:50:403] : Remove LGE Bluetooth TransPort (COM7)
[11:25:50:403] : rsi.strFriendlyName=LGE Android Platform USB Serial Port (COM15)
[11:25:50:403] : FriendlyNameList[iii].szFriendlyName=LGE Android Platform USB Serial Port
[11:25:50:426] : WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 1 - COM15
[11:25:50:426] : Port = COM15
[11:25:50:817] : UNKNOWN : Req(12) -> Rsp(13)
[11:25:50:818] : UNKNOWN : Req(12) -> Rsp(13)
[11:25:50:819] : UNKNOWN : Req(12) -> Rsp(13)
[11:25:50:819] : >> DIAG_STATUS_F FAILED
[11:25:50:824] : >>Get Model Name [DIAG_VERNO_F]
[11:25:50:825] : BAD CONN MODE : Req(0) -> Rsp(3)
[11:25:50:826] : BAD CONN MODE : Req(0) -> Rsp(3)
[11:25:50:827] : BAD CONN MODE : Req(0) -> Rsp(3)
[11:25:50:828] : BAD CONN MODE : Req(0) -> Rsp(3)
[11:25:50:829] : BAD CONN MODE : Req(0) -> Rsp(3)
[11:25:50:830] : BAD CONN MODE : Req(0) -> Rsp(3)
[11:25:50:830] : FAIL (No Phone)
[11:25:50:830] : GetModelName() Operation Failed Check Diag CMD
[11:25:50:830] : EMERGENCY Booting Mode
[11:25:50:830] : >>Get Model Name in Emergency Mode [DLOAD_VERREQ_F]
[11:25:50:831] : BS/P350/7Ddministrator\Downloads\Tail.e
[11:25:50:831] : WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 0 - P350
[11:25:50:842] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[11:25:50:842] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[11:25:50:843] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[11:25:50:843] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[11:25:50:844] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[11:25:50:844] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[11:25:51:033] : NV Write Fail : NV ITEM 9028(9028)
[11:25:51:133] : >> GET DLOAD COMM MODE
[11:25:51:134] : [GetCommMode] Communication mode : 2
[11:25:51:167] : Pre Nand Download
[11:25:51:167] : >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted)
[11:25:51:173] : WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - TRUSTED MODE
[11:25:51:174] : [COM15] >>NandFlashInitWithFile(PARTITION TBL)
[11:25:51:175] : WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - INIT PARTITION TBL
[11:25:56:195] : ¸Þ½ÃÁö º¸³¿ TYPE_WPARAM_WRITE_TO_SDRAM 3
[11:25:56:195] : [COM14] ¸Þ½ÃÁö º¸³¿ TYPE_WPARAM_WRITE_AMSS 15
[11:25:56:195] : [COM15] >>NandFlashInitWithFile(AMSS MODEM HEADER)
[11:25:56:410] : WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - INIT AMSS MODEM HEADER
[11:25:56:422] : [COM14] >>Dl_AsyncWrite()
[11:25:56:422] : >> AMSS FLASHING ...
[11:25:56:428] : ¸Þ½ÃÁö º¸³¿ ProgreassiveBar Init wParam TYPE_WPARAM_PROGRESSIVE_POS=5 lParam(pos)=0 nResult=0
[11:25:56:480] : Sending Pkt Seq : 0
[11:25:56:480] : Sending Pkt Seq : 1
[11:25:56:480] : Sending Pkt Seq : 2
[11:25:56:480] : Sending Pkt Seq : 3
[11:25:56:480] : Sending Pkt Seq : 4
[11:25:56:480] : Sending Pkt Seq : 5
[11:25:56:480] : Sending Pkt Seq : 6
[11:25:56:481] : Sending Pkt Seq : 7
[11:25:56:481] : Sending Pkt Seq : 8
[11:25:56:481] : Sending Pkt Seq : 9
[11:25:59:486] : RX Timeout : 3.0 seconds
[11:25:59:486] : RX TIMEOUT
[11:25:59:497] : Dl_AsyncWrite - Packet is lost! : Sent packet(9), Lost packet(10)
[11:25:59:497] : if(bPktLost == TRUE)
[11:26:00:497] : Sending Pkt Seq : 10
[11:26:00:497] : Sending Pkt Seq : 11
[11:26:00:497] : Sending Pkt Seq : 12
[11:26:00:497] : Sending Pkt Seq : 13
[11:26:00:498] : Sending Pkt Seq : 14
[11:26:00:498] : Sending Pkt Seq : 15
[11:26:00:498] : Sending Pkt Seq : 16
[11:26:00:498] : Sending Pkt Seq : 17
[11:26:00:498] : Sending Pkt Seq : 18
[11:26:00:498] : Sending Pkt Seq : 19
[11:26:03:508] : RX Timeout : 3.0 seconds
[11:26:03:508] : RX TIMEOUT
[11:26:03:510] : Dl_AsyncWrite - Packet is lost! : Sent packet(19), Lost packet(20)
[11:26:03:510] : if(bPktLost == TRUE)
[11:26:04:510] : Sending Pkt Seq : 20
[11:26:04:510] : Sending Pkt Seq : 21
[11:26:04:510] : Sending Pkt Seq : 22
[11:26:04:511] : Sending Pkt Seq : 23
[11:26:04:511] : Sending Pkt Seq : 24
[11:26:04:511] : Sending Pkt Seq : 25
[11:26:04:511] : Sending Pkt Seq : 26
[11:26:04:511] : Sending Pkt Seq : 27
[11:26:04:511] : Sending Pkt Seq : 28
[11:26:04:511] : Sending Pkt Seq : 29
[11:26:04:512] : Dl_AsyncWrite - ErrNo(45), Addr(0x00009800), NandErrNo(0x19)
[11:26:04:512] : [COM14] ERROR Dl_AsyncWrite() TYPE_LPARAM_UPGRADE_ERROR_WRITE_TO_FLASH
[11:26:04:513] : WM_COPYDATA ¸Þ½ÃÁö º¸³¿ 3 - Close Port
[11:26:04:513] : Close Port<<
[11:26:04:513] : TYPE_WPARAM_UPGRADE_ERROR
[11:26:04:513] : ¸Þ½ÃÁö º¸³¿ - TYPE_WPARAM_UPGRADE_ERROR Error Code = 4008
[11:26:04:791] : Log finished
ik weet dus niet wat ik fout heb gedaan en of het nog wel gefixt kan worden |:(
kan iemand mij hier alsjeblieft bij helpen?
RhedX
  • RhedX
ok, ik wordt hier gek van.
ik koop gwn een nieuwe telefoon
/topic gesloten
  • loll
  • Laatst online: 28-07 21:31
Ik heb hem ook sowieso is het een k*t telefoon.
Het is een slim plan om een nieuwe te halen want hij is niet vooruit te branden.
