Error tijdens "Make" Debian
  • durkp
  • Laatst online: 24-11 22:10
Hi,
Ik ben thuis bezig om op een testbakje libnfc te installeren met hierop de tool NfcEventD.
Libnfc is allemaal prima geinstalleerd. Alleen bij NfcEventD krijg ik tijdens "make" een error waardoor ik niet verder kom.
Ben gaan zoeken op internet maar hier kwam ik niks verder mee. Nergens komt iets voor van de fout.
./Configure
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether make sets $(MAKE)... (cached) yes
checking build system type... armv6l-unknown-linux-gnueabi
checking host system type... armv6l-unknown-linux-gnueabi
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for pkg-config... /usr/bin/pkg-config
checking for ANSI C header files... (cached) yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for stdint.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdbool.h... (cached) yes
checking for memset... yes
checking for strcasecmp... yes
checking for strchr... yes
checking for strdup... yes
checking for strerror... yes
checking for strstr... yes
checking for strtol... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking for an ANSI C-conforming const... yes
checking for pid_t... yes
checking vfork.h usability... no
checking vfork.h presence... no
checking for vfork.h... no
checking for fork... yes
checking for vfork... yes
checking for working fork... yes
checking for working vfork... (cached) yes
checking for GNU libc compatible malloc... yes
checking for GNU libc compatible realloc... yes
checking for vprintf... yes
checking for _doprnt... no
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for size_t... yes
checking for uint8_t... yes
checking for uint16_t... yes
checking for uint32_t... yes
checking for uint64_t... yes
checking for int32_t... yes
checking for debug flag... no
checking for dbus support... no
checking for pkg-config... (cached) /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for LIBNFC... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating conf/Makefile
config.status: creating src/Makefile
config.status: creating src/nfcconf/Makefile
config.status: creating src/debug/Makefile
config.status: creating src/modules/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
sysconfdir: ${prefix}/etc
nemdir: ${pkglibdir}/modules
en dan als ik make wil uitvoeren komt de volgende error te voorschijn.
29
30
31
32
33
34
35
36
37
38
39
root@nfc:/home/nfc/nfc-eventd# make
make  all-recursive
make[1]: Entering directory `/home/nfc/nfc-eventd'
Making all in src
make[2]: Entering directory `/home/nfc/nfc-eventd/src'
Making all in debug
make[3]: Entering directory `/home/nfc/nfc-eventd/src/debug'
  CC     debug.lo
In file included from debug.c:31:
nfc-utils.h:89: warning: type defaults to âintâ in declaration of ânfc_iso14443a_infoâ
nfc-utils.h:89: error: expected â;â, â,â or â)â before ânaiâ
nfc-utils.h:90: warning: type defaults to âintâ in declaration of ânfc_iso14443b_infoâ
nfc-utils.h:90: error: expected â;â, â,â or â)â before ânbiâ
nfc-utils.h:91: warning: type defaults to âintâ in declaration of ânfc_iso14443bi_infoâ
nfc-utils.h:91: error: expected â;â, â,â or â)â before âniiâ
nfc-utils.h:92: warning: type defaults to âintâ in declaration of ânfc_iso14443b2sr_infoâ
nfc-utils.h:92: error: expected â;â, â,â or â)â before ânsiâ
nfc-utils.h:93: warning: type defaults to âintâ in declaration of ânfc_iso14443b2ct_infoâ
nfc-utils.h:93: error: expected â;â, â,â or â)â before ânciâ
nfc-utils.h:94: warning: type defaults to âintâ in declaration of ânfc_felica_infoâ
nfc-utils.h:94: error: expected â;â, â,â or â)â before ânfiâ
nfc-utils.h:95: warning: type defaults to âintâ in declaration of ânfc_jewel_infoâ
nfc-utils.h:95: error: expected â;â, â,â or â)â before ânjiâ
nfc-utils.h:96: warning: type defaults to âintâ in declaration of ânfc_dep_infoâ
nfc-utils.h:96: error: expected â;â, â,â or â)â before ândiâ
nfc-utils.h:97: warning: type defaults to âintâ in declaration of ânfc_baud_rateâ
nfc-utils.h:97: error: expected â;â, â,â or â)â before ânbrâ
nfc-utils.h:99: warning: type defaults to âintâ in declaration of ânfc_targetâ
nfc-utils.h:99: error: expected â;â, â,â or â)â before ântâ
debug.c:80: warning: type defaults to âintâ in declaration of ânfc_targetâ
debug.c:80: error: expected â;â, â,â or â)â before â*â token
make[3]: *** [debug.lo] Error 1
make[3]: Leaving directory `/home/nfc/nfc-eventd/src/debug'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/nfc/nfc-eventd/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/nfc/nfc-eventd'
make: *** [all] Error 2
De link naar het bestand nfc-utils.h.
Dus mijn vraag is als er iemand bekend is met het tevoorschijnen van zo'n probleem. Wat hij aangeeft zijn namelijk spaties.
Ik weet overigens niet als ik hier goed zit omdat dit misschien ook wel bij programming hoort, maar dit leek mij de beste keus, in de hoop dat iemand ervaring met dit heeft.
Durk
  • CH4OS
CH4OS
It's a kind of magic
Ik zou zeggen dat het een probleem is met de gebruikte locale (geen UTF-8 wellicht) als ik de speciale characters zo zie tevoorschijnen.
[ Voor 8% gewijzigd door CH4OS op 11-09-2012 18:44 ]
  • Osiris
CptChaos schreef op dinsdag 11 september 2012 @ 18:44:
Die à-tjes e.d.? Dat lijkt me eerder een probleem door de poster en niet zozeer in `make`. Die gekke tekentjes zijn aanhalingstekens e.d., moet je er maar gewoon eventjes bijverzinnen.
durkp schreef op dinsdag 11 september 2012 @ 18:36:
Wut?
Ik zie toch echt code op de door `make` aangegeven regels staan... En de error-messages zijn ook nog eens harstikke duidelijk. Dus ik snap niet echt waar je nu tegenaan loopt.
(Even los van het feit dat wellicht de code van dat NfcEventD gewoon brak kan zijn..)
  • CH4OS
CH4OS
Osiris schreef op dinsdag 11 september 2012 @ 18:47:
Dingen als
â;â, â,â or â)â
bedoel ik. Niet zozeer die verder in de regel (na in declaration of dus) staan. :)
[ Voor 3% gewijzigd door CH4OS op 11-09-2012 18:50 ]
  • Osiris
CptChaos schreef op dinsdag 11 september 2012 @ 18:50:
Dingen als
â;â, â,â or â)â
Ja, daar staat dus gewoon
';', ',' or ')' before 'nai'
en is niet het inhoudelijke probleem van de TS. Die tekens staan immers helemaal niet in de nfc-utils.h of iets dergelijks, maar worden door `make` zelf gegenereerd. Daar *KAN* `make` dus niet eens over vallen. Dús geen inhoudelijk probleem voor dit topic.
Verder krijg ik 't ook niet aan de praat onder Gentoo. 't Is een SVN checkout, dus tja, nou niet echt stabiel te noemen :P
Oh wacht, d'r is ook een .tar.gz.
Ah, die compilet prima:
[b][green]gerjan@desktop[/][blue] nfc-eventd-0.1.5 $[/][/] make
make  all-recursive
make[1]: Entering directory `/tmp/nfc-eventd-0.1.5'
Making all in src
make[2]: Entering directory `/tmp/nfc-eventd-0.1.5/src'
Making all in debug
make[3]: Entering directory `/tmp/nfc-eventd-0.1.5/src/debug'
  CC     debug.lo
In file included from debug.c:31:0:
nfc-utils.h:79:0: warning: "ERR" redefined
debug.h:33:0: note: this is the location of the previous definition
debug.c: In function ‘debug_print’:
debug.c:75:13: warning: format not a string literal and no format arguments
  CC     nfc-utils.lo
  CCLD   libdebug.la
make[3]: Leaving directory `/tmp/nfc-eventd-0.1.5/src/debug'
Making all in nfcconf
make[3]: Entering directory `/tmp/nfc-eventd-0.1.5/src/nfcconf'
  CC     nfcconf.lo
nfcconf.c: In function ‘parse_type’:
nfcconf.c:443:9: warning: ISO C forbids conversion of object pointer to function pointer type
nfcconf.c: In function ‘write_type’:
nfcconf.c:601:9: warning: ISO C forbids conversion of object pointer to function pointer type
nfcconf.c:636:36: warning: cast from pointer to integer of different size
nfcconf.c:646:36: warning: cast from pointer to integer of different size
  CC     parse.lo
parse.c: In function ‘nfcconf_item_find’:
parse.c:75:77: warning: unused parameter ‘key’
  CC     write.lo
  CC     nfclex.lo
  CCLD   libnfcconf.la
make[3]: Leaving directory `/tmp/nfc-eventd-0.1.5/src/nfcconf'
Making all in modules
make[3]: Entering directory `/tmp/nfc-eventd-0.1.5/src/modules'
make  all-am
make[4]: Entering directory `/tmp/nfc-eventd-0.1.5/src/modules'
  CC     nem_execute_la-nem_execute.lo
  CCLD   nem_execute.la
make[4]: Leaving directory `/tmp/nfc-eventd-0.1.5/src/modules'
make[3]: Leaving directory `/tmp/nfc-eventd-0.1.5/src/modules'
make[3]: Entering directory `/tmp/nfc-eventd-0.1.5/src'
  CC     nfc-eventd.o
nfc-eventd.c: In function ‘load_module’:
nfc-eventd.c:105:25: warning: ISO C forbids assignment between function pointer and ‘void *’
nfc-eventd.c:116:34: warning: ISO C forbids assignment between function pointer and ‘void *’
  CCLD   nfc-eventd
make[3]: Leaving directory `/tmp/nfc-eventd-0.1.5/src'
make[2]: Leaving directory `/tmp/nfc-eventd-0.1.5/src'
Making all in conf
make[2]: Entering directory `/tmp/nfc-eventd-0.1.5/conf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/tmp/nfc-eventd-0.1.5/conf'
make[2]: Entering directory `/tmp/nfc-eventd-0.1.5'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/tmp/nfc-eventd-0.1.5'
make[1]: Leaving directory `/tmp/nfc-eventd-0.1.5'
[b][green]gerjan@desktop[/][blue] nfc-eventd-0.1.5 $[/][/] ls
aclocal.m4  [b][blue]conf[/][/]          config.h.in    [b][green]config.sub[/][/]    COPYING  [b][green]install-sh[/][/]  [b][blue]m4[/][/]           Makefile.in  README
AUTHORS     [b][green]config.guess[/][/]  [green]config.log[/]     [b][green]configure[/][/]     [b][green]depcomp[/][/]  [b][green]libtool[/][/]     Makefile     [b][green]missing[/][/]      [b][blue]src[/][/]
ChangeLog   config.h      [b][green]config.status[/][/]  configure.ac  INSTALL  [b][green]ltmain.sh[/][/]   Makefile.am  NEWS         stamp-h1
[b][green]gerjan@desktop[/][blue] nfc-eventd-0.1.5 $[/][/] cd src/
[b][green]gerjan@desktop[/][blue] src $[/][/] ls
[b][blue]debug[/][/]  Makefile  Makefile.am  Makefile.in  [b][blue]modules[/][/]  [b][blue]nfcconf[/][/]  [b][green]nfc-eventd[/][/]  nfc-eventd.c  nfc-eventd.o  types.h
Prachtige nfc-eventd-binary :)
[ Voor 107% gewijzigd door Osiris op 11-09-2012 19:03 ]
  • Cassettebandje
  • Laatst online: 10:40
Cassettebandje
SA-C90 TDK
nfc-utils.h:89: warning: type defaults to "int" in declaration of "nfc_iso14443a_info"
Hier klopt iets niet aan je broncode. Er wordt in regel 89 van nfc-utils.h een type gebruikt wat nog niet eerder gedefinieerd is, dan krijg je met gcc deze melding. Bekijk de code, kijk waarom dit type nog niet gedefinieerd is en kijk hoe je dat eventueel op kunt lossen. Misschien moet je een extra define of een optie meegeven aan je configure. Contacteer eventueel de ontwikkelaar.
  • Osiris
Cassettebandje schreef op dinsdag 11 september 2012 @ 19:00:
Hij moet gewoon nfc-eventd-0.1.5.tar.gz downloaden, die werkt wel. Vanuit SVN niet tho.
  • durkp
Hmm de nfc-eventd tool heb ik inderdaad alleen vanuit svn gedaan. Zal het eens proberen
  • sam.vimes
  • Laatst online: 06-11 12:47
Osiris schreef op dinsdag 11 september 2012 @ 19:04:
Of switchen naar de svn-branch tags/nfc-eventd-0.1.5.
Daar heb je nou versiebeheer voor.
