Laptop ~1000.- programming + gaming
Wat ga je met je laptop doen (welke programma's wil je gebruiken)?
1. frontend development (software like eclipse for symfony2, photoshop..)
2. a bit of gaming
Wat mag je laptop gaan kosten?
preferably 1000.-, max 1200.- with OS or best alternative
Ben je van plan je laptop veel met je mee te slepen? (gewicht, accuduur, grootte etc)
15.6 inch is fine
Dutch is fine, I just write in English because I didn't learn to write Dutch that good abroad
thanks a lot!
  • manmad
  • Laatst online: 08-07 11:14
Deze laptop is mij aangeraden geweest door Omni en ziet er zeer interessant uit!
- Super goede grafische kaart
- Full hd scherm, wat programmeren minder vermoeiend maakt.
- ssd
. 1Tb HDD
- Goede batterij
productreview: Lenovo IdeaPad Y580-M772CMH review door Omni
[ Voor 22% gewijzigd door manmad op 28-08-2012 23:16 ]
  • Vinand
  • Laatst online: 13-08 23:20
Another alternative for a laptop is the Asus N56 series, this laptop had a great build quality and a decent battery duration compared with the Lenovo, is you prefer to have a better Full HD screen and a very low weight, then look no further then the Sony Vaio S15...
Dell Alienware M15X - Core i7 730QM - GTX460M | Sony Vaio Z21L9E | Blackberry Z10
Those are pretty much all the options for that price. The y580 has the best graphics card, the n56vz is good all round but a bit less focused on gaming and is a bit more sturdy than the y580 (and the asus looks better imo). The s15 stands out because of its lightness, it weighs approx. 2kg where the n56 weighs 2,7 and the lenovo is 2,8kg
Btw, where are you from?
[ Voor 3% gewijzigd door Verwijderd op 28-08-2012 23:33 ]
Many thanks for the quick replies!
weight and battery are not an issue.
You mean this Asus n56vz?
pricewatch: Asus N56VZ-S4022V
For work both are fine, but for gaming does it make a big difference?
No the cheaper one, for the 4022 you pay 200€ for pretty much nothing. pricewatch: Asus N56VZ-S4035V-NL doesn't have a backlit keyboard though, but pricewatch: Asus N56VZ-S4056V does. The hard disk is slower on the 4056 though.
