[W2K8R2] VSS writers failen bij backup
  • YellowOnline
  • Laatst online: 25-01 20:45
YellowOnline
BEATI PAVPERES SPIRITV
Na een verse boot is alles in orde met de VSS writers op deze server:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Windows\system32>vssadmin list writers
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2005 Microsoft Corp.
Writer name: 'Task Scheduler Writer'
   Writer Id: {d61d61c8-d73a-4eee-8cdd-f6f9786b7124}
   Writer Instance Id: {1bddd48e-5052-49db-9b07-b96f96727e6b}
   State: [1] Stable
   Last error: No error
Writer name: 'VSS Metadata Store Writer'
   Writer Id: {75dfb225-e2e4-4d39-9ac9-ffaff65ddf06}
   Writer Instance Id: {088e7a7d-09a8-4cc6-a609-ad90e75ddc93}
   State: [1] Stable
Writer name: 'Performance Counters Writer'
   Writer Id: {0bada1de-01a9-4625-8278-69e735f39dd2}
   Writer Instance Id: {f0086dda-9efc-47c5-8eb6-a944c3d09381}
   State: [1] Stable
Writer name: 'DPM Writer'
   Writer Id: {0074a271-4f24-43e0-9ec7-28a44189cb80}
   Writer Instance Id: {4f8e2d77-9843-45f0-a47a-6376bfc820b3}
   State: [1] Stable
Writer name: 'System Writer'
   Writer Id: {e8132975-6f93-4464-a53e-1050253ae220}
   Writer Instance Id: {44d9645f-3d1a-4b00-9844-8d2a07431bb9}
   State: [1] Stable
Writer name: 'ASR Writer'
   Writer Id: {be000cbe-11fe-4426-9c58-531aa6355fc4}
   Writer Instance Id: {ca27f6f0-b915-43dc-b49d-1804865b4029}
   State: [1] Stable
Writer name: 'Registry Writer'
   Writer Id: {afbab4a2-367d-4d15-a586-71dbb18f8485}
   Writer Instance Id: {121900c0-b86e-43b1-a36f-c8d85e214a2d}
   State: [1] Stable
Writer name: 'IIS Config Writer'
   Writer Id: {2a40fd15-dfca-4aa8-a654-1f8c654603f6}
   Writer Instance Id: {64b566a0-abed-46d0-96b2-ffc64638e2f0}
   State: [1] Stable
Writer name: 'Shadow Copy Optimization Writer'
   Writer Id: {4dc3bdd4-ab48-4d07-adb0-3bee2926fd7f}
   Writer Instance Id: {919235ea-7924-449a-a239-03cc0173e5e1}
   State: [1] Stable
Writer name: 'COM+ REGDB Writer'
   Writer Id: {542da469-d3e1-473c-9f4f-7847f01fc64f}
   Writer Instance Id: {b3ae0cc2-b7b1-430e-9ad8-50a004277f2a}
   State: [1] Stable
Writer name: 'WMI Writer'
   Writer Id: {a6ad56c2-b509-4e6c-bb19-49d8f43532f0}
   Writer Instance Id: {f39419a7-bdba-4e19-8885-07bdaa6c007f}
   State: [1] Stable
Na een backup te proberen nemen met DPM ziet het er een slagveld uit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
   State: [1] Stable
   State: [1] Stable
   State: [1] Stable
   State: [1] Stable
   State: [7] Failed
   Last error: Timed out
   Writer Instance Id: {d2b45971-628b-4ab3-8dda-32535542e871}
   State: [7] Failed
   Last error: Non-retryable error
   Writer Instance Id: {76a8eda5-8a8b-45b5-b4cb-7ac93913297a}
   State: [7] Failed
   Writer Instance Id: {b2914711-4bd5-42a2-bbfd-ac3f6d050f63}
   State: [7] Failed
   State: [7] Failed
   State: [7] Failed
   Writer Instance Id: {669488ec-fa74-4416-8e38-de6309332b42}
   State: [7] Failed
Ik heb geen idee waar te beginnen, aangezien alle writers in orde zijn bij start-up. De foutmelding in Windows Backup is niet erg duidelijk: "The operation to back up the volume was stopped before the operation started running. Veel is er op Google niet over te vinden, zelfs als ik DPM buiten beschouwing laat. De oplossingen inzake actieve partitie wijzigen en DLLs herregistreren zijn niet van toepassing op een 2008 R2 (ze zouden zelfs eerder schade toebrengen).
Wat al evenmin werkt is een backup buiten DPM om, dus het is geen DPM probleem:
The backup operation to D:\Temp is starting.
Creating a shadow copy of the volumes specified for backup...
The backup operation stopped before completing.
Summary of the backup operation:
Detailed error: ERROR - A Volume Shadow Copy Service operation error has
occurred: (0x800423f4)
The writer experienced a non-transient error.  If the backup process is retried,
the error is likely to reoccur.
A Volume Shadow Copy Service operation failed. Please check "VSS" and "SPP" appl
ication event logs for more information.
I'm at loss. Loopt hier toevallig een VSS expert rond?
  • megamuch
  • Laatst online: 29-01 20:14
megamuch
Tring Tring!
Als welke user worden die backups gestart? VSS gebruikt COM om te communiceren bij het starten. Wellicht dat daar iets mis gaat ?
MSDN: Troubleshooting VSS Applications (Windows)
Verstand van Voip? Ik heb een leuke baan voor je!
  • CaPuT
  • Laatst online: 06-10 16:14
Wat misschien mist in dit verhaal, is het een fysieke of een virtuele (Hyper-V?) server?
  • kroegtijger
  • Laatst online: 21-07 14:56
Is de machine soms ge-imaged met Achronis of iets dergelijks? Daar moet je namelijk eerst VSS uitschakelen voordat je gaat imagen, aangezien VSS gebruik maakt van het Disk ID en deze is na een image terug plaatsen anders geworden. Kan je wel weer herstellen, maar is risky business... Het kan zomaar gebeuren dat je disk niet meer toegankelijk is, en je een clean install moet gaan doen dan...
iRacing Profiel
  • Razwer
  • Laatst online: 17-09 21:20
edit: ik moet leren lezen: dacht dat je backupexec had, maar je hebt het over DPM.
[ Voor 68% gewijzigd door Razwer op 23-08-2012 18:59 ]
Newton's 3rd law of motion. Amateur moraalridder.
  • YellowOnline
YellowOnline
megamuch schreef op donderdag 23 augustus 2012 @ 16:46:
Als NT AUTHORITY\SYSTEM. Ik zal morgen eens die link uitpluizen. De info die ik al op MSDN vond voor dit soort problemen was niet van toepassing op R2.
CaPuT schreef op donderdag 23 augustus 2012 @ 16:55:
Sorry, een fysieke machine. Om precies te zijn is het een fysieke primary DPM server die niet gebackupped kan worden door een andere virtuele secondary DPM server. Er zijn 7 identieke servers en het probleem stelt zich enkel bij deze.
kroegtijger schreef op donderdag 23 augustus 2012 @ 17:26:
Deployment doe ik met SCCM. Maar zoals gezegd: er zijn DPM 7 machines uitgerold op deze manier (en 500+ andere) en enkel deze heeft het probleem, dus de basisimage wast zijn handen in onschuld
  • CaPuT
Kijk is of automount enabled is, zo niet, enable deze is.
diskpart -> automount
en dan evt automount enable
