Quake III Arena fout!
Ik kwou eff BFPen dus eff q3 op starten maar geeft ie ineens deze fout aan? :?
Q3 1.27g win-x86 Dec 4 2000
----- FS_Startup -----
Current search path:
E:\Quake III Arena\baseq3\pak5.pk3 (7 files)
E:\Quake III Arena\baseq3\pak4.pk3 (272 files)
E:\Quake III Arena\baseq3\pak0.pk3 (3539 files)
E:\Quake III Arena\baseq3\mapmedia.pk3 (76 files)
E:\Quake III Arena\baseq3\PAK3.PK3 (4 files)
E:\Quake III Arena\baseq3\PAK2.PK3 (148 files)
E:\Quake III Arena\baseq3\PAK1.PK3 (26 files)
E:\Quake III Arena/baseq3
4072 files in pk3 files
execing default.cfg
couldn't exec q3config.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\OS\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...25 PFDs found
...hardware acceleration found
...PIXELFORMAT 2 selected
...creating GL context: succeeded
...making context current: failed
...failed hard
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
----- CL_Shutdown -----
RE_Shutdown( 1 )
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...releasing DC: failed
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
Q_strncpyz: NULL src
WTF?!?! is dit?
Hier hebben we niks aan
Geen eens wat er in dat blauwe balkje bovenaan staat te knipperen??
Dat zal dit wel zijn :
  • Aikon
Ik weet niet wat t probleem precies is, maar de-installeer hem gewoon. Gooi alles van Q3A uit je register en installeer hem opnieuw. Kijken of íe dan werkt, of de laatste point-release installeren. Het is maar een idee...
Opstarten van cd-rom???
Laad ie hem van cdrom
Op dinsdag 27 maart 2001 21:30 schreef -polle- het volgende:
Volgens mij zegt ie dat altijd :P
Nee, zoals altijd, simply re-install q3, sla als je wil ff je q3config.cfg op, maar als je die na de install er weer overheen zet, sla nog ff de default op, zodat je hem altijd nog kan terugzetten als 't probleem 'em in je config zit ;)
