Winamp plugin om mix-MP3'z afspelen met trackslist
  • 170 views sinds 30-01-2008
Yo pplz...
voor iedereen die wel eens een lange mp3 heeft waarvan ook de .cuefile bijgesloten zit:
http://www.guerillasoft.com/mp3cue/index.html
daarmee kan je je lange mp3 gebruiken ' alsof het een cd is ' >:)
mp3cue winamp plugin
Want to listen to "mix CDs" in mp3 format? You're in the right place....
Before now, if you wanted to rip/encode such a CD you had two options:
Track based
You rip the CD into a bunch of wav files (one for each track), and encode them. There will be a gap between each track on playback, however. This is because mp3 decoders need a few frames to 'warm up'. You might use a crossfader to combat this... I personally rate the SqrSoft crossfader. However you sometimes lose some music at the transition between tracks...not much, but it can be noticeable.
Album based
You rip the whole CD as one mighty wav, then encode it as a single mp3. This is great, but you've lost all the track information!
Well, this plugin is the solution. You rip the CD as a single wav, encode it as normal (say as myfile.mp3). You create a .cue file from your CD (EAC does this, for example... why would you use any other ripper?) Call this cue file myfile.cue. Stick it in the same directory as myfile.mp3, and play the mp3 with winamp (with this plugin installed). The cue file will be detected, and the information extracted, and displayed...
:D 8-)
