Leuk Kassie
Niet slecht, dat is nog dunner dan mijn slimline desktop model [wat toch al nix is], maar is dat nou 2u ?
Hoeveel CM is dat? [jah sorry ik ben lui :+]
Anyway, wat wou je er mee zeggen?
Geef je ze gratis weg :D:D:D?
  • Pizzaman
Pizzaman
16:00 Cup-a-soup.
Voor de luie mensen: (FlameHeaD :))
Afbeeldingslocatie: http://www.elanvital.com.tw/products/servercases/r-20/graphics/R-20_s.jpg
Features
Six hotswap SCA drives or standard IDE drives
Supports standard or extended ATX boards up to 13inch deep
Optimal cooling characteristics through active and passive thermal design features
Basic Specifications
Dimensions:
height:
width:
depth:
2U
19inch
593.10mm
Drive bays:
6x SCA hotswap drive bays (when backplane installed)
(6x IDE drives also possible, no backplane necessary)
1x standard 5.25inch drive bay (for example DVD/CD-ROM)
1x slimline FDD drive bay
Mainboard:
Standard ATX or extended ATX, up to 13inch deep
Expansion slots:
3x PCI on risercard
System cooling:
- 1x 120mm high performance double ball bearing blower above CPU area
- 1x 80mm fan in PCI expansion port duct
For single powersupply option:
- 1x 80mm fan inside powersupply
- Optional 1x 80mm, 38mm width high performance fan between harddrive and powersupply area
For redundant powersupply option:
- 2x 92mm high performance double ball bearing blowers between harddrive and powersupply area, one blower each per powersupply module
CPU cooling :
HSAR01C passive heatsink for R-20
(part no. 60CHSAR0000000)
- includes: 1x heatsink
- Thermal support: up to at least 1GHz Pentium III
Please note:
a. for dual CPU systems, 2x HSAR01C can be used
b. when using the HSAR01C the standard provided 120mm high performance double ball bearing blower will provide abundant airflow for cooling the CPU(s)
Power Supply: Option 1: standard 300W powersupply
Option 2: ElanVital EVP-3056 redundant powersupply
For more information see EVR-3056 powersupply information
  • Bierkameel
Bierkameel
I use Debian btw
Wij leveren deze kasten :
Afbeeldingslocatie: http://members.home.nl/emike/Quote%20server.jpg
Dat is pas proppen om alles erin te krijgen want dit is een 1U dus nog een keer zo plat als die witte.
Er kunnen er 42 van in een 19" rack :)
Alle proemn in n drek
  • Femme
  • Laatst online: 00:41
Femme
Hardwareconnaisseur
Official Jony Ive fan
Hoe duur zijn die 1U rackjes?
Wacht maar tot de nieuwe procase kasten er zijn. Dan sta je helemaal te kwijlen.
Ze zouden op de Cebit geintroduceerd worden en daarna in de verkoop gaan.
  • Peerke
Peerke
Connection reset by Peerke
Op dinsdag 27 maart 2001 00:16 schreef sproggle het volgende:
http://www.procase.nl/ipcseries.htm#1u dus ... :)
Peerke in action >:)
Modjes in action !!
"Met drank maak je weer lief wat kapot is"
-- © 2
  • B-Man
Wou er niet al te veel mee zeggen :)
en nee, ik geef ze niet gratis weg...
Mijn hardware leverancier is volgende week dealer van elan vital, enne ik heb hier al Tyan Tiger 200 mobo'tjes liggen met CPU's en geheugen. Ik zocht nog een fatsoenlijke 2U kast met swappable 3,5" IDE slots... en dat heeft deze dus. Daarbij draai ik (persoonlijk) liever niet 2 x pIII 800 + 2 7200rpm HDD's in een 1U rackmount. En in een 2U rackmount heb je nog ruimte om er twee extra schijfjes bij te zetten.
Wat betreft proppen: was er laatst niet een artikel op t.net waarin een bedrijf 4 onafhankelijke server in een 1U rackmount had zitten (dus 4 x CPU, 4 x mem, 4 x HDD)...
  • The System
  • Laatst online: 30-09 00:12
bierkameel hoe duur zijn die 1u kastjes eruit?
* The System system- zou een hostingbedrijf beginnen alleen voor die kastjes al :9~
  • The System
