Ubuntu 12.04, vsFTPd 2.3.5, 530 Login incorrect.
  • Eagleman7
  • Laatst online: 08:26
Nadat ik mijn 11.10 Ubuntu server heb ge upgrade naar 12.04 kan ik niet meer inloggen met ftp op de server.
Status: Connecting to 192.168.1.10:21...
Status: Connection established, waiting for welcome message...
Response: 220 (vsFTPd 2.3.5)
Command: USER mijninlognaam
Response: 331 Please specify the password.
Command: PASS *******
Response: 530 Login incorrect.
Error: Critical error
Error: Could not connect to server
De config file is nog hetzelfde als voor de installatie:
# Example config file /etc/vsftpd.conf
# The default compiled in settings are fairly paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Please see vsftpd.conf.5 for all compiled in defaults.
# READ THIS: This example file is NOT an exhaustive list of vsftpd options.
# Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
# capabilities.
# Run standalone? vsftpd can run either from an inetd or as a standalone
# daemon started from an initscript.
listen=YES
pasv_enable=YES
pasv_max_port=51000
pasv_min_port=50000
port_enable=YES
# Run standalone with IPv6?
# Like the listen parameter, except vsftpd will listen on an IPv6 socket
# instead of an IPv4 one. This parameter and the listen parameter are mutually
# exclusive.
#listen_ipv6=YES
# Allow anonymous FTP? (Disabled by default)
anonymous_enable=NO
# Uncomment this to allow local users to log in.
local_enable=YES
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# Uncomment this if you want the anonymous FTP user to be able to create
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# If enabled, vsftpd will display directory listings with the time
# in your local time zone. The default is to display GMT. The
# times returned by the MDTM FTP command are also affected by this
# option.
use_localtime=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format.
# Note that the default log file location is /var/log/xferlog in this case.
#xferlog_std_format=YES
# You may change the default value for timing out an idle session.
#idle_session_timeout=600
# You may change the default value for timing out a data connection.
#data_connection_timeout=120
# It is recommended that you define on your system a unique user which the
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that on some FTP servers, ASCII support allows a denial of service
# attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
# predicted this attack and has always been safe, reporting the size of the
# raw file.
# ASCII mangling is a horrible feature of the protocol.
#ascii_upload_enable=YES
#ascii_download_enable=YES
# You may fully customise the login banner string:
#ftpd_banner=Welcome to blah FTP service.
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may restrict local users to their home directories. See the FAQ for
# the possible risks in this before using chroot_local_user or
# chroot_list_enable below.
chroot_local_user=YES
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
#chroot_local_user=YES
#chroot_list_enable=YES
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
# Debian customization
# Some of vsftpd's settings don't fit the Debian filesystem layout by
# default. These settings are more Debian-friendly.
# This option should be the name of a directory which is empty. Also, the
# directory should not be writable by the ftp user. This directory is used
# as a secure chroot() jail at times vsftpd does not require filesystem
# access.
secure_chroot_dir=/var/run/vsftpd/empty
# This string is the name of the PAM service vsftpd will use.
pam_service_name=vsftpd
# This option specifies the location of the RSA certificate to use for SSL
# encrypted connections.
rsa_cert_file=/etc/ssl/private/vsftpd.pem
Ik heb zelf al wat zitten googlen maar omdat 12.04 pas net uit is heb ik niks kunnen vinden wat werkte.
Iemand die mij zou kunnen helpen?
  • Kees
  • Laatst online: 21-10 17:44
Kees
Serveradmin / BOFH / DoC
Staat er wat in de log files
En is ftp perse noodzakelijk? FTP is aan archaisch protocol dat met vuur en zwaard bestreden dient te worden.
  • Eagleman7
Kees schreef op vrijdag 27 april 2012 @ 18:09:
Fri Apr 27 17:42:29 2012 [pid 2] CONNECT: Client "192.168.1.15"
Fri Apr 27 17:42:31 2012 [pid 1] [gebruiker] FAIL LOGIN: Client "192.168.1.15"
Welk protocol is dan beter volgens jou?
[ Voor 5% gewijzigd door Eagleman7 op 27-04-2012 18:49 ]
  • Kees
Kees
sftp ('ssh ftp') is al een stuk veiliger en werkt vaak veel beter.
Maar er staat niets verder in de auth/syslogs/daemonlogs? Zie je wat als je de daemon op de voorgrond start met debugging aan?
  • Eagleman7
Heb nog niet zo heel veel ervaring met Linux, zou je kunnen zeggen hoe ik dit doe?
[ Voor 27% gewijzigd door Eagleman7 op 27-04-2012 20:44 ]
  • 0xDEADBEEF
Nee, GoT is geen helpdesk :> http://linux.die.net/man/5/vsftpd.conf zoeken naar 'background'.
"Religion is an insult to human dignity. With or without it you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg
