[ubuntu] dpkg laat een pakket unconfigured
  • Boudewijn
Boudewijn
omdat het kan
Hoi
Ik draai atm ubuntu 12.04 beta en heb wat gespeeld met foreman en foreman-mysql , maar hierbij halverwege afgebroken bij het database instellen, dit omdat ik dit toch met de hand wilde doen.
Nu krijg ik bij elk pakket dat ik wil installeren:
29
30
31
32
root@bfl:/var/log# apt-get install foreman foreman-proxy foreman-mysql isc-dhcp-server bind9 tftpd-hpa
Reading package lists... Done
Building dependency tree
Reading state information... Done
bind9 is already the newest version.
isc-dhcp-server is already the newest version.
tftpd-hpa is already the newest version.
foreman is already the newest version.
foreman-mysql is already the newest version.
foreman-proxy is already the newest version.
The following packages were automatically installed and are no longer required:
  libaccess-bridge-java libgucharmap7 libx264-116 libmagickcore3 wine1.3 libmagickwand3 ttf-sil-gentium libiso9660-7 libreoffice-report-builder-bin libdbd-mysql-ruby1.8
  libdeprecated-ruby1.8 lib32nss-mdns libaccess-bridge-java-jni libvpx0 libmatroska4 libjpeg62:i386 libmusicbrainz4c2a libmagickcore3-extra libdbi-ruby1.8 libllvm2.9:i386
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]?
Setting up foreman (0.4.2-1) ...
dbconfig-common: writing config to /etc/dbconfig-common/foreman.conf
dpkg: error processing foreman (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of foreman-mysql:
 foreman-mysql depends on foreman; however:
  Package foreman is not configured yet.
dpkg: error processing foreman-mysql (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
        Errors were encountered while processing:
 foreman
 foreman-mysql
E: Sub-process /usr/bin/dpkg returned an error code (1)
Negeer de extra crap maar.
apt-get -f install werkt niet, dat faalt op hetzelfde punt. Ook dpkg-reconfigure en het verwijderen en herinstalleren van het pakket helpt niet. Als ik die pakketten purge en daarna reinstall krijg ik alsnog dit:
Creating config file /etc/foreman/database.yml with new version
 foreman
 foreman-mysql
root@bfl:/var/log#
Ik ben een beetje uitgekakt, weet iemand waar dit door kan komen?
  • Kees
  • Laatst online: 22-10 15:43
Kees
Serveradmin / BOFH / DoC
En wat als je /var/lib/dpkg/info/foreman-*.postint edit/handmatig uitvoert / exit 0 bovenaan zet?
  • Boudewijn
Boudewijn
omdat het kan
Yuk wat een vieze hack... maar het werkt wel. Thanks voor de tip :).
