• Ryan1981
  • Laatst online: 18-11 07:51
Ryan1981
Je ne sais pas
BlueTimes BT3584D 3D & Android Media Speler
Afbeeldingslocatie: http://s19.postimage.org/pcwsjjlg3/3584_D1186_2.jpg
Intro
Dit topic is bedoeld om over de BlueTimes BT3584D 3D & Android Media Speler. Als iemand zich geroepen voelt mede eigenaar te worden van dit topic en weet hoe dit moet dan hoor ik het wel.
Inhoudsopgave
Specificaties
Product Main Features
Model nameBT3584D
System
CPURTD1186
Frequency750MHZ
RAM512MB DDR3
Flash4G Byte NAND FLASH
OSLinux & Android2.2
File System
TypeReadWrite
NTFSYESYES
FAT32YESYES
EXT3YESYES
HFSYESYES
UDF 2.5YESNO
ISO 9660YESNO
Interface
USB host3 * USB HOST (1 USB 3.0; 2 USB 2.0)
SD Card1 * SD slot
RJ451 * Gigabit Lan
AV1 * AV out
Ypbpr1 * Ypbpr out
HDMI1 * HDMI 1.4 out
Optical1 * Optical (Digital 5.1)
Coaxial1 * Coaxial (Digital 5.1)
VoltageInput: 100-240V Output: 5V/2A
Dimension
Products Size14.9(L)x10.9(W)x 2.7(H) cm
Specification
UIStylish 3D-View UI design
Video FormatsMKV,TS,M2TS,TP,WMV,IFO, ISO, VOB, DAT, AVI, MPG,MP4,MOV, RM, RMVB, FLV etc
Video Formats (Codecs)MPEG-1 / MPEG-2 / MPEG-4 SP /ASP /AVC (H.264) / XviD / DivX / WMV9 (VC-1) / RealVideo 8/9/10 (up to 720P)
Video Extensions (Containers)AVI / BDMV Light / BD-ISO Light / MKV / TS / TP / TRP / M2TS / MPG / MP4 / MOV / M4V / VOB / ISO / IFO / DAT / WMV / ASF / RM / RMVB / FLV
OthersDVD ISO (original menus)
Terug naar de inhoudsopgave
Chip Features
Let op, niet elke feature is geïmplementeerd op dit model, dit is enkel om aan te geven wat de chip aankan,
RTD1186
HD MPEG1/2/4, H.264/H.264 MVC, AVC/VC1, RM/RMVB, AVS Decoder with 10/100/1000M Ethernet, PCIe, Card Reader, and HDMI
General Description
The RTD1186 is a highly integrated SoC for Consumer Electronics products requiring High Definition Media Playback, Wireless/Wired Networking, Mass Storage, and DTV capabilities
Features
CPU: 750MHz
GPU: OpenGL ES2.0-compliant 3D GPU
HD MPEG1/2/4/H.264/H.264 MVC & HD JPEG Decoder
HD AVC/VC-1 Decoder
HD RM/RMVB Decoder
HD AVS Decoder
AV Streaming/Transmission via Ethernet & Wi-Fi
TV Encoder with CVBS/S-Video/YPbPr/SCART Out
HDMI v1.4 with CEC and support for 3D over HDMI
I2S, SPDIF Out
Dual USB 2.0 Host or one USB 2.0 Host/Device with dual port integrated PHY, USB 3.0 Host/Device
SATA
10/100 Ethernet MAC & PHY
Gigabit Ethernet MAC
PCI-Express
Card Reader (SD/MMC/MS Pro)
DTV Recording & Time-Shifting
Dual TS-In
Applications
HDD Media Player
Digital Media Adaptor/Server
Networked Media Module for Embedded CE device
Networked STB with PVR
In de doos
BT3584D Speler
EU stroom kabel
Input 100-240VAC, 50-60Hz, 1.2A; Output 12.0V DC 3000mA
A/V Kabel (3.5mm plug to 3 tulp rood/wit/geel)
SATA data+voedings Kabel
Afstandsbediening
2 AAA batterijen
Handleiding (engels)
Reclame folder
Reviews
AVForum
Mijn eigen review
FAQ
Q: Heeft deze speler de Realtek 24P bug?
A: Ja, zelf getest en heb idd iets waargenomen. 24P bug in het kort is een dubbel frame elke 41.7 secondes.
Q: Hoe werkt bittorent?
A: Deze speler heeft 2 bittorrent clients. Je kunt deze clients individueel aanzetten (maar niet allebij tegelijk)
De eerste is een simpele client die neighbor web heet. Deze client is onderdeel van linux samba. Ik heb een mooie beschrijving gevonden hier. Deze client is vrij eenvoudig. Je opent een browser op een PC, typt het netwerk adres van de speler als volgt in: b.v. http://192.168.1.50/unicgi en je krijgt een interface waar je de torrent op de locale PC kunt uploaden en de schijf van de speler kunt kiezen waar je de torrent wil downloaden. Daarna kun je voortgang op de browser zien en de torrents beheren. Het netwerk adres van de speler wordt in het instellingen menu weergegeven.
De 2e bittorrent client is een PT Transmission client. De website voor deze client is hier te vinden. Voor deze client is wat extra configuratie nodig om hem naar de correcte locatie te laten downloaden omdat er (nog) geen schijf selectie ingebouwd zit. Je kan het correcte pad vinden om naar toe te downloaden via de OI file manager in android. Kies hier de Home button links bovenin en navigeer naar de disk waar je de torrent wil downloaden. Gebruik dit pad in de web interface. In mijn geval heb ik: "/tmp/usbmounts/sdc1/BT" gebruikt. Hou er rekening mee dat dit hoofdletter gevoelig is. De webinterface is te benaderen door het volgende adres in te typen (wordt in de speler onderaan aangegeven wanneer deze optie in instellingen geselecteerd is) b.v. http://192.168.1.50:9091. Het pad dat je zojuist gevonden hebt kun je invullen door links onderin de web interface te klikken op het configuratie icoontje en daar te kiezen voor preferences en dan in de eerste tab in "download to" neer te zetten. Dan save klikken en je bent klaar om een lokaal torrent bestand of link up te loaden. Zodra je hem geupload hebt klik je 1 keer op refresh en hij wordt weergegeven.
Q: Werkt uitzending gemist app in android
A: Op moment van schrijven heb ik geen losse APK kunnen vinden om te proberen te installeren dus is het antwoord nee.
Foto's
De kleinere thumbnails kan op geklikt worden voor een grotere versie.
Afbeeldingslocatie: http://s19.postimage.org/j2d6dpob3/Box.jpgAfbeeldingslocatie: http://s19.postimage.org/bnnulc2fj/Open_Box.jpg|Afbeeldingslocatie: http://s19.postimage.org/w92md8k0f/In_the_box.jpg
Afbeeldingslocatie: http://s19.postimage.org/f9y9bpy6n/Player_Front_OFF.jpgAfbeeldingslocatie: http://s19.postimage.org/i5bcil26n/Player_USB_side.jpgAfbeeldingslocatie: http://s19.postimage.org/64pwhuurz/Player_Backside.jpg
Afbeeldingslocatie: http://s19.postimage.org/l1ydiv80f/Player_Drive_HD_side.jpgAfbeeldingslocatie: http://s19.postimage.org/3py0xfej3/Player_bottom.jpgAfbeeldingslocatie: http://s19.postimage.org/lh9nbvtxr/Player_Front_ON.jpg
Afbeeldingslocatie: http://s19.postimage.org/prob7gz0v/Remote.jpg
Youtube
Handige Links
Website van fabrikant
Realtek Chip fabrikant link
Topic in AVForums
Changelog
1) Toevoegen Q&A Bittorent & Uitzending gemist.
2) Toevoegen youtube review
[ Voor 11% gewijzigd door Ryan1981 op 25-04-2012 11:32 ]
  • Michael Knight
  • Laatst online: 19:04
Michael Knight
Moderator Consumentenelektronica
KITT, I need you buddy!
Nette topicstart. Ben benieuwd wanneer we het dingetje in de (web)winkels kunnen gaan zien hier. Als de prijs aantrekkelijk is, kan het een leuk speeltje zijn voor Bittorent/streaming apps etc. :)
(Zeldzame) retrogames en meer --> Aangeboden op V&A
  • Ryan1981
Ryan1981
Je ne sais pas
Bedankt! Zelf heb ik niet zo veel kennis van linux e.d. maar ik denk dat deze speler vrij open is en het mogelijk makkelijk toelaat zelf wijzigingen aan te brengen. Zodra de volgende firmware uit is zal ik die linken voor mensen die geinteresseerd zijn. Of er veel support komt voor deze realtek chip kan ik niet voorspellen natuurlijk maar het ziet er veelbelovend uit. Wellicht komt er in de toekomst een port van XMBC e.d. maar voorlopig eerst maar eens kijken of bluetimes hun product in NL gaan verkopen.
  • Ryan1981
Ryan1981
Je ne sais pas
Belangrijk nieuws voor dit type media spelers op de tweakers hoofdpagina:
nieuws: 'Google gaat Android voor MIPS-architectuur ondersteunen'
Ik weet niet precies wat dit betekend voor android compatibility van apps maar het lijkt me dat het beter wordt? Verbeter me maar als ik er naast zit.
[ Voor 31% gewijzigd door Ryan1981 op 17-04-2012 14:42 ]
  • joey6666
  • Laatst online: 23-04 18:02
Er is een gast op marktplaats die een broertje van dit model verkoopt, de BT-3550B http://3dhdplayer.jouwweb.nl
