[MySQL] Query met veel sortering versnellen
  • bindsa
Ik heb een query die vrij veel moet sorteren en ook nog wat joins nodig heeft, en daardoor redelijk traag wordt:
SQL:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
SELECT accounts.*, sys_provinces.name AS province_name, sys_cities.name AS city_name, sys_cities.province_id AS province_id, c2.cnt AS cnt
FROM (accounts)
LEFT JOIN (
    SELECT 1 as vip_city, city_id
    FROM accounts AS accs_2
    WHERE account_type_id = 1
    AND accs_2.state = 1
    AND accs_2.accepted = 1
    AND accs_2.activated = 1
) AS accs_2
ON accounts.city_id = accs_2.city_id
JOIN sys_cities
ON sys_cities.id = accounts.city_id
JOIN (
    SELECT city_id, COUNT(city_id) AS cnt
    FROM accounts
    WHERE accounts.state = 1
    AND accounts.activated = 1
    AND accounts.accepted = 1
    GROUP BY city_id
) AS c2
ON c2.city_id = accounts.city_id
LEFT JOIN (
    SELECT place_id AS rating_acc,count(rating1) AS cnt_ratings_abs, sum(round((rating1+rating2+rating3+rating4)/4, 1))/count(rating1) AS cnt_ratings
    FROM ratings
    GROUP BY ratings.place_id) AS ratings
ON accounts.id = ratings.rating_acc
LEFT JOIN sys_provinces
ON sys_provinces.id = sys_cities.province_id
WHERE (accounts.state = 1
AND accounts.accepted = 1)
ORDER BY
    vip_city desc,
    c2.cnt desc,
    city_id desc,
    FIELD(accounts.account_type_id, 1) desc,
    ratings.cnt_ratings_abs desc,
    ratings.cnt_ratings desc,
    accounts.company_name
Relevante indexes:
accounts.account_type_idNormalBTREE
accounts.city_idNormalBTREE
accounts.activatedNormalBTREE
accounts.stateNormalBTREE
accounts.acceptedNormalBTREE
accounts.activated,accounts.state,accounts.acceptedNormalBTREE
ratings.place_idNormalBTREE
sys_cities.province_idNormalBTREE
accounts.company_nameNormalBTREE
Explain:
SQL:
1   PRIMARY <derived3>  ALL                 223 Using temporary; Using filesort
1   PRIMARY accounts    ref city_id,activated,accepted,state,state_2,state_3    city_id 9   c2.city_id  2   Using where
1   PRIMARY <derived2>  ALL                 1
1   PRIMARY <derived4>  ALL                 4
1   PRIMARY sys_cities  eq_ref  PRIMARY,id  PRIMARY 4   theme_system.accounts.city_id   1   Using where
1   PRIMARY sys_provinces   eq_ref  PRIMARY PRIMARY 4   theme_system.sys_cities.province_id 1
4   DERIVED ratings index       place_id    9       5
3   DERIVED accounts    ref activated,accepted,state,state_2,state_3    activated   1       488 Using where; Using temporary; Using filesort
2   DERIVED accs_2  ref account_type_id,activated,accepted,state,state_2,state_3    account_type_id 4       1   Using where
En ook een query die de postcodes in een range zoekt:
SQL:
SELECT DISTINCT city_id
FROM sys_postal_codes
WHERE
    ROUND(
        ( 6378136 * acos( cos( radians( 52.273300 ) )
        * cos( radians( sys_postal_codes.lat ) )
        * cos( radians( sys_postal_codes.lng ) - radians( 5.243605 ) )
        + sin( radians( 52.273300 ) )
        * sin( radians( sys_postal_codes.lat ) ) ) ) < '15000'
        ORDER BY ROUND(
        * sin( radians( sys_postal_codes.lat ) ) ) ))
LIMIT 20
Deze duurt ong. 1.5 sec. Relevante indexes die ik geplaatst heb:
sys_postal_codes.nameNormalBTREE
sys_postal_codes.latNormalBTREE
sys_postal_codes.lngNormalBTREE
Explain:
SQL:
1 SIMPLE sys_postal_codes ALL 650430 Using where; Using temporary; Using filesort
Hebben jullie enig idee hoe deze queries verder te optimaliseren zijn?
  • frickY
  • Laatst online: 18-11 15:40
Mogelijk met denormalisatie.
Zorg dat je geen berekeningen of aggregaties op kolommen hoeft te doen waarop je wilt sorteren, zodat je daar (bruikbare) indexen op kunt plaatsen.
Een quick-win kan zijn om je sort buffers en temporary table size te verhogen. In je explain zie je nu 2x een filesort. Het zal ook al schelen als hij dat in memory kan doen.
[ Voor 35% gewijzigd door frickY op 09-04-2012 15:51 ]
  • Voutloos
Voutloos
Die laatste query is wel heel makkelijk te fixen door een bounding box (zoekterm voor kant en klare oplossingen) in je where clause toe te voegen. Dwz een grof vierkant gebied waarvoor wel indexes gebruikt kunnen worden.
{signature}
  • bindsa
In die richting zat ik zelf ook al te denken, ik hoopte dat ik nog ergens mijn joins etc. kon optimaliseren. In ieder geval bedankt, ik ga de relevante triggers aanmaken en een bounding box toevoegen.
  • GlowMouse
GlowMouse
Ik snap je query niet goed. Wat doet de join op regel 4-15, wat doet de GROUP BY op regel 40, en wat doet de FIELD op regel 45?
frickY schreef op maandag 09 april 2012 @ 15:49:
gebeurt dat nu niet?
  • bindsa
GlowMouse schreef op maandag 09 april 2012 @ 18:29:
4-15: Ik wil gaan orderen op bepaalde steden, namelijk de steden die VIP accounts hebben. Daarom doe ik een subquery in de join die een 1 selecteerd als de stad één of meerdere VIP accounts heeft, en omdat ik LEFT JOIN zal de rest null geven. En dus werkt ORDER BY vip_city precies zoals de bedoeling is.
De FIELD sorteert eerst op records waarbij account_type_id = 1 en daarna volgt de rest.
De GROUP BY was een foutje en heb ik weggehaald (Deze query wordt dynamisch gegenereerd, en ik had in de gauwigheid de verkeerde stukken aan elkaar geplakt.
