file contents match foreach loop
  • MarcHeijerman
  • Laatst online: 11-05 12:27
Hi all,
ik zit met een klein issue, waar ik even niet uitkom. wanneer ik vmrun, run (Linux), worden de resultaten naar een bestand weggeschreven. Hierna lees ik dit bestand uit, en match ik op hostnames om zo de vm's per esx hosts te krijgen.
hier een voorbeeld:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
<?php
// list unique esx hosts \\
shell_exec("vmrun -h <hosts> -u <user> -p <password> list | cut -d'/' -f2 | cut -d']' -f1 | cut -d':' -f1 | egrep -v '(<string>|<string>)' | grep -i <string>  > /var/log/vm/vlist");
$hostfile=file("/var/log/vm/vlist");
$hostfile=array_unique($hostfile);
asort($hostfile);
$esxhosts=count($hostfile);
// Get total vm's from file \\
shell_exec("vmrun -h <host> -u <user> -p <password> list > /var/log/vm/list");
$number_of_vms=shell_exec("cat /var/log/vm/vlist | wc -l");
$max_vm_per_host=25;
$max_vm_total=$max_vm_per_host*$esxhosts;
$vms_left=$max_vm_total-$number_of_vms;
        print "<table align='center' border='1' cellpadding='3' cellspacing='0'>";
        print "<tr><td colspan='2'><b><ENV>: <...> environment</b></td></tr>";
        print "<tr><td>Total ESX hosts: </td><td>".$esxhosts."</td></tr>";
        print "<tr><td>Number of VM's: </td><td>$number_of_vms</td></tr>";
        print "<tr><td>Max VM's for <env>: </td><td>$max_vm_total</td></tr>";
        print "<tr><td>VM's left</td><td>$vms_left</td></tr>";
        print "</table><br>";
///// Main Table \\\\\\
    print "<table align='center' border='1' cellpadding='3' cellspacing='0' >";
$count=1;
foreach($hostfile as $host) {
    // find all instances of $host from $file
    $host=trim($host); // remove any white space from $host.
    $file=file_get_contents('/var/log/vm/list') or die($php_errormsg);
    $numvms=substr_count($file,$host );
    if($numvms < 20){
                print "<tr><td bgcolor=#AFDCEC>$count: </td><td bgcolor=#C3FDB8><a href=\"scripts/hostid.php?id=".$host."\" target=\_blank\">".htmlspecialchars($host)."</a></td><td bgcolor='#C3FDB8'align='left'>total vm's: $numvms</td></tr>";
        } elseif($numvms < 24) {
                print "<tr><td bgcolor=#AFDCEC>$count: </td><td bgcolor=#C3FDB8><a href=\"scripts/hostid.php?id=".$host."\" target=\_blank\">".htmlspecialchars($host)."</a></td><td bgcolor='orange'align='left'>total vm's: $numvms</td></tr>";
        } elseif($numvms > 24) {
                print "<tr><td bgcolor=#AFDCEC>$count: </td><td bgcolor=#C3FDB8><a href=\"scripts/hostid.php?id=".$host."\" target=\_blank\">".htmlspecialchars($host)."</a></td><td bgcolor='red'align='left'>total vm's: $numvms</td></tr>";
$count++;
    print "</table>";
Dit werkt, alleen wordt er 1 esx host niet weergegeven, ik heb de file vlist bekeken, en alle esxhosts staan netjes onder elkaar. Voor alle andere esx hosts wordt er dus gezocht naar het aantal matches voor $host in /var/log/vm/list, en wordt het aantal vm's per esx host gewoon aangegeven, op 1 na dus, deze esx host wordt ook totaal niet weer gegeven op de pagina.
dmv $count kan ik goed zien welke er wordt weggelaten:
1: host1
2: host2
3: host3
4: host4
5: host5
7: host7
8: host8
etc etc
host 6 wordt hier dus weggelaten, terwijl hij wel degelijk in de lijst voorkomt.
Wanneer ik trim aanpas naar:
PHP:
$host=trim($host, "\n"); // remove any white space from $host
worden wel alle esx hosts weergegeven (inclusief nr 6 dus), alleen nu zijn er geen matches meer voor het aantal vm's per host...
Heb trim op verschillende manieren getest, ik heb geprobeerd de file anders uit te lezen, maar krijg dan errors als: array to string conversion etc.
De file is gewoon 1 lange lijst met hosts, en op de manier zoals ik hem nu uitlees, werkt het niet helemaal goed.
Is er een andere mogelijkheid, om dit op een nette manier op te lossen ?
p.s. Ben geen php guru ofzo, ben ook nog aan het leren :-)
  • MarcHeijerman
FYI
problem solved.
Zat hem in de elseif en elseif, de laatste elseif heb ik vervangen door else, alle hosts met exact 24 instances werden genegeerd.
  • Voutloos
Ja, en nog enkel die if/else om enkel een $class string op low/medium/high te zetten (of kleurtje als semantiek je echt niet boeit) en zodoende niet meer een hele lap html 3x te hebben staan.
{signature}
  • MarcHeijerman
Voutloos schreef op dinsdag 03 april 2012 @ 13:37:
Het werkt ondertussen allemaal naar behoren :D, is nog een aardig tooltje geworden.
  • Guillome
Guillome
test
Heb je ook gedaan wat Voutloos aangaf?
If then else matters! - AMD 9800X3D, Gigabyte Gaming OC 16G 5080 RTX, MSI MAG B850, 32GB DDR5, Corsair RM850X PSU, SN850 1TB, Arctic Liquid Freezer 280, TP-Link AXE5400 Wi-Fi 6E Router
  • MarcHeijerman
Guillome schreef op dinsdag 03 april 2012 @ 18:13:
Zou ik daar iets meer uitleg over kunnen krijgen, snap even niet wat er precies gezegd wordt over die if else loop.
  • Guillome
Guillome
test
Je doet 3 keer een echo van een hele lange htmlstring. Enig verschil is je classname of style. En daar gebruik je nu een if elseif else voor met 3 keer dezelfde string.
Doe beter een switch en een variabele met de classname of style, en gebruik die
  • MarcHeijerman
Guillome schreef op woensdag 04 april 2012 @ 11:28:
Ok, even kijken hoe zo'n switch werkt, nog niet gedaan in php, zal wel moeten lukken neem ik aan :-)
  • Guillome
Guillome
test
Ja das niet zo moeilijk :) Maar het gaat voornamelijk om de rest van het verhaaltje
  • MarcHeijerman
Alles gefixed :-), tool werkt goed. Thanks for the replies.
