Ik heb onderhand een boot tijd van ruim 3 minuten voor ik überhaupt wat kan doen. Vroeger was dat altijd maximaal 30 seconden tot 1 minuut. Uit de log zie ik wel rare dingen alleen ik heb geen idee wat ze betekenen en ik kan er ook verder niets over vinden... Ik heb een aantal zaken in de log benadrukt.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
23-03-12 10:14:12   com.apple.launchd[1]    *** launchd[1] has started up. ***
23-03-12 10:14:20   mDNSResponder[17]   mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) starting
23-03-12 10:14:20   configd[14] setting hostname to "MacBook-Pro-Anton.local"
23-03-12 10:14:20   configd[14] network configuration changed.
23-03-12 10:14:21   configd[14] network configuration changed.
23-03-12 10:14:21   blued[16]   Apple Bluetooth daemon started
23-03-12 10:14:26   com.apple.launchd[1]    (com.vmware.launchd.vmware[52]) posix_spawn("/Library/Application Support/VMware Fusion/boot.sh", ...): No such file or directory
23-03-12 10:14:26   com.apple.launchd[1]    (com.vmware.launchd.vmware[52]) Exited with exit code: 1
23-03-12 10:14:34   bootlog[48] BOOT_TIME: 1332494052 0
23-03-12 10:14:37   com.freemacsoft.appcleanerd[55] Appcleanerd started successfully.
23-03-12 10:14:37   Parallels[68]   Unloading kernel extension prl_netbridge.kext
23-03-12 10:14:37   com.apple.usbmuxd[30]   usbmuxd-268.5 on Jan  5 2012 at 03:34:01, running 64 bit
23-03-12 10:14:37   _usbmuxd[93]    audit warning: closefile /var/audit/20120323091415.20120323091437
23-03-12 10:14:37   _usbmuxd[94]    audit warning: soft /var/audit
23-03-12 10:14:37   _usbmuxd[95]    audit warning: allsoft
23-03-12 10:14:37   Parallels[98]   Unloading kernel extension prl_vnic.kext
23-03-12 10:14:37   Parallels[107]  Unloading kernel extension prl_usb_connect.kext
23-03-12 10:14:40   Parallels[116]  Unloading kernel extension prl_hid_hook.kext
23-03-12 10:14:40   Parallels[125]  Unloading kernel extension prl_hypervisor.kext
23-03-12 10:14:40   Parallels[134]  Loading kernel extension prl_usb_connect.kext
23-03-12 10:14:44   /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[37] Login Window Application Started
23-03-12 10:14:45   Parallels[151]  Loading kernel extension prl_hypervisor.kext
23-03-12 10:14:45   Parallels[158]  Loading kernel extension prl_hid_hook.kext
23-03-12 10:14:45   Parallels[165]  Loading kernel extension prl_netbridge.kext
23-03-12 10:14:45   Parallels[172]  Loading kernel extension prl_vnic.kext
23-03-12 10:14:45   Parallels[178]  Trying to load kernel extensions, exit status: 0
23-03-12 10:14:45   Parallels[181]  Starting Parallels networking...
23-03-12 10:14:46   Parallels[193]  Parallels networking sucessfully started
23-03-12 10:14:46   /Library/Parallels/Parallels Service.app/Contents/PlugIns/Parallels NAPT Service.app/Contents/MacOS/prl_naptd[190]  Starting Parallels Network Daemon
23-03-12 10:14:46   Parallels[195]  Restarting CiscoVPN
23-03-12 10:14:46   SystemStarter[197]  Unknown service: CiscoVPN
23-03-12 10:14:46   Parallels[201]  Starting Parallels Dispatcher Service
23-03-12 10:14:46   Parallels[205]  Parallels Dispatcher Service sucessfully started
23-03-12 10:14:46   /Library/Parallels/Parallels Service.app/Contents/PlugIns/Parallels NAPT Service.app/Contents/MacOS/prl_naptd[190]  vnic0: DHCP/NAT for 10.211.55.1-10.211.55.254 netmask 255.255.255.0
23-03-12 10:14:46   /Library/Parallels/Parallels Service.app/Contents/PlugIns/Parallels NAPT Service.app/Contents/MacOS/prl_naptd[190]  vnic1: DHCP for 10.37.129.1-10.37.129.254 netmask 255.255.255.0
23-03-12 10:14:46   com.apple.launchctl.LoginWindow[209]    launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
23-03-12 10:14:46   loginwindow[37] Login Window Started Security Agent
23-03-12 10:14:46   WindowServer[145]   kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
23-03-12 10:14:46   com.apple.WindowServer[145] Fri Mar 23 10:14:46 MacBook-Pro-Anton.local WindowServer[145] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
23-03-12 10:14:51   Firewall[80]    krb5kdc is listening from :::88 proto=6
23-03-12 10:14:51   Firewall[80]    krb5kdc is listening from 0.0.0.0:88 proto=6
23-03-12 10:14:58   loginwindow[37] Login Window - Returned from Security Agent
23-03-12 10:14:58   loginwindow[37] USER_PROCESS: 37 console
23-03-12 10:14:58   com.parallels.vm.prl_naptd[190] QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
23-03-12 10:14:58   com.parallels.vm.prl_naptd[190] QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
23-03-12 10:14:58   com.apple.launchctl.Background[222] launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
23-03-12 10:14:58   com.apple.launchctl.Aqua[223]   launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
23-03-12 10:14:58   com.apple.launchctl.Aqua[223]   launchctl: Dubious permissions on file (skipping): /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
23-03-12 10:14:58   com.apple.launchd.peruser.501[221]  (com.divx.agent.postinstall) Unknown key: LimitToSessionType
23-03-12 10:14:58   com.apple.launchd.peruser.501[221]  (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
23-03-12 10:15:01   configd[14] network configuration changed.
23-03-12 10:15:05   Firewall[80]    krb5kdc is listening from :::88 proto=6
23-03-12 10:15:05   Firewall[80]    krb5kdc is listening from 0.0.0.0:88 proto=6
23-03-12 10:15:06   /Library/Parallels/Parallels Service.app/Contents/PlugIns/Parallels NAPT Service.app/Contents/MacOS/prl_naptd[248]  Starting Parallels Network Daemon
23-03-12 10:15:06   com.parallels.vm.prl_pcproxy[248]   QKqueueFileSystemWatcherEngine::addPaths: open: No such file or directory
23-03-12 10:15:06   com.parallels.vm.prl_pcproxy[248]   QFileSystemWatcher: failed to add paths: /Library/Managed Preferences
23-03-12 10:15:10   com.apple.launchd.peruser.501[221]  (com.apple.Kerberos.renew.plist[244]) Exited with exit code: 1
23-03-12 10:15:12   Adobe Reader Updater Helper[258]    Adobe Reader Updater encountered errorCode 260
23-03-12 10:15:13   Adobe Reader Updater Helper[258]    Adobe Reader Updater encountered errorCode 1001
23-03-12 10:15:20   loginwindow[37] Login items - LSOpenApplication returned error -10825, url=/Applications/Snippets.app/Contents/MacOS/SnippetsAssistant.app
23-03-12 10:15:20   loginwindow[37] Unable to lauch startup item: (null)
23-03-12 10:15:21   sudo[268]   root : TTY=unknown ; PWD=/ ; USER=Anton ; COMMAND=/bin/launchctl load /Library/LaunchAgents/com.parallels.vm.prl_pcproxy.plist
23-03-12 10:15:25   sudo[290]   root : TTY=unknown ; PWD=/ ; USER=Anton ; COMMAND=/bin/launchctl start com.parallels.vm.prl_pcproxy
23-03-12 10:15:29   macfusionAgent[269] Main bundle path  /Applications/Macfusion.app
23-03-12 10:15:31   macfusionAgent[269] Loaded plugin at path /Applications/Macfusion.app/Contents/PlugIns/ftpfs.mfplugin OK: org.mgorbach.macfusion2.ftpfs
23-03-12 10:15:32   macfusionAgent[269] Loaded plugin at path /Applications/Macfusion.app/Contents/PlugIns/sshfs.mfplugin OK: org.mgorbach.macfusion2.sshfs
23-03-12 10:15:32   macfusionAgent[269] Could not read recents from file at path /Users/Anton/Library/Application Support/Macfusion/recents.plist
23-03-12 10:15:36   SystemUIServer[226]     MenuCracker 2.2 (/Library/Application Support/iStat local/extras/MenuCracker.menu)
    See http://sourceforge.net/projects/menucracker
    MenuCracker is now loaded. Ready to accept new menu extras.
23-03-12 10:15:36   SystemUIServer[226] failed to instantiate and get the principal class of bundle: NSBundle </Library/Application Support/iStat local/extras/MenuCracker.menu> (loaded)
23-03-12 10:15:37   SystemUIServer[226] MenuCracker: Allowing "iStatMenusDateAndTimes".
23-03-12 10:15:39   SystemUIServer[226] MenuCracker: Allowing "iStatMenusBattery".
23-03-12 10:15:41   SystemUIServer[226] MenuCracker: Allowing "iStatMenusCPU".
23-03-12 10:15:41   SystemUIServer[226] MenuCracker: Allowing "iStatMenusMemory".
23-03-12 10:15:42   SystemUIServer[226] MenuCracker: Allowing "iStatMenusNetwork".
23-03-12 10:15:42   SystemUIServer[226] MenuCracker: Allowing "iStatMenusTemps".
23-03-12 10:15:48   defaults[308]
The domain/default pair of (com.apple.driver.AppleBluetoothMultitouch.mouse, MouseMomentumScroll) does not exist
23-03-12 10:15:48   [0x0-0x21021].com.hegenberg.BetterTouchTool[282]    2012-03-23 10:15:48.633 defaults[308:903]
23-03-12 10:15:48   [0x0-0x21021].com.hegenberg.BetterTouchTool[282]    The domain/default pair of (com.apple.driver.AppleBluetoothMultitouch.mouse, MouseMomentumScroll) does not exist
23-03-12 10:15:58   mdworker[267]   (Error) SyncInfo: Catalog changed during searchfs too many times -- falling back to fsw search /
**** 1 minuut en 10 seconden??? ****
23-03-12 10:16:48   1PasswordAgent[255] Starting 1PasswordAgent 3.8.17 #31272 built Feb 15 2012 16:15:57
23-03-12 10:16:48   1PasswordAgent[255] Trying to load Localizable.strings [English] from the main bundle
23-03-12 10:16:48   1PasswordAgent[255] Cannot find English version, using English localization for Localizable.strings
23-03-12 10:16:51   1PasswordAgent[255] reloadAllObjects
23-03-12 10:16:51   1PasswordAgent[255] Database (AGHtmlDatabase:file://localhost/Users/Anton/Library/Application%20Support/1Password/1Password.agilekeychain/) load time [Cache]: 0.196+0.001 (155 objects)
23-03-12 10:16:54   Firewall[80]    1PasswordAgent is listening from 127.0.0.1:6258 proto=6
23-03-12 10:16:54   Firewall[80]    1PasswordAgent is listening from ::1:6258 proto=6
**** 26 seconden??? ****
23-03-12 10:17:20   SystemUIServer[226] iStat Menus loading extra - time
23-03-12 10:17:23   SystemUIServer[226] iStat Menus loading extra - battery
23-03-12 10:17:27   Typinator[280]  XML parse error Error Domain=NSXMLParserErrorDomain Code=5 "The operation couldn&#8217;t be completed. (NSXMLParserErrorDomain error 5.)"
23-03-12 10:17:27   Typinator[280]  version check failed for http://update.ergonis.com/vck/typinator.xml
23-03-12 10:17:28   SystemUIServer[226] iStat Menus loading extra - cpu
23-03-12 10:17:29   SystemUIServer[226] no gpus
23-03-12 10:17:29   SystemUIServer[226] iStat Menus loading extra - memory
23-03-12 10:17:30   SystemUIServer[226] iStat Menus loading extra - network
23-03-12 10:17:30   SystemUIServer[226] iStat Menus loading extra - sensors
  • vj_slof
  • Laatst online: 13:28
schakel Spotlite eens uit. http://www.fixamacsoftware.com/software/spot3/index.php
Het process mdworker heeft nogal wat tijd nodig zo te zien. Ook het pakket Parallels vreet enorm veel resources dus die de-installeren en iets anders gebruiken wat minder heftig is. Verder zie ik dus best veel programma's die standaard niet in OSX zitten maar wel mee opstarten. iStat, 1PasswordAgent, BetterTouchTool, MacFusion. Dat is nogal wat dat mee opstart met je OS. Is het persé nodig dat deze ook mee opstarten?
  • OkselFris
  • Laatst online: 13-11 23:07
OkselFris
Rabarber, Rabarber, Rabarber
vj_slof schreef op vrijdag 23 maart 2012 @ 12:21:
Sorry dat ik het zeg, maar deze tips zijn natuurlijk onzin. Die paar dingen die hier worden opgestart? Ik wou dat ik het zo clean had. Een OS is niet bedoeld om geheel niks anders mee op te laten starten.
Wat wil je gebruiken dat minder heftig is dan Parallels (wat niet echt een zware resource vreter is) en waarom niet die tools opstarten?
Ja natuurlijk het snelst is alles wanneer je niks opstart.
Gebruiker moet niet vergeten dat hij dus een beta draait en tegen nog wat incompatibiliteit kan aanlopen. Helaas is OSX na Snow Leopard niet 1 van de snelste met opstarten. (SSD helpt hier veel)
Ik zou het echter nu eerst maar accepteren gezien je een vroeger beta draait en veel programma's die je draait ook nog nieuw op 10.6.8 zijn. Zodra je een paar programma's mee opstart is OSX net zoals Windows niet de snelste met het opstarten. Gelukkig hoef je OSX op het algemeen maar weinig opnieuw te starten. :)
To crash with a Volvo is extremely safe..... if you’re sitting in a Saab
  • vistu
  • Laatst online: 13-11 11:07
OkselFris schreef op vrijdag 23 maart 2012 @ 22:10:
10.6.8 is de laatste Snow Leopard, bijna 7 maanden geleden uitgebracht. 10.8 is een vroege beta, maar 10.6.8 zeker niet ;)
  • DAzN
10.6 != 10.8 ;)
TS draait Snow Leopard en doet er inderdaad goed aan om de memory / cpu resistente programma's te bekijken.
  • OkselFris
OkselFris
vistu schreef op vrijdag 23 maart 2012 @ 22:17:
oeps, niet echt scherp geweest. ;-)
  • Ghehe
  • Laatst online: 14-11 20:32
Ghehe
400 pound hacker
mdworker is - denk ik toch - de indexeringstool van Spotlight en indexeert wat er in documenten enzo staat zodat je er met Spotlight snel bij kan. Is het mogelijk dat je laatst een nieuwe harde schijf hebt aangekoppeld vol met bestanden of dat je op je computer heel wat nieuwe bestanden hebt staan?
Je kan zoals hierboven gezegd is geweest je Spotlight eens uitschakelen of via System Preferences -> Spotlight -> Privacy ervoor zorgen dat er bepaalde mappen worden overgeslagen.
  • vj_slof
@ Okselfris: Alleen Parallels vertraagt het opstarten al met 10 sec. Zo nog 3 andere programma's mee laten starten en je bent een halve minuut kwijt. Waarom moet Parallels zoveel bij het opstarten van OSX gebruiken? Ik heb liever dat dit gebeurd tijdens het opstarten van het programma. Het vreet geheugen en het kost tijd zoals je duidelijk kunt zien. Tel nu even de tijden van de programma's op die niet bij OSX horen en je kunt bijna een minuut opstarttijd besparen.
Ik heb spotlight uitgeschakeld (door privacy op de root van de schijf "/" te zetten"). Parallels, VMware en iStats uninstalled maar het is nog steeds mega traag.
Ter illustriate:
- Opstarten tot het inlog scherm duurt 37 seconden (perfect, niets te klagen, hoewel het voor mijn gevoel wel sneller is geweest).
- Het inlog proces van username + password en het verdwijnen van de strandbal duurt 1 minuut en 46 seconden!!!! Dat is toch niet normaal of wel??
De log is nu een stuk schoner
29
30
26-03-12 18:58:09   com.apple.launchd[1]    *** launchd[1] has started up. ***
***** Komt overeen met de timing van 30+ seconden *****
26-03-12 18:58:39   com.freemacsoft.appcleanerd[53] Appcleanerd started successfully.
***** Heb ik het juist als ik stel dat appcleanerd ongeveer 26 seconden nodig heeft om op te starten?? *****
26-03-12 18:59:06   com.apple.WindowServer[86]  Mon Mar 26 18:59:06 MacBook-Pro-Anton.local WindowServer[86] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
26-03-12 18:59:13   com.apple.launchctl.Aqua[117]   launchctl: Dubious permissions on file (skipping): /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
26-03-12 18:59:13   com.apple.launchd.peruser.501[115]  (com.divx.agent.postinstall) Unknown key: LimitToSessionType
26-03-12 18:59:13   com.apple.launchd.peruser.501[115]  (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
26-03-12 18:59:25   com.apple.launchd.peruser.501[115]  (com.apple.Kerberos.renew.plist[139]) Exited with exit code: 1
26-03-12 18:59:33   macfusionAgent[158] __CFServiceControllerBeginPBSLoadForLocalizations timed out while talking to pbs
26-03-12 18:59:34   SpeechSynthesisServer[160]  __CFServiceControllerBeginPBSLoadForLocalizations timed out while talking to pbs
26-03-12 18:59:35   Alfred[161] __CFServiceControllerBeginPBSLoadForLocalizations timed out while talking to pbs
26-03-12 18:59:36   GrowlHelperApp[159] __CFServiceControllerBeginPBSLoadForLocalizations timed out while talking to pbs
26-03-12 18:59:36   DropzoneProxy[171]  __CFServiceControllerBeginPBSLoadForLocalizations timed out while talking to pbs
***** Weer ruim 15 seconden kwijt *****
26-03-12 18:59:53   defaults[194]
26-03-12 18:59:53   [0x0-0x1b01b].com.hegenberg.BetterTouchTool[169]    2012-03-26 18:59:53.126 defaults[194:903]
26-03-12 18:59:53   [0x0-0x1b01b].com.hegenberg.BetterTouchTool[169]    The domain/default pair of (com.apple.driver.AppleBluetoothMultitouch.mouse, MouseMomentumScroll) does not exist
26-03-12 19:00:04   1PasswordAgent[146] Starting 1PasswordAgent 3.8.17 #31272 built Feb 15 2012 16:15:57
26-03-12 19:00:04   1PasswordAgent[146] Trying to load Localizable.strings [English] from the main bundle
26-03-12 19:00:05   1PasswordAgent[146] Cannot find English version, using English localization for Localizable.strings
26-03-12 19:00:10   1PasswordAgent[146] reloadAllObjects
26-03-12 19:00:10   1PasswordAgent[146] Database (AGHtmlDatabase:file://localhost/Users/Anton/Library/Application%20Support/1Password/1Password.agilekeychain/) load time [Cache]: 0.291+0.001 (156 objects)
Ik ga nog eens wat meer dingen uninstallen, kijken wat voor effect dat heeft... Ik hou jullie op de hoogte. Bedankt voor het meedenken!!
  • Frietsaus
Ga eens naar /System/Library/CoreServices en dubbelklik op pbs. Pbs zal dan starten en weer sluiten, dat zou in elk geval die time outs moeten verhelpen en wellicht dat hij dan ook sneller opstart.
Frietsaus schreef op maandag 26 maart 2012 @ 19:30:
Thanks, het is ietsje sneller geworden 1 minuut 39 seconden. De log ziet er al weer wat schoner uit:
26-03-12 19:44:10   com.apple.launchd[1]    *** launchd[1] has started up. ***
26-03-12 19:44:31   com.freemacsoft.appcleanerd[54] Appcleanerd started successfully.
26-03-12 19:44:44   com.apple.WindowServer[85]  Mon Mar 26 19:44:44 MacBook-Pro-Anton.local WindowServer[85] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
26-03-12 19:44:50   com.apple.launchctl.Aqua[111]   launchctl: Dubious permissions on file (skipping): /etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist
26-03-12 19:44:50   com.apple.launchd.peruser.501[109]  (com.divx.agent.postinstall) Unknown key: LimitToSessionType
26-03-12 19:44:50   com.apple.launchd.peruser.501[109]  (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
26-03-12 19:45:02   com.apple.launchd.peruser.501[109]  (com.apple.Kerberos.renew.plist[130]) Exited with exit code: 1
26-03-12 19:45:24   defaults[167]
26-03-12 19:45:24   [0x0-0x1d01d].com.hegenberg.BetterTouchTool[155]    2012-03-26 19:45:24.566 defaults[167:903]
26-03-12 19:45:24   [0x0-0x1d01d].com.hegenberg.BetterTouchTool[155]    The domain/default pair of (com.apple.driver.AppleBluetoothMultitouch.mouse, MouseMomentumScroll) does not exist
26-03-12 19:45:38   1PasswordAgent[137] Starting 1PasswordAgent 3.8.17 #31272 built Feb 15 2012 16:15:57
26-03-12 19:45:38   1PasswordAgent[137] Trying to load Localizable.strings [English] from the main bundle
26-03-12 19:45:38   1PasswordAgent[137] Cannot find English version, using English localization for Localizable.strings
26-03-12 19:45:43   1PasswordAgent[137] reloadAllObjects
26-03-12 19:45:43   1PasswordAgent[137] Database (AGHtmlDatabase:file://localhost/Users/Anton/Library/Application%20Support/1Password/1Password.agilekeychain/) load time [Cache]: 0.392+0.001 (156 objects)
Zou het te maken kunnen hebben met de beschikbare vrije ruimte op de hardeschijf?? Ik heb slechts 10 GB beschikbaar van de 500.
  • Frietsaus
Te weinig schijfruimte kan ook zeer vertragend werken ja in OS X, ik zou wat meer ruimte vrijmaken ja. ;)
Er zit schot in de zaak!! Na het inlog scherm doe ik er nu 1 minuut en 6 seconden over.
Wat ik onderhand allemaal al heb gedaan:
- Verwijderden van /Library/Caches
- Verwijderen van ~/Library/Caches
- Resetten van PRAM & NVRAM
Ik las dat iemand het er over had om de volgende folder weg te gooien:
/Library/Preferences/SystemPreferences
Echter vraag ik me af of dit wel zomaar kan. Wat denken jullie?
  • Saven
  • Laatst online: 15:01
Saven
Administrator
Wat denk je zelf als je de naam van de map zo leest? :P
Ik denk dat hij instellingen die je hebt gemaakt reset oid. Weet het niet precies, maar ga er maar van uit dat er dingen gaan gebeuren waar je niet helemaal op zit te wachten
Saven schreef op maandag 26 maart 2012 @ 22:40:
Hehehe als ik de naam zo zie denk ik "vooral niet mee klooien" :+
Ik heb de Apple "Hardware Test" uitgeprobeerd (vóór het witte scherm je D-toets inhouden). Echter blijft deze na 8 minuten hangen en houdt hij geen status meer bij. Als ik dan op "Stop Test" of "CMD + <punt>" druk gebeurd er niets. Ik heb hem 45 min laten draaien maar na 8 minuten gaat hij niet verder.
Kan dit onderdeel van het probleem zijn??
Ik heb de "Apple Hardware Test" de hele nacht laten ratelen en ik denk dat ik gewoon niet lang genoeg gewacht had. Na 2 uur en 10 minuten (8 GB) was hij er helemaal klaar mee en waren er geen dingen gevonden.
Heeft het nut om de boot cache leeg te gooien? De naam cache geeft natuurlijk aan dat hij weer vol raakt...
  • vj_slof
je zou daarvoor een tool als Cocktail for Snow Leopard kunnen gebruiken. Die kun je dan alle onderhoudscripts die in OSX zitten laten uitvoeren. De bootcache is daarmee ook te legen.
http://maintain.se/cocktail
Ik heb mijn Mac flink opgeschoond en het was de moeite waard!!! Ik zit nu op de desktop met een seconde of 30 (vanaf het inlog scherm). Het booten tot het inlog scherm duurt iets van 45 seconden. Ik kan het korter maken door Parallels er af te knikkeren maar die heb ik helaas nodig... ;)
Ik denk persoonlijk dat het aan BetterTouchTool ligt. Sinds die er af is gaat alles een stuk sneller. Ik kan het niet met volle zekerheid zeggen omdat ik er tegelijkertijd nog één of twee andere apps heb afgegooid.
  • Muncher
  • Laatst online: 13-11 11:52
Ik heb soortgelijke problemen. In welke log kan ik de boot gegevens vinden? (Draai Lion, 10.7.3)
  • coptician
  • Laatst online: 12:00
Overweeg eens om gewoonweg het OS opnieuw te installeren. Je verliest geen data of instellingen, maar het kan wel heel erg helpen als er bepaalde dingen verkeerd zijn gaan lopen.
Vermijd trouwens ook dingen als "Mac SpeedUp" of "AppCleaner" software, die zijn vaak niet echt goed voor je systeem, ongeacht hoe hard ze schreeuwen van wel.
Als je dat niet wilt doen, doe dan eens met Disk Utility (met de Mac OS install disc) een repair permissions, dat wil ook nog wel eens helpen, en ik zie dat je ergens wat permissie-problemen kan hebben.
Hoe meer je dingen gaat verwijderen en zomaar files verplaatst, hoe groter de kans dat er iets mis gaat.Geen man over boord (vooral als je Time Machine gebruikt) maar dat is toch niet echt aan te raden.
HP Brio - Pentium iii 733 MHz - 128 MB SDRAM - 20 GB Ultra-ATA/66 - 3.5" 1.44MB FDD - S3 ProSavage 8MB graphics - 1024x768 - Windows Me
Muncher schreef op zaterdag 21 april 2012 @ 18:45:
In /Applications/Utilities zit een Console.app. Daar kan je precies zien wat er allemaal gebeurd tijdens het opstarten.
