Geen internet via LAN, wel via Airport Express
  • Pluistronaut
  • Laatst online: 15-09 17:01
Hallo allemaal,
Ik heb sinds een paar dagen problemen met mijn thuisnetwerk. Ik heb al een vraag gesteld op het Apple support forum, maar daar ben ik niet echt geholpen. Daarom stel ik hem nu hier! Ik heb niet echt tijd om hem te vertalen naar het Nederlands, dus ik doe hem eerst ff in het Engels, als dat geen probleem is?
"As of this morning, the wired internet connection on my iMac stopped working. A little background info:
I live in a student complex in the Netherlands where the internet connection enters my apartment with just an ethernet cable (no modem). This cable is connected to a TP-Link switch (type: TL-SG1005D). From here, a Cat 5E cable runs to my iMac.
This configuration has always worked, just until this morning. The network preferences pane gives me the following info:
Ethernet is currently active and has the ip address 169.254....
Subnet mask: 255.255.0.0
Router: (nothing) ---> there used to be an address here but it is gone now
Strange thing is that I also have an Airport Express connected to the switch which does have an internet connection (I am typing this message from a MacBook pro connected to this Airport Express).
After looking all over the internet for solutions, I have tried the following:
-reset the switch
-reset the iMac
-unplugged/plugged the ethernet cables back in
-tried different cables/ports on the switch
-renewed DHCP lease
-created another network location, added ethernet adapter, renewed DHCP lease
As I do have a wireless connection with my laptop and the ethernet cable does not give me a connection on the laptop, I think the problem lies with the switch. It couldn't have anything to do with the ISP, as I can connect to the internet wirelessly, right?
I read that the 169.xxx IP address means that it is a self-assigned IP address.
Maybe the distribution of IP addresses by the switch doesn't work anymore, and the Airport Express distributes its own IP addresses to the wireless devices, enabling me to access the internet through wi-fi?"
Ik hoor graag jullie theorieën!
Alvast dank. :|
  • --MeAngry--
  • Laatst online: 13:42
--MeAngry--
aka Qonstrukt
Lijkt erop dat je nog maar 1 IP adres binnen krijgt en deze gebruikt wordt door je Airport Express. In het verleden kreeg je misschien meer IP-adressen welke je via de switch netjes kon verdelen.
Tesla Model Y RWD (2024) ▪︎ Daikin Altherma 3 6kW (300L SWW) ▪︎ 20x AIKO NeoStar 2S+ 465Wp ▪︎ Sigenergy SigenStor EC 10+10 (12kW + Gateway HomePro TP)
  • lier
  • Laatst online: 18:38
lier
MikroTik nerd
Wat gebeurt er als je de imac een vast IP adres (van de AE) geeft en de AE van het netwerk afhaalt?
  • Pranger
  • Laatst online: 06-08 10:43
Een 169.254.x.x adres betekent meestal dat de DHCP server niet te bereiken valt of dat deze niet aanwezig is in het netwerk. Gezien jouw wireless wel werkt zou ik je eens willen vragen om te controleren als je hier een statisch IP adres hebt ingesteld?
  • laurens0619
  • Laatst online: 15:36
precies wat --MeAngry-- zegt. Ze hebben waarschijnlijk een limiet van ip addressen met poort ingesteld. Even een router ertussen en je kan weer lekker doorgaan :)
  • Pluistronaut
Bedankt voor de reacties! Ondertussen is het allemaal gefikst.
Ik heb eerst alles losgekoppeld en uit het stopcontact gehaald. Daarna de switch aangezet en mijn imac aangesloten, waarmee ik op internet kon.
Daarna heb ik de Airport express aangesloten, welke vervolgens een foutmelding gaf dat hij geen internetverbinding had. Het verhaal van --MeAngry-- leek mij hiermee bevestigd.
Vervolgens heb ik een wireless gigabit router besteld en alles hier netjes op aangesloten, en voila, alle clients hebben een prachtige internetverbinding!
Case closed!
