Vraagje over pproxy
  • _DPC_Scorpion
  • Laatst online: 07-09 23:46
Hej als mijn pproxy zijn buffer exceed
probeert hij verbinding te maken met een keyserver dat lukt dan niet
pas als ik m'n service restart flusht ie pas
das naar :(
w2k bakkie
2001-03-23 07:15:20,Status: Uplink needed... (thresholds exceeded)
2001-03-23 07:15:20,Status: Creating uplink (outgoing server) connection.
2001-03-23 07:15:21,Uplink: [1] connection to 130.161.38.84 changed state
2001-03-23 07:15:21, from 0 (ESTNONE) to 1 (ESTCONNWAIT)
2001-03-23 07:15:27,rc564 r=21487/30000, d=9383/10000, 15.7 Mkeys/sec, tot=9019
2001-03-23 07:15:27,ogr r=4928/5000, d=64/50, 50.6 Mnodes/sec, tot=63 stubs
2001-03-23 07:15:27,Status: Uptime: 1.18:26:04, 2 listeners, 1 uplink
2001-03-23 07:15:27,Status: 0 active clients (peak: 1, mean: 0.00)
2001-03-23 07:15:42,Uplink: [1] Socket error; (WSAEHOSTUNREACH): The host is unreachable
2001-03-23 07:15:42,Uplink: [1] Closed connection to 130.161.38.84.
2001-03-23 07:15:42,rc564 r=21487/30000, d=9383/10000, 15.7 Mkeys/sec, tot=9019
2001-03-23 07:15:42,Status: rc564: Last uplink sent 0 and received 0
na rebout
2001-03-23 07:26:18,Status: 0 active clients (peak: 1, mean: 0.00)
2001-03-23 07:26:42,Status: Shutting down listeners...
2001-03-23 07:26:42,Status: Closing client connections...
2001-03-23 07:26:42,Status: Closing uplink connections...
2001-03-23 07:26:42,*Break* Initiating shutdown.
2001-03-23 07:26:42,Shutting down contests.
2001-03-23 07:26:42,Proxy shutdown complete.
2001-03-23 07:26:43,distributed.net Personal Proxy (build 319)
2001-03-23 07:26:43,Visit http://www.distributed.net/ for details.
2001-03-23 07:26:43,Proxy starting up.
2001-03-23 07:26:43,Verbosity set to: general stats keyblock server client buffers timestamp attention errlow errsevere (3519)
2001-03-23 07:26:43,desII-in: limits adjusted to min 1, max 20
2001-03-23 07:26:43,csc-in: limits adjusted to min 1, max 20
2001-03-23 07:26:43,Notice: connectivity mode is normal
2001-03-23 07:26:43,Notice: Loaded 0 ignoredip addresses from ini file
2001-03-23 07:26:43,Notice: Loaded 0 allowedip addresses from ini file
2001-03-23 07:26:43,Notice: Primary listener bound to 212.206.239.221:2064
2001-03-23 07:26:43,Notice: Test listener bound to 212.206.239.221:3064
2001-03-23 07:26:43,Status: Uplink needed... (thresholds exceeded)
2001-03-23 07:26:43,Status: Creating uplink (outgoing server) connection.
2001-03-23 07:26:43,rc564 r=21487/30000, d=9383/10000, 0.0 Mkeys/sec, tot=0
2001-03-23 07:26:43,ogr r=4928/5000, d=64/50, 0.0 Mnodes/sec, tot=0 stubs
2001-03-23 07:26:43,Status: Uptime: 0.00:00:00, 2 listeners, 0 uplinks
2001-03-23 07:26:43,Status: 0 active clients (peak: 0, mean: 0.00)
2001-03-23 07:26:44,Uplink: [1] connection to 130.161.38.84 changed state
2001-03-23 07:26:44, from 0 (ESTNONE) to 1 (ESTCONNWAIT)
2001-03-23 07:26:47,Uplink: [1] connection to 130.161.38.84 changed state
2001-03-23 07:26:47, from 1 (ESTCONNWAIT) to 50 (ESTREADY)
2001-03-23 07:26:48,Uplink: [1] Establishing handshake with 130.161.38.84...
2001-03-23 07:26:48,Uplink: [1] Server is running version 324.
2001-03-23 07:26:48,Uplink: [1] Got permission acknowledgement.
gebruik je dns of het ip-adres?
ip wil nog wel eens helpen, of anders de poort invullen waarmee je wilt connecten met de proxy.
