vage fouten harde schijf
  • 120 views sinds 30-01-2008
  • tjikkun
  • Laatst online: 06-09 20:27
Hoi, ik kan partition magic niet meer gebruiken, want mijn harde schijf heeft fouten.
hier is een txt-je van partitionInfo, ik hoop dat iemand weet wat ik nu kan doen
PowerQuest PartitionInfo 2.0 -- Windows 95 Version
Date Generated: 03/22/01 11:59:58
Copyright (c)1994-1999, PowerQuest Corporation
Permission is granted for this utility to be freely copied so long
as it is not modified in any way. All other rights are reserved.
PowerQuest, makers of PartitionMagic(r), Drive Image(tm), and DriveCopy(tm), can be reached at:
Voice: 801-437-8900
Fax: 801-226-8941
Web site: http://support.powerquest.com/support.html
E-mail: magic@powerquest.com
General System Information:
Total Physical Memory (bytes): 131,805,184
Used Physical Memory: (bytes): 123,637,760
Maximum Page File Size: (bytes): 524,288,000
Current Page File Size: (bytes): 33,599,488
Disk Geometry Information for Disk 1: 3736 Cylinders, 255 Heads, 63 Sectors/Track
System PartSect # Boot BCyl Head Sect FS ECyl Head Sect StartSect NumSects
HARDUSKIWE1 0 0 80 267 1 1 0B 713 254 63 4,289,418 7,180,992
0 1 00 714 0 1 0F 1023 254 63 11,470,410 44,451,855
Info: Begin C,H,S values were large drive placeholders.
Info: End C,H,S values were large drive placeholders.
Actual values are:
0 1 00 714 0 1 0F 3480 254 63 11470410 44451855
WIN ME 0 2 00 0 1 1 1B 266 254 63 63 4,289,292
HARDUSKEIV2 11,470,410 0 00 859 1 1 0B 1023 254 63 13,799,898 20,627,397
Actual values are:
11470410 0 00 859 1 1 0B 2142 254 63 13799898 20627397
11,470,410 1 00 1023 0 1 05 1023 254 63 34,427,295 16,386,300
Actual values are:
11470410 1 00 2143 0 1 05 3162 254 63 34427295 16386300
HARDUSKEIV3 34,427,295 0 00 1023 1 1 0B 1023 254 63 34,427,358 16,386,237
Actual values are:
34427295 0 00 2143 1 1 0B 3162 254 63 34427358 16386237
34,427,295 1 00 714 1 1 05 714 254 63 11,470,473 16,002
Error #120: Logical Drive chain extends toward start of drive.
11,470,473 0 00 714 2 1 83 714 254 63 11,470,536 15,939
Info: Partition didn't begin on head boundary.
ucBeginHead expected to be 0 or 1, not 2.
11,470,473 1 00 1023 0 1 05 1023 254 63 50,813,595 4,096,575
Actual values are:
11470473 1 00 3163 0 1 05 3417 254 63 50813595 4096575
50,813,595 0 00 1023 1 1 83 1023 254 63 50,813,658 4,096,512
Actual values are:
50813595 0 00 3163 1 1 83 3417 254 63 50813658 4096512
50,813,595 1 00 715 0 1 05 731 254 63 11,486,475 273,105
SWAPSPACE2 11,486,475 0 00 715 1 1 82 731 254 63 11,486,538 273,042
Partition Information for Disk 1: 29,306.1 Megabytes
Volume PartType Status Size MB PartSect # StartSect TotalSects UsedSects FreeSects
*:WIN ME Hidden FAT32Pri 2,094.4 0 2 63 4,289,292 4,289,292 0
C:HARDUSKIWE1 FAT32 Pri,Boot 3,506.3 0 0 4,289,418 7,180,992 7,180,992 0
ExtendedX Pri 21,705.0 0 1 11,470,410 44,451,855 41,399,505 3,052,350
EPBR Log 0.0 None -- 11,470,410 63 63 0
EPBR Log 7.8 34,427,295 1 11,470,473 16,002 16,002 0
Linux Ext2 Log 7.8 11,470,473 0 11,470,536 15,939 15,939 0
EPBR Log 133.4 50,813,595 1 11,486,475 273,105 273,105 0
*:SWAPSPACE2 Linux Swap Log 133.3 11,486,475 0 11,486,538 273,042 273,042 0
Free Space Log 996.2 None -- 11,759,580 2,040,255 0 2,040,255
D:HARDUSKEIV2 FAT32 Log 10,071.10 11,470,410 0 13,799,898 20,627,397 20,627,397 0
EPBR Log 8,001.1 11,470,410 1 34,427,295 16,386,300 16,386,300 0
E:HARDUSKEIV3 FAT32 Log 8,001.1 34,427,295 0 34,427,358 16,386,237 16,386,237 0
EPBR Log 2,000.3 11,470,473 1 50,813,595 4,096,575 4,096,575 0
Linux Ext2 Log 2,000.3 50,813,595 0 50,813,658 4,096,512 4,096,512 0
Free Space Log 494.2 None -- 54,910,170 1,012,095 0 1,012,095
Free Space Pri 2,000.3 None -- 55,922,265 4,096,575 0 4,096,575
Boot Record for drive *: (Drive: 1, Starting sector: 63, Type: FAT32)
1. Jump: EB 58 90
2. OEM Name: MSWIN4.1
3. Bytes per Sector: 512
4. Sectors per Cluster: 8
5. Reserved Sectors: 32
6. Number of FAT's: 2
7. Reserved: 0x0000
8. Reserved: 0x0000
9. Media Descriptor: 0xF8
10. Sectors per FAT: 0
11. Sectors per Track: 63 (0x3F)
12. Number of Heads: 255 (0xFF)
13. Hidden Sectors: 63 (0x3F)
14. Big Total Sectors: 4289292 (0x41730C)
15. Big Sectors per FAT: 4183
16. Extended Flags: 0x0000
17. FS Version: 0
18. First Cluster of Root: 1047 (0x417)
19. FS Info Sector: 1
20. Backup Boot Sector: 6
21. Reserved: F6F6F6F6F6F6F6F6F6F6F6F6
22. Drive ID: 0x80
23. Reserved for NT: 0x00
24. Extended Boot Sig: 0x29
25. Serial Number: 0x3A49245D
26. Volume Name: WIN ME
27. File System Type: FAT32
28. Boot Signature: 0xAA55
Boot Record for drive C: (Drive: 1, Starting sector: 4,289,418, Type: FAT32)
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
13. Hidden Sectors: 4289418 (0x41738A)
14. Big Total Sectors: 7180992 (0x6D92C0)
15. Big Sectors per FAT: 7003
17. FS Version: 0
18. First Cluster of Root: 2248 (0x8C8)
21. Reserved: 000000000000000000000000
22. Drive ID: 0x80
25. Serial Number: 0x2F0D1BF4
26. Volume Name: HARDUSKIWE1
Boot Record for drive D: (Drive: 1, Starting sector: 13,799,898, Type: FAT32)
1. Jump: EB 58 90
4. Sectors per Cluster: 16
7. Reserved: 0x0000
8. Reserved: 0x0000
14. Big Total Sectors: 20627397 (0x13ABFC5)
15. Big Sectors per FAT: 10067
17. FS Version: 0
18. First Cluster of Root: 742 (0x2E6)
22. Drive ID: 0x80
25. Serial Number: 0x41141BF9
26. Volume Name: HARDUSKEIV2
Boot Record for drive E: (Drive: 1, Starting sector: 34,427,358, Type: FAT32)
1. Jump: EB 58 90
7. Reserved: 0x0000
8. Reserved: 0x0000
14. Big Total Sectors: 16386237 (0xFA08BD)
15. Big Sectors per FAT: 15987
17. FS Version: 0
18. First Cluster of Root: 2 (0x2)
22. Drive ID: 0x80
25. Serial Number: 0x0C6A1BFF
26. Volume Name: HARDUSKEIV3
