Vandaag ff een kleine 30 poi,s in de map
content / poi,s gezet
kml bestanden en bitmapafbeeldingen
maar als ik rij dan zie ik ze niet
en zie ze ook niet bij.....
meer / instellingen / kaartinstellingen en markeringen plaatsen
en heb nog 3 vragen
1 heb ik tmc ?
2 waar kun je icoon pijl naar auto veranderen ?
3 welke scheme/skin kan ik het beste gebruiken..realistisch wolken kleuren lucht gebouwen etc etc ?
mvg harry
hierbij sys
[Interface]
vga=0
show_exit=1
;show_minimize=1
extra_settings=1
shutdown_time=0
capture_to_jpeg=1
show_mapchanger=1
show_programs=1
[rawdisplay]
highres=0
screen_x=480
screen_y=272
stretch=1
class="landscape"
[folders]
has_secondary_root=0
[utility]
calibratefix=1 ; ; If gps signal don't lost write - "0"; if lost write "1"
;[gps]
;baud=57600
;port=2
;source="virtserial"
;set_messages="0" ;
[TMC]
port = "COM, 2"
source = "eten"
gps_source = 0
auto_tuning="1"
saved_last_frequency="1040"
;[tmc]
;saved_config_available="1"
;saved_config_classname="GNS_GPSTMC_SOURCE"
;saved_config_portname="COM"
;saved_config_port="1"
;auto_tuning="1"
;saved_last_frequency="1040"
[mapchanger]
map_ta="TELEATLAS" ; - you can write other title
map_nt="NAVTEQ"
map_ot="TOP MAP"
[tripcomputer]
num_of_trips=4
[vr]
disabled=0
[3d_config]
disable_roadsign_navigation_mode=0
roadsign_lines_per_screen=10
rotated_roadsigns=0
[sound]
csv_voice_enabled=1
ding=0
[debug]
skip_eula=1
screenshotsavecameraini=0
screenshotfilename="\captures\ecran_%02d.jpg"
show_battery_percent=1
experimental_features=1
;show_networkservices=1
;[lua]
;backlightdetails=1
[gestures]
border_width=130
;[tmc-http]
;enabled=1
[map]
show_oneway=1
2dheadup=1
show_oneway_3d=1
poi_grouping_distance=0
3d_max_zoomlevel=800;
3d_min_zoomlevel=30;40
speedcam_visibility=500;
3d_max_tiltlevel="8700"
3d_default_tiltlevel="8200"
3d_max_zfar=5000
3d_buildings=1
3d_landmarks="1"
3d_roads="1"
3d_tunnels="1"
follow_gps=1
[2d]
guidancearrow_disappearlevel=600
guidancearrow_maxshift=12
minguidancearrowsize=20
minguidancearrowsize_zoomlevel=1200
maxguidancearrowsize=65
maxguidancearrowsize_zoomlevel=0
[3d]
planned_route_track_width="5"
planned_route_track_contour_width="1"
planned_route_contour_width="1"
max_pois_on_horizont="5"
[navigation]
junction_view_distance=300 ;(200)
junction_view_distance_ramp=300 ;(400)
junction_view_distance_highway=400 ;(800)
simple_crossborder_warning=1
use_duration_for_tunnel=0
show_current_city=1
show_city_in_next_street = 1
show_city_in_next_street_distance = 1000
autoreplan_action="AUTO"
gps_pos_to_road=1
show_countrychange=1
[camera.roundabout]
enabled=0
[feature]
text_guidance=1
signpost_coloring=1
tmc_event_coloring=1
tmc_traffic_side=1
ding=0
[dynamiccompressor] ;TTS voice
compressor=1
gain=10
[tts]
automatic_direction_conversion=1
announce_exit_directions=1
always_say_road_names=3
skip_exit_numbers=1
p.s gaat om primo v2.0 standaard
gr harry
  • RoD
RoD
Admin Mobile & FP PowerMod
Er gaan hier een aantal dingen fout.
1. We verwachten hier eigen initiatief alvorens je op GoT aan komt kloppen. Uit je topicstart valt niet op te maken wat je zelf al hebt geprobeerd om het antwoord op je vragen te krijgen, terwijl we dit volgens Het algemeen beleid wel van je verwachten.
2. Je post is zeer slecht te lezen doordat je willekeurige enters plaatst en je zinnen onsamenhangend te zijn. Als je onze hulp wil is het wel zo netjes om het ook goed leesbaar te maken.
3. Je post een hele lap tekst zonder dat je daar de relevante delen uit quote. Het is niet de bedoeling dat wij uit een brei tekst relevante informatie gaan vissen.
4. We verwachten dat je de editknop gebruikt in plaats van twee keer op rij te posten.
Al met al gaat dit topic dus op slot.
