nvram
Als mijn PC opstart blijft hij hangen bij de melding checking NVRAM.
Iemand idee wat dit is en hoe dit is op te lossen? (denk het wel)
TXXx
Hmm,
Non-Volatile Random Acces Memory (NVRAM) retains its contens when the computer is turned off. NVRAM is used to store essential information such as device node data, and Setup parameters. Select [Yes] only if you want to clear these data during the Power-On Self Test (POST)
Ff t bios in duiken ?
