MDADM Raid 6 3 drives weg.......
  • jp73
  • Laatst online: 19-08 09:29
Hallo
ik heb 6 drives in a Raid 6 met MDADM. Gisteravond bootte de computer niet meer, nu blijkt dat 3 drives niet meer in de Raid zitten.
Ik heb al wat gegoocheld en geprobeerd de drives toe te voegen maar dat lukt niet.
Ik zou graag wat expert hulp hebben voordat ik de zaak verder opkloot.
wat gegevens:
DebianServer:~# cat /proc/mdstat
Personalities : [raid6] [raid5] [raid4]
md0 : inactive sde1[3] sdg1[5] sdf1[4]
4395408384 blocks super 1.2
uit dmesg :
[ 13.036039] raid6: int64x1 2314 MB/s
[ 13.104015] raid6: int64x2 2376 MB/s
[ 13.172019] raid6: int64x4 1871 MB/s
[ 13.240052] raid6: int64x8 1420 MB/s
[ 13.308023] raid6: sse2x1 3437 MB/s
[ 13.376023] raid6: sse2x2 4638 MB/s
[ 13.444026] raid6: sse2x4 4708 MB/s
[ 13.444027] raid6: using algorithm sse2x4 (4708 MB/s)
[ 13.446238] md: raid6 personality registered for level 6
[ 13.446241] md: raid5 personality registered for level 5
[ 13.446243] md: raid4 personality registered for level 4
[ 13.950888] md: md0 stopped.
[ 13.954850] md: bind<sdb1>
[ 13.955035] md: bind<sdc1>
[ 13.955221] md: bind<sdd1>
[ 13.955392] md: bind<sdf1>
[ 13.955559] md: bind<sdg1>
[ 13.955743] md: bind<sde1>
[ 13.955763] md: kicking non-fresh sdd1 from array!
[ 13.955768] md: unbind<sdd1>
[ 13.968064] md: export_rdev(sdd1)
[ 13.968110] md: kicking non-fresh sdc1 from array!
[ 13.968117] md: unbind<sdc1>
[ 13.980025] md: export_rdev(sdc1)
[ 13.980053] md: kicking non-fresh sdb1 from array!
[ 13.980056] md: unbind<sdb1>
[ 13.992024] md: export_rdev(sdb1)
[ 13.993465] bio: create slab <bio-1> at 1
[ 13.993483] md/raid:md0: device sde1 operational as raid disk 3
[ 13.993486] md/raid:md0: device sdg1 operational as raid disk 5
[ 13.993489] md/raid:md0: device sdf1 operational as raid disk 4
[ 13.994208] md/raid:md0: allocated 6384kB
[ 13.994249] md/raid:md0: not enough operational devices (3/6 failed)
[ 13.994301] RAID conf printout:
[ 13.994303] --- level:6 rd:6 wd:3
[ 13.994306] disk 3, o:1, dev:sde1
[ 13.994308] disk 4, o:1, dev:sdf1
[ 13.994310] disk 5, o:1, dev:sdg1
[ 13.994793] md/raid:md0: failed to run raid set.
[ 13.994826] md: pers->run() failed ...
enig advies hoe dit aan te pakken ?
  • CAPSLOCK2000
  • Laatst online: 18:21
CAPSLOCK2000
zie teletekst pagina 888
Ik hoop dat je backups hebt. Ik bedoel het niet lullig maar het ziet er slecht uit.
Je zou eens naar de "--assume-clean" optie kunnen kijken maar pas op, dat is een riskant commando. Er is een grote kans dat het de boel nog verder stuk maakt (maar als je toch al niks te verliezen had....).
Heb je enig idee wat er mis is gegaan? Dat 3 schijven tegelijkertijd uit je array vallen is een beetje vreemd. Is er misschien een stroomkabel uit je voeding losgekomen of zoiets?
This post is warranted for the full amount you paid me for it.
  • jp73
Van het belangrijke spul heb ik een back-up. Volgens mij is het gebeurt nadat ik in een Drivebay een hdd gedaan heb en toen mount -a gedaan. Voor de drive stond een entry in mijn fstab. Volgens mij is het hierna de mist in gegaan. Aan de computer hangt een ups dus daar zou het probleem niet mogen liggen.
Wel zitten de 6 raid schijven aan een intel raid card ik moet nog eens kijken of de 3 schijven aan dezelfde poort zitten.
  • jp73
heb besloten maar alles opnieuw op te zetten, kon geen oplossing vinden
alleen vervelend dat ik de oorzaak niet heb kunnen achterhalen
UPDATE
Ik heb nu de 6 hdd op het moederbord en en extra sata kaartje aangesloten en geen problemen om de schijven te benaderen.
Via de raid kaart (Intel / LSI SASUC8I) kon ik sommige hdd niet benaderen, i/o error etc. Kon de schijven ook niet formatteren. En toen bedacht ik dat ik sinds de kaart heb ik nooit in het bios menu van de kaart kon komen, de pc bootte altijd door.
Dus nu ben ik een nieuwe raid 6 aan het maken en heb een RMA aangevraagd voor de raid kaart.
[ Voor 64% gewijzigd door jp73 op 16-12-2011 10:51 ]
