XMl geeft niets weer in xcode/objective C
  • nathanchunkie
  • Laatst online: 07-02-2025
Ik gebruik de volgende code in de .m file (stuk code met parser):
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
- (void)parserDidStartDocument:(NSXMLParser *)parser{
 NSLog(@"File found and parsing started");
 - (void)parseXMLFileAtURL: (NSString *)URL;{
 NSString *agentString = @"Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10_5_6; en-us) AppleWebKit/525.27.1 (KHTML, like Gecko) Version/3.2.1 Safari/525.27.1";
 NSMutableURLRequest *request = [NSMutableURLRequest requestWithURL:
 [NSURL URLWithString:URL]];
 [request setValue:agentString forHTTPHeaderField:@"User-Agent"];
 xmlFile = [ NSURLConnection sendSynchronousRequest:request returningResponse: nil error: nil ];
 articles = [[NSMutableArray alloc] init];
 errorParsing= NO;
 rssParser = [[NSXMLParser alloc] initWithData:xmlFile];
 [rssParser setDelegate:self];
 // You may need to turn some of these on depending on the type of XML file you are parsing
 [rssParser setShouldProcessNamespaces:NO];
 [rssParser setShouldReportNamespacePrefixes:NO];
 [rssParser setShouldResolveExternalEntities:NO];
 [rssParser parse];
 - (void)parser:(NSXMLParser *)parser parseErrorOccurred:(NSError *)parseError {
 NSString *errorString = [NSString stringWithFormat:@"Error code %i", [parseError code]];
 NSLog(@"Error parsing XML: %@", errorString);
 errorParsing=YES;
 - (void)parser:(NSXMLParser *)parser didStartElement:(NSString *)elementName namespaceURI:(NSString *)namespaceURI qualifiedName:(NSString *)qName attributes:(NSDictionary *)attributeDict{
 currentElement = [elementName copy];
 ElementValue = [[NSMutableString alloc] init];
 if ([elementName isEqualToString:@"intro"]) {
 item = [[NSMutableDictionary alloc] init];
 - (void)parser:(NSXMLParser *)parser foundCharacters:(NSString *)string{
 [ElementValue appendString:string];
 - (void)parserDidEndDocument:(NSXMLParser *)parser {
 if (errorParsing == NO)
 NSLog(@"XML processing done!");
 } else {
 NSLog(@"Error occurred during XML processing");
Header file:
#import <UIKit/UIKit.h>
@class ontfsViewController;
@interface artikels : UIViewController {
    ontfsViewController *detailViewController;
    IBOutlet UIWebView *errorView;
    //xml
    NSXMLParser *rssParser;
    NSMutableArray *articles;
    NSMutableDictionary *item;
    NSString *currentElement;
    NSMutableString *ElementValue;
    BOOL errorParsing;
@property (nonatomic, retain) IBOutlet ontfsViewController *detailViewController;
@end
en onder viewdidload:
- (void)viewDidLoad
    [super viewDidLoad];
    // Do any additional setup after loading the view from its nib.
    [self parseXMLFileAtURL:@"http://****.com/get_recent_posts.xml"];
Maar de XML weergeeft ie niet maar haalt ie wel keurig op zie ik aan de NSlogs
2011-12-11 17:35:22.820 [18712:f803] File found and parsing started
2011-12-11 17:35:22.821 [18712:f803] title
2011-12-11 17:35:22.822 [18712:f803] title
2011-12-11 17:35:22.823 [18712:f803] XML processing done!
in de .xib file heb ik niks toevoegt aan 'view' omdat ik simpelweg niet weet welk object ik moet gebruiken voor de weergave en of dit wel nodig is.
Afbeeldingslocatie: http://cl.ly/3s193j1r0Q3d1d3s2V3i/Schermafbeelding%202011-12-11%20om%2017.39.56.png
Weet iemand wat ik over het hoofd zie of vergeet?
Front-end developer.
  • ZpAz
  • Laatst online: 20:09
Wil je het in een tabel ofzo stoppen? Dan moet je nog een NSTable en een DataSource toevoegen. De datasource leest dan je geparsede XML data uit.
  • YopY
  • Laatst online: 12-11 10:52
Wat hoort 'ie te doen dan? Voor zover ik weet doet hij nl precies wat hij hoort te doen - de XML parsen als de view geladen wordt. Meer niet, want meer staat niet in je code. Je haalt een item genaamd 'intro' uit de XML... maar doet er vervolgens niks mee.
Wat je vergeet is iets te doen met de RSS feed die je parset.
  • NLxAROSA
Er vanuit gaande dat de XML die je leest bestaat uit een verzameling artikelen, waarvan je het veld 'intro' wil tonen in een lijstje, heb je in ieder geval nog een UITableView nodig, waarbij je je ViewController (of een andere class) gebruikt als dataSource/delegate. Zoek eens in de Apple documentatie op 'UITableViewDelegate Protocol Reference'.
Ik neem aan dat je ook het volledige artikel wil tonen in een detail view als de gebruiker 'm aantapt in het lijstje, maar begin eerst maar even hier mee. :)
Maar zoals boven al aangegeven: wellicht wil je iets heel anders, maar dat is zonder context nogal lastig te beoordelen.
