[bug/forum] Soms werkt [url=]tekst[/url] incorrect
  • 243 views
  • Xthemes.us
  • Laatst online: 11-10 23:48
De url tag heeft moeite met sommige urls.
De onderstaande url is hier een voorbeeld van (vermoedelijk door het gebruik van de rechthoekige haakjes)
http://www.prad.de/en/guide/ergebnis_auswahl_stat.html?pradid=22f820892730b8c1aed6047771aa7a94&manufacturer[]=no+specific+feature+selected&price1=&price_old=no&erfdatum=01.01.2000&1[]=0&28[]=0&43[]=2&2[]=no+specific+feature+selected&31[]=no+specific+feature+selected&3[]=no+specific+feature+selected&8[]=no+specific+feature+selected&36[]=no+specific+feature+selected&10[]=0&4[]=no+specific+feature+selected&5[]=no+specific+feature+selected&39[]=no+specific+feature+selected&6[]=no+specific+feature+selected&7[]=no+specific+feature+selected&37[]=no+specific+feature+selected&38[]=no+specific+feature+selected&11[]=no+specific+feature+selected&13[]=0&9[]=0&35[]=no+specific+feature+selected&44[]=2&30[]=2&14[]=2&15[]=2&16[]=2&17[]=2&18[]=2&19[]=2&20[]=no+specific+feature+selected&21[]=0&22[]=2&23[]=2&24[]=0&33[]=0&40[]=no+specific+feature+selected&32[]=120Hz&25[]=0&order_by=10&order_order=desc&Submit=find+displays
Via de "Maak een link van de tekst knop":
http://www.prad.de/en/gui...desc&Submit=find+displays
werkt
Via [url="http://"]tekst[/url]:
tekst
werkt
Via [url=http://]tekst[/url]:
[url=http://www.prad.de/en/guide/ergebnis_auswahl_stat.html?pradid=22f820892730b8c1aed6047771aa7a94&manufacturer[]=no+specific+feature+selected&price1=&price_old=no&erfdatum=01.01.2000&1[]=0&28[]=0&43[]=2&2[]=no+specific+feature+selected&31[]=no+specific+feature+selected&3[]=no+specific+feature+selected&8[]=no+specific+feature+selected&36[]=no+specific+feature+selected&10[]=0&4[]=no+specific+feature+selected&5[]=no+specific+feature+selected&39[]=no+specific+feature+selected&6[]=no+specific+feature+selected&7[]=no+specific+feature+selected&37[]=no+specific+feature+selected&38[]=no+specific+feature+selected&11[]=no+specific+feature+selected&13[]=0&9[]=0&35[]=no+specific+feature+selected&44[]=2&30[]=2&14[]=2&15[]=2&16[]=2&17[]=2&18[]=2&19[]=2&20[]=no+specific+feature+selected&21[]=0&22[]=2&23[]=2&24[]=0&33[]=0&40[]=no+specific+feature+selected&32[]=120Hz&25[]=0&order_by=10&order_order=desc&Submit=find+displays]tekst[/url]
werkt niet
Met dank aan Darkstone die de wel merkende manieren had gepost, maak zelf altijd gebruik van de laatste methode. Het zou handig zijn dat die ook op de juiste manier zou werken
MSI GX640 - 8GB RAM, Radeon 5970, 80GB SSD
  • PromoX
  • Laatst online: 26-10 17:33
PromoX
Flying solo
De url tussen " " zetten, dus [url="site"]omschrijving[/url].
[ Voor 58% gewijzigd door PromoX op 11-12-2011 02:23 ]
And I'm the only one and I walk alone.
  • Wiethoofd
  • Laatst online: 30-09 23:41
Wiethoofd
Broadcast TOM
De url tussen "" zetten of de [ en ] naar respectievelijk %5B en %5D omzetten, dan werkt ie wel zonder quotes er omheen. Bekijk de bron van dit bericht maar :>
  • Xthemes.us
De url tussen quotes plaatsen is precies wat ik bij het 2de voorbeeld heb gedaan, het gaat om het laatste voorbeeld. HTML entities gebruiken voor de brackets is ook creatief gevonden, maar ik wou met deze post aankaarten dat voorkomen beter dan genezen is.
Er zijn manieren om het goed te laten werken maar er is ook een manier die niet goed werkt, en het zou prettig zijn als die gefixt wordt.
  • Dirk
  • Laatst online: 05:13
Dirk
Coördinator Frontpagemoderatie
Ehrm, blokhaken horen urlencoded te zijn, crisp heeft daar ook wel eens een bugreport over ingediend bij mozilla.
All statements are true in some sense, false in some sense, meaningless in some sense, true and false in some sense, true and meaningless in some sense, false and meaningless in some sense, and true and false and meaningless in some sense.
  • Xthemes.us
Dat is een reactie waar ik iets mee kan, gebruik vrijwel exclusief Firefox. Als dit wordt afgedaan als een browserbug (bij het kopiëren van urls) dan kan ik daar mee leven ;).
  • crisp
  • Laatst online: 00:38
crisp
Devver
Pixelated
Dit is inderdaad ambigu:
\[url=http://tweakers.net?foo\[]=bar]blaat[/url]
Want hoe moet je dit nu parsen? Je begint met:
so far so good, maar dan komt de parser weer een \[ tegen - hmmz; is dat het begin van een nieuwe tag ook al is de vorige tag niet afgesloten?
Daarom: in dit soort gevallen altijd quotes om je attributen gebruiken (ook bij komma's in de url) en/of zorgen dat blokhaken in de url goed geëncodeerd zijn (en dat gaat inderdaad fout in Firefox bij copy/pasten vanuit de urlbalk).
Dit is geen bug en helaas ook een can't fix aan onze kant.
Intentionally left blank
