Grote problemen met Fedora dependencies na upgrade
  • chronoz
  • Laatst online: 09-10-2022
Ik heb Fedora geupgrade via de 4GB DVD van Fedora 15 naar Fedora 16, dat ging op zich goed, maar ik kan nu op geen manier meer het OS updaten.
yum update --skip-broken...
(259/279): thai-scalable-fonts-common-0.4.17-1.fc16.noarch.rpm        |  11 kB     00:00
(260/279): thai-scalable-waree-fonts-0.4.17-1.fc16.noarch.rpm        | 169 kB     00:00
(261/279): thunderbird-8.0-2.fc16.x86_64.rpm        |  32 MB     00:09
(262/279): tigervnc-server-1.1.0-2.fc16.x86_64.rpm        | 154 kB     00:00
(263/279): tigervnc-server-minimal-1.1.0-2.fc16.x86_64.rpm        | 866 kB     00:00
(264/279): tomboy-1.8.0-1.fc16.x86_64.rpm        | 6.2 MB     00:05
(265/279): twolame-libs-0.3.13-1.fc16.x86_64.rpm        |  48 kB     00:00
(266/279): unrar-4.0.7-1.fc16.x86_64.rpm        | 103 kB     00:00
(267/279): usb_modeswitch-1.2.0-1.fc16.x86_64.rpm        |  59 kB     00:00
(268/279): usb_modeswitch-data-20111023-1.fc16.noarch.rpm        |  53 kB     00:00
(269/279): vlc-1.1.12-1.fc16.x86_64.rpm        | 1.9 MB     00:00
(270/279): vlc-core-1.1.12-1.fc16.x86_64.rpm        | 6.7 MB     00:01
(271/279): wxBase-2.8.12-1.fc16.x86_64.rpm        | 564 kB     00:00
(272/279): wxGTK-2.8.12-1.fc16.x86_64.rpm        | 2.9 MB     00:00
(273/279): x264-libs-0.0.0-0.31.20110811.fc16.x86_64.rpm        | 308 kB     00:00
(274/279): xine-lib-1.1.19-7.fc16.x86_64.rpm        | 2.0 MB     00:00
(275/279): xorg-x11-server-Xephyr-1.11.2-3.fc16.x86_64.rpm        | 846 kB     00:00
(276/279): xulrunner-8.0-1.fc16.x86_64.rpm        |  10 MB     00:03
(277/279): yum-langpacks-0.2.4-1.fc16.noarch.rpm        |  18 kB     00:00
(278/279): zlib-1.2.5-5.fc16.i686.rpm        |  83 kB     00:00
(279/279): zvbi-0.2.33-9.fc16.x86_64.rpm        | 374 kB     00:00
Total        2.8 MB/s | 278 MB     01:39
Running Transaction Check
ERROR with transaction check vs depsolve:
libcryptui.so.0()(64bit) is needed by seahorse-plugins-2.91.6-0.2.git1e35fd9.fc16.x86_64
Please report this error in http://yum.baseurl.org/report
** Found 98 pre-existing rpmdb problem(s), 'yum check' output follows:
GConf2-gtk-2.32.3-1.fc15.x86_64 has missing requires of GConf2 = ('0', '2.32.3', '1.fc15')
atk-2.2.0-2.fc16.x86_64 is a duplicate with atk-2.0.0-1.fc15.i686
audit-libs-2.1.3-4.fc16.x86_64 is a duplicate with audit-libs-2.1.3-1.fc15.i686
avahi-libs-0.6.30-4.fc16.x86_64 is a duplicate with avahi-libs-0.6.30-3.fc15.i686
cairo-1.10.2-4.fc16.x86_64 is a duplicate with cairo-1.10.2-3.fc15.i686
1:cups-libs-1.5.0-16.fc16.x86_64 is a duplicate with 1:cups-libs-1.4.8-5.fc15.i686
cyrus-sasl-lib-2.1.23-25.fc16.x86_64 is a duplicate with cyrus-sasl-lib-2.1.23-18.fc15.i686
1:dbus-libs-1.4.10-3.fc16.x86_64 is a duplicate with 1:dbus-libs-1.4.6-5.fc15.i686
device-mapper-multipath-0.4.9-15.fc15.x86_64 has missing requires of kpartx = ('0', '0.4.9', '15.fc15')
ffmpeg-libs-0.7.6-1.fc15.x86_64 has missing requires of libcelt0.so.1()(64bit)
focuswriter-1.3.2.1-2.fc15.x86_64 has missing requires of libhunspell-1.2.so.0()(64bit)
fontconfig-2.8.0-4.fc16.x86_64 is a duplicate with fontconfig-2.8.0-3.fc15.i686
gamin-0.1.10-10.fc16.x86_64 is a duplicate with gamin-0.1.10-9.fc15.i686
gd-2.0.35-13.fc16.x86_64 is a duplicate with gd-2.0.35-12.fc15.i686
gdk-pixbuf2-2.24.0-1.fc16.x86_64 is a duplicate with gdk-pixbuf2-2.23.3-2.fc15.i686
glib2-2.30.1-1.fc16.x86_64 is a duplicate with glib2-2.28.8-1.fc15.i686
glibc-2.14-5.i686 has missing requires of glibc-common = ('0', '2.14', '5')
glibc-2.14.90-14.x86_64 is a duplicate with glibc-2.14-5.i686
gnome-python2-bonobo-2.28.1-4.fc15.x86_64 has missing requires of gnome-python2 = ('0', '2.28.1', '4.fc15')
gnome-python2-gnomedesktop-2.32.0-4.fc15.x86_64 has missing requires of gnome-python2-desktop = ('0', '2.32.0', '4.fc15')
gnutls-2.12.7-2.fc16.x86_64 is a duplicate with gnutls-2.10.5-1.fc15.i686
gstreamer-0.10.35-1.fc16.x86_64 is a duplicate with gstreamer-0.10.34-1.fc15.i686
gstreamer-plugins-base-0.10.35-1.fc16.x86_64 is a duplicate with gstreamer-plugins-base-0.10.33-1.fc15.i686
hplip-gui-3.11.10-5.fc15.x86_64 has missing requires of hplip = ('0', '3.11.10', '5.fc15')
hplip-gui-3.11.10-5.fc15.x86_64 has missing requires of libsane-hpaio = ('0', '3.11.10', '5.fc15')
initscripts-9.33-1.fc16.x86_64 has installed conflicts libselinux < ('0', '2.1.0', None): libselinux-2.0.99-4.fc15.i686
irssi-0.8.15-4.fc15.x86_64 has missing requires of perl(:MODULE_COMPAT_5.12.3)
jack-audio-connection-kit-example-clients-1.9.7-2.fc15.x86_64 has missing requires of jack-audio-connection-kit = ('0', '1.9.7', '2.fc15')
jack-audio-connection-kit-example-clients-1.9.7-2.fc15.x86_64 has missing requires of libcelt0.so.1()(64bit)
keyutils-libs-1.5.2-1.fc16.x86_64 is a duplicate with keyutils-libs-1.2-7.fc15.i686
krb5-libs-1.9.1-18.fc16.x86_64 is a duplicate with krb5-libs-1.9.1-14.fc15.i686
lcms-libs-1.19-4.fc16.x86_64 is a duplicate with lcms-libs-1.19-4.fc15.i686
Een langere pastebin is te vinden op http://www.codepad.eu/view/raw/4973654. Ik heb de instructies proberen uit te voeren volgens http://fedoraunity.org/Members/fenris02/post_upgrade_cleanup.
Ik gebruikte Fedora 2 maanden en het beviel goed en had alles naar eigen wens aangepast. De upgrade heb ik ook volgens instructies aangepast en ik heb expres niet naar F16 geüpdate met Yum, omdat dat problemen zou kunnen veroorzaken. De enige RPM repositories die ik gebruik zijn Rpmfusion en Fedora, dus daar lijkt het ook niet aan te liggen.
Andere gebruikers lijken ook gewoon veel F15 pakketten nog te hebben en zowel x86 als x64 pakketten te hebben, dus dat lijkt op zich ook goed. Hoe zou ik hier uit kunnen komen?
  • Rainmaker
  • Laatst online: 14-07-2024
Rainmaker
RHCDS
Het lijkt erop alsof alle F16 pakketten erop staan, maar in de RPM database nu zowel de F15 als de F16 paketten staan.
Je zou eens kunnen proberen de RPM database te rebuilden, zoals hier uitgelegd.
Ook kun je met ldbedit de database rechtstreeks gaan bewerken, maar dat is niet echt aangeraden.
We are pentium of borg. Division is futile. You will be approximated.
  • chronoz
Op een nieuwe installatie van F16, staan zo'n 1000 F16- en 300 F15-pakketten, dus ik weet niet of dat een probleem is. Ik heb opnieuw de rpm database ook aangemaakt volgens de instructies.
Ik heb het verholpen door met yum remove alle fc15 rpm's uit die lijst te verwijderen, wel goed opletten natuurlijk, maar er kwamen voornamelijk fc15 dependencies mee en de meeste zagen er niet belangrijk uit. Gelukkig maar, was op zich redelijk blij overgestapt te zijn op Linux.
  • Borromini
Borromini
Mislukt misantroop
Ontbrekende bibliotheken kan je altijd checken met
ldd $path/$binary | grep -i not found
Als je dat loopt kan je zien wat er allemaal mankeert en dat fiksen (mocht het nodig zijn).
[ Voor 32% gewijzigd door Borromini op 30-11-2011 15:10 ]
  • CAPSLOCK2000
  • Laatst online: 18:21
CAPSLOCK2000
zie teletekst pagina 888
Wilde gok: heb je de 64-bits versie over de 32-bits versie heen geinstalleerd?
This post is warranted for the full amount you paid me for it.
