(JIT) debugging
  • dorzel
  • Laatst online: 11-09 07:23
DIT PROBLEEM IS INMIDDELS VERHOLPEN, EN MAG E.V.T. VERWIJDERD WORDEN.
wie kan mij met het volgende helpen,??
mijn systeem:
moederbord: asrock extreme 3
videokaard: evga 460 superclocked
geheugen: OCZ DDR3 PC3-10666 Gold Low-Voltage Triple Channel
Cpu: intel core i7-920 D0
besturingssysteem: win 7 prof. 64 bit.
bij het instaleren van as ssd krijg ik de volgende foutmelding.
geen idee hoe ik dit moet oplossen.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.OutOfMemoryException: Onvoldoende geheugen om het programma nog langer uit te voeren.
at System.Management.ThreadDispatch.Start()
at System.Management.ManagementScope.Initialize()
at System.Management.ManagementObjectSearcher.Initialize()
at System.Management.ManagementObjectSearcher.Get()
at AS_SSD_Benchmark.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
AS SSD Benchmark
Assembly Version: 1.6.4237.30508
Win32 Version: 1.6.4237.30508
CodeBase: file:///C:/Users/Iwan/AppData/Local/Temp/Rar$EX28.080/AS%20SSD%20Benchmark.exe
System
Win32 Version: 2.0.50727.5447 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
AS SSD Benchmark.resources
CodeBase: file:///C:/Users/Iwan/AppData/Local/Temp/Rar$EX28.080/en-US/AS%20SSD%20Benchmark.resources.DLL
System.Management
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mvg,
Iwan
[ Voor 0% gewijzigd door dorzel op 23-11-2011 18:55 . Reden: opgelost ]
  • CoolGamer
  • Laatst online: 05-10 08:26
CoolGamer
What is it? Dragons?
Herstart je computer en probeer het nog eens. Het programma zegt niet genoeg geheugen te hebben.
¸.·´¯`·.¸.·´¯`·.¸><(((º>¸.·´¯`·.¸><(((º>¸.·´¯`·.¸.·´¯`·.¸.·´¯`·.¸<º)))><¸.·´¯`·.¸.·´¯`·.¸.·´¯`·.¸
  • dorzel
bedankt voor jou reactie.
dat van het te weinig geheugen is niet mogelijk, maar ik heb het al opgelost.
het bleek dat het programma geblokkeerd werd om gebruik te maken van het geheugen.
dit was te veranderen door de instellingen van het programma in defence+ te wijzigen van Comodo security suite.
