Exchange 2007 SP3 Upgrade mislukt
Ik heb een SBS 2008 SP2 Standard server, hierop draait Exchange Server 2007 SP2
wanneer ik hier een upgrade op uitvoer naar SP3, dan hangt hij begeven moment bij
de Client Access Role. En komt met fout HRESULT: 0x80005006
Ik heb anti-virus software al compleet verwijderd, Sharepoint 3.0 + .NET 4.0 (zoals op Technet als oplossing werdt gegeven) Echter mocht dit niet baten.
In de event viewer komt hij met het volgende:
Watson report about to be sent to dw20.exe for process id: 7656, with parameters: E12, c-RTL-AMD64, 08.03.0083.006, ExSetup, M.E.Management, M.E.M.M.IisUtility.SetAuthenticationMethod, S.R.InteropServices.COMException, 50be, 08.03.0083.000. ErrorReportingEnabled: False
En onderin de logfile van de setup, staat het volgende:
[11/22/2011 6:42:56 AM] [2] [WARNING] An unexpected error has occurred and debug information is being generated: Exception from HRESULT: 0x80005006
[11/22/2011 6:42:56 AM] [2] [ERROR] Exception from HRESULT: 0x80005006
[11/22/2011 6:42:57 AM] [2] [ERROR] The pipeline has been stopped.
[11/22/2011 6:42:57 AM] [1] Exception : System.Management.Automation.CmdletInvocationException: Exception from HRESULT: 0x80005006 ---> System.Runtime.InteropServices.COMException (0x80005006): Exception from HRESULT: 0x80005006
at System.DirectoryServices.Interop.UnsafeNativeMethods.IAds.PutEx(Int32 lnControlCode, String bstrName, Object vProp)
at System.DirectoryServices.PropertyValueCollection.OnInsertComplete(Int32 index, Object value)
at System.Collections.CollectionBase.System.Collections.IList.Add(Object value)
at System.DirectoryServices.PropertyValueCollection.Add(Object value)
at Microsoft.Exchange.Management.Metabase.IisUtility.SetAuthenticationMethod(DirectoryEntry virtualDirectory, AuthenticationMethodFlags method, Boolean value)
at Microsoft.Exchange.Management.SystemConfigurationTasks.MobileSyncVirtualDirectoryHelper.SetToMetabase(ADMobileVirtualDirectory adObject)
at Microsoft.Exchange.Management.SystemConfigurationTasks.SetMobileSyncVirtualDirectory.InternalProcessRecord()
at Microsoft.Exchange.Configuration.Tasks.Task.ProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
--- End of inner exception stack trace ---
at System.Management.Automation.Internal.PipelineProcessor.SynchronousExecuteEnumerate(Object input, Hashtable errorResults, Boolean enumerate)
at System.Management.Automation.PipelineNode.Execute(Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext context)
at System.Management.Automation.StatementListNode.ExecuteStatement(ParseTreeNode statement, Array input, Pipe outputPipe, ArrayList& resultList, ExecutionContext context)
[11/22/2011 6:42:57 AM] [1] [WARNING] An unexpected error has occurred and debug information is being generated: Exception from HRESULT: 0x80005006
[11/22/2011 6:42:57 AM] [1] [ERROR] Exception from HRESULT: 0x80005006
  • --Mulder--
  • Laatst online: 08-10 16:11
Artikel van MS gevolgd voor het installeren van Exchange 2007 SP3 op SBS 2008?
How to install Exchange Server 2007 SP3 on a computer that is running Windows SBS 2008
Onderstaand een tread waar ook problemen zijn met SP3 op SBS 2008.
http://social.technet.mic...919abe02ef6?prof=required
1 van de fixes was dat er een 2 tal key's bleven staan na de-installatie van McAfee Anti-Virus, zie onder:
For future reference:
Issue: Unable to install Exchange SP3
Cause: AdvancedInstallersNeedResolving and PendingXmlIdentifier entries were present under HKEY_LOCAL_MACHINE\Components registry key
Resolution: Deleted the above two entries, rebooted the server and installed Exchange SP3 from newly downloaded setup
[ Voor 24% gewijzigd door --Mulder-- op 22-11-2011 21:04 ]
Probleem opgelost. Het zat hem erin dat ik de complete SBS Applications in de IIS moest rebuilden. (met de Metabase explorer heb ik ook verschillende zaken verwijderd) Uiteindelijk alles ge-rebuild, en het werkt weer netjes :-) Draai nu SP3 met Rollup 5
