[php] Uploaded file bestaat niet
  • Rekcor
  • Laatst online: 08-09 12:13
SOLVED
Mijn bestand-upload script werkt niet, maar ik begrijp niet wat er misgaat. Hier de relevante code:
PHP:
error_reporting(E_ALL);
print_r($_FILES);
//see if file exists
if(file_exists($_FILES['myfileinput']['tmp_name'])){
 echo ' File '.$_FILES['myfileinput']['tmp_name'].' does exist!';
}else{
 echo ' File '.$_FILES['myfileinput']['tmp_name'].' does NOT exist!';
//move the file
if (!move_uploaded_file($_FILES['myfileinput']['tmp_name'], 'mywritablefolder/mypicture.jpg')) {
 echo 'Could not move file!';
Dit geeft als resultaat:
Array
    [myfileinput] => Array
            [type] => image/jpeg
            [tmp_name] => /tmp/phpWOvsyK
            [error] => 0
            [size] => 9483
File /tmp/phpWOvsyK does NOT exist!
Ik krijg dus geen foutmeldingen, $_FILES['myfileinput']['error'] is netjes 0, maar het bestand /tmp/phpWOvsyK bestaat toch niet. Het staat ook niet in de /tmp folder.
Hoe kan dit?
  • zwippie
zwippie
Electrons at work
Heb je in je form tag wel enctype='multipart/form-data' gezet?
How much can you compute with the "ultimate laptop" with 1 kg of mass and 1 liter of volume? Answer: not more than 10^51 operations per second on not more than 10^32 bits.
  • Rekcor
Uiteraard :)
  • wackmaniac
  • Laatst online: 21-10 10:01
die tmp_name hoeft niet per se onder /tmp/* te staan:
http://www.php.net/manual...variables.files.php#89674:
Array
    [file1] => Array
            [name] => MyFile.txt (comes from the browser, so treat as tainted)
            [type] => text/plain  (not sure where it gets this from - assume the browser, so treat as tainted)
            [tmp_name] => /tmp/php/php1h4j1o (could be anywhere on your system, depending on your config settings, but the user has no control, so this isn't tainted)
            [error] => UPLOAD_ERR_OK  (= 0)
            [size] => 123   (the size in bytes)
Afhankelijk van je settings kan die map dus ergens anders op je file system staan. Wellicht heb je wat aan is_uploaded_file.
[ Voor 13% gewijzigd door wackmaniac op 27-10-2011 14:37 ]
Read the code, write the code, be the code!
  • arendvw
  • Laatst online: 17-08 04:43
Is je map waar je 'm heen probeert te verplaatsen wel writable voor je webserver?
  • Rekcor
Opgelost! Het was uiteindelijk een combinatie van schrijfrechten, een typo, een error-reporting instelling..
Bedankt!
