Niet verwijderbare map :(
Ik zit met een map die niet te verwijderen lijkt.
Ik heb het meest al geprobeerd.
Free Windows Utilities to Delete Undeleteable, Currently In-Use, Locked, Busy Files
OpenedFilesViewer
OpenedFilesViewer lets you see a list of files that are currently opened on your system as well as the process that is currently holding the file open. You can also close the handle of the file from within the program (although of course that may destabilise your system). This program works under Windows 2000, XP, and 2003. It also works on the 32 bit version of Windows 7, Vista, and 2008.
Unlocker
Unlocker uses a variety of methods to delete the persistent or locked files, including attempting to close the handle, killing the process holding the file open, unloading the DLL that may have open the file handle, scheduling the file to be deleted on the next reboot, etc. It integrates with Windows Explorer and can be accessed simply with a right click on the filename within Explorer. A command line interface is also available. The program works under Windows 2000, XP and 2003.
WhoLockMe
If you have ever received a message from Windows like "Cannot delete (filename). There has been a sharing violation. The source or destination file may be in use" when you tried to delete, move or rename a file, then this program may be helpful. It integrates with the Windows shell, and provides you a right click context menu that when used, identifies the processes (running programs) that have locked that file, preventing it from being deleted, moved or renamed.
FileAssassin
FileAssassin deletes locked malware files using a variety of methods, including unloading modules, closing remote handles and terminating processes. You get to select the method that the program uses from its user interface. The program works in Windows 2000, XP, Vista and NT. There is also a portable version that you can use from a flash / USB drive.
FreeFile
FreeFile attempts to free locked DLL and EXE files (so that you can delete, move or rename them) by locating the processes that have open handles to them. You can then terminate the process from within the program. The program requires you to have installed the .NET framework. It works under Windows 2000 and XP.
UnLock IT
This utility allows you to identify the processes (running programs) that are keeping a particular file open (and thus preventing you from deleting, moving or renaming it) and terminate those processes.
BusyDelete (BDel)
BusyDelete allows you to delete files that are busy (currently in use) by marking it for deletion by Windows during the next reboot of the system. The program works under Windows 95, 98, ME, NT, 2000 and XP. It is a command line program that requires you to open a console window (sometimes called a DOS prompt) to use it.
Kan iemand me helpen?
  • HTT-Thalan
  • Laatst online: 10:28
HTT-Thalan
Vertel eens welke map je precies probeert te verwijderen? Waar behoort hij toe? Waarom moet hij weg?
Een map van een voormalige oude windows installatie. Die stond nog op een mijn schijf, formateren lukt niet, want ik heb er al belangrijke data naar toe verplaatst.
Ik heb al geprobeerd de map te verwijderen door hem te vernoemen met en andere naam. Geen succes.
Dus iets in Windows (XP) houdt bestanden in de map actief. Waardoor verwijderen onmogelijk wordt.
  • Arie-
Linux boot cd'tje, ubuntu live ofzo?
  • HTT-Thalan
HTT-Thalan
Ja, of gewoon een backup maken van die belangrijke data en opnieuw beginnen, dan weer je zeker dat 'ie schoon is.
  • djexplo
  • Laatst online: 31-07 15:50
Wat zegt Unlocker dan over de folder? Noemt hij bepaalde processen?
Draai ook eens "chkdsk /F"
'if it looks like a duck, walks like a duck and quacks like a duck it's probably a duck'
  • dezejongeman
  • Laatst online: 01-10 09:27
vermoedelijk heb je gewoon geen rechten. probeer je huidige map eens full control aan je administrator account.
lukt het gewone verijderen dan nog niet dan zou je nog een tool kunnen proberen.
vermoedelijk zijn de rechten nog actief van je vorige installatie de ssid van de administrator van je vorige windows komt niet overeen met de huidige.
  • dezejongeman
sloeg nergens op verkeerde topic dus zo maar aangepast
[ Voor 128% gewijzigd door dezejongeman op 20-10-2011 15:54 . Reden: toegevoegd aan het verkeerde topic ]
  • HenkEisDS
  • Laatst online: 27-10 07:48
Open cmd.exe als administrator en probeer het daar eens mee.
Run je die tooltjes van je ook als administrator (rechtermuisknop > uitvoeren als administrator)?
  • DeTeraarist
  • Laatst online: 20-10 21:58
DeTeraarist
#Boots2Asses
In SafeMode opstarten wil ook wel eens werken.
Soms, als ik heel stil ben, kan ik de zon horen schijnen
DeTeraarist schreef op donderdag 20 oktober 2011 @ 17:49:
Ik wilde net zeggen, het lijkt me dat Veilige Modus (zoals het zo fijn vertaald is) daarvoor bedoeld is.
Veilige modus al geprobeerd, vergeten te melden :)
Met cdm.exe zegt hij toegang geweigert?
Checkdisk /f Geen resultaat.
Bizar: De map neemt steeds meer ruimte in beslag. van 24 gb, wat al veel was naar meer dan 44 gb op moment, met wel 14000 submappen :?
Denk dat ik te maken heb met een virus oid...
Ga nu dat met die administrator rechten proberen :)
Echt alles al geprobeerd, dus ga nu bealngrijke data backuppen en de schijf formateren :)
mocht dit ook niet lukken, dan meld ik wel weer.
Rats weg met de partitie en nieuwe maken :), daarna formateren en weer een schone schijf tot mijn beschiking.
Dit werkte prima.
Dus status opgelost :)
[ Voor 29% gewijzigd door Verwijderd op 20-10-2011 22:43 . Reden: wat toevoegingen! ]
