Beste Tweakers,
Tijdens een exchange 2010 installatie op een w2k8 server krijgen wij de volgende melding.
We komen er maar niet uit wat nou de oplossing kan zijn.
Zie hieronder:
Summary: 7 item(s). 5 succeeded, 1 failed.
Elapsed time: 00:09:09
Preparing Setup
Completed
Elapsed Time: 00:00:00
Stopping Services
Completed
Elapsed Time: 00:00:01
Copy Exchange Files
Completed
Elapsed Time: 00:00:25
Restoring services
Completed
Hub Transport Role
Completed
Elapsed Time: 00:05:50
Client Access Role
Failed
Error:
The following error was generated when "$error.Clear(); Install-ExchangeCertificate -services "IIS, POP, IMAP" -DomainController $RoleDomainController" was run: "Could not grant Network Service access to the certificate with thumbprint F1A641E8AE775F185C23A6F41AA1DECFB52E7A03 because a cryptographic exception was thrown.".
Toegang geweigerd.
Elapsed Time: 00:02:51
Finalizing Setup
Cancelled
Hebben jullie enig idee hoe we dit op kunnen lossen, en de installatie voort kunnen zetten?
Mvg
  • Question Mark
  • Laatst online: 21-11 10:50
Question Mark
Moderator SSC/WOS
F7 - Nee - Ja
Op een internet post kom ik onderstaande procedure tegen:
Here is what I did to resolve the problem and successfully install Exchange 2010:
Since Exchange did install the Hub Transport role and Management Tools before failing, I was able to open the Exchange Management Console.
1. Open Exchange Management Console
2. Click Server Config in the left pane
3. In the center pane, under the Exchange Certificates tab, click on Microsoft Exchange
4. Click Assign Services to Certificate in the Right pane
5. Select each required service (I selected all except Unified Messaging)
6. Click Assign
You should now be able to install the remaining roles.
http://social.technet.mic...65-4261-82c1-1309f9065d15
[ Voor 7% gewijzigd door Question Mark op 17-10-2011 12:46 ]
Bedankt!
We hebben het getest, en alles werkt goed! Super!
